today> Twyndyllyngs not postponed Chez Mosc
G2X Pitch Stick Weirdness
Page 1 of 1 [20 Posts]
mtvic
PostPosted: Mon Feb 18, 2008 6:36 pm    Post subject: G2X Pitch Stick Weirdness Reply with quote  Mark this post and the followings unread
Could the pitch stick on my G2 be out of calibration?
It does not track well i.e. ,wobbly pitching and takes some time for the sound to return to the played keys tone.
I have tried adjusting the bend amount to no avail.
Is there any hardware adjustments inside that could be made to correct this?
An adjustment screw perhaps?
Audio files: 296
PostPosted: Mon Feb 18, 2008 6:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
The pitch stick has a mechanical vulnerability ... it works with pressure sensitive resistors glued onto a bent piece of metal, sometimes they loosen up and that means they go weird, it also means repair is needed ... I fear you ran into that Crying or Very sad
mtvic
PostPosted: Tue Feb 19, 2008 8:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is there a way to reglue or repair without sending it in for repair, my warranty has expired.
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Wed Feb 20, 2008 2:09 am    Post subject: Reply with quote  Mark this post and the followings unread
I had my pitch stick replaced a couple of years ago. You could maybe get the part from Clavia and install it yourself. Only three wires to reconnect from memory.
mtvic
PostPosted: Wed Feb 20, 2008 4:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds like the right thing to do.
There is a Clavia authorized service center in the area,
maybe I can order from them and replace it myself.
mtvic
PostPosted: Wed Feb 20, 2008 6:08 pm    Post subject: Success g2x pitch stick weirdness Reply with quote  Mark this post and the followings unread
mailed Jason At Nord US
here is the scoop
"From: "Jason Stanfield" <jason> Add Mobile Alert
To: "Michael Victor" <mtv022002>
Date: Wed, 20 Feb 2008 18:15:06 -0500
Subject: RE: Support From Michael Victor
They're $75, and yes I'll sell one to you direct.
Call me at [866] 855-2156 after 10am EDT and provide a credit card & shipping address.
Make sure to remind me of this email and that it's a pitch stick for a G2X … they're longer than the ones for the Leads
Jason Stanfield
Product Manager
Nord USA
jason@nordusa.com
[866] 855-2156"
info for future reference
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Wed Feb 20, 2008 9:25 pm    Post subject: Re: Success g2x pitch stick weirdness Reply with quote  Mark this post and the followings unread
here is the scoop
That's good news I guess.
I had mine replaced by a serviceman back in 2005ish and was only charged 30NZD all up(=15USD in those days)
Maybe I got a good price because it was only a few months out of warranty. Smile
Off topic, I bought an expensive (2-3K) swivel chair 5 and a half years ago. Recently, one of the arm rests developed a small split which my three year old Liam, happily picked at till he exposed the sharp metal sub structure.
I took the arm off and walked down to the store I bought the chair from to see if I could get a replacement. The shop had moved to new premises across the road. I had no proof of purchase and they had no record of me on computer but the salesman called the agent. He then offered to courier a complete new pair of arms to my address, at no cost Shocked
The arms arrived but wouldn't fit because they were for a newer model. I managed to unscrew the arm rest parts and the chair is as good as new.
mtvic
PostPosted: Thu Feb 21, 2008 4:31 am    Post subject: Reply with quote  Mark this post and the followings unread
I have received some knobs that had come off my DSI Desktop evolver.
Just dropped an e-mail to Dave explaining the design flaw of the knobs being loose and falling off .
He sent me a set free of charge.
Then again;same situation with my novation xio synth.
Novation came through with some free replacements even during
NAMM show 2008!
And again from Jason for my nord lead 2X ,
when it slid from my X stand and broke off a key he came through for me with a free replacement .
I guess mechanical parts like the pitch stick assembly for the G2 are not
free but,75 dollars isn't an unreasonable price for such a part.
One thing is for sure, Clavia US has quick response for technical issues.
Once again,
thanks for your help Ian and Jan,
You gotta love electro-music.com Exclamation
Very Happy Very Happy
mtvic
PostPosted: Fri Feb 22, 2008 4:32 am    Post subject: Reply with quote  Mark this post and the followings unread
A replacement is on its way!!!
I am thankful for all of your assistance.
I will post again when it arrives.
In case I need assistance with the installation
m
mtvic
PostPosted: Thu Feb 28, 2008 10:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Replacement has arrived .
Now its time to crack open the g2x and get the iron hot .
Installation should be simple .
If any problems arise I'll be sure to consult.
m
mtvic
PostPosted: Mon Mar 10, 2008 5:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Operation Pitch stick
Completed without an iron
Open
Cut
Splice Wires X 8 (2 RED ,2 BLUE X 2
add new part (Pitch Stick)
Crimp on disconnects X 4
Connect disconnects
CLOSE
PLAY
SUCCESS
Audio files: 296
PostPosted: Mon Mar 10, 2008 6:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool Laughing
onosendai
G2 patch files: 4
PostPosted: Sat Nov 06, 2010 1:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have to replace mine.
How do you open a G2 ? I've tried to remove all the up screw but i can't open it. Bottom screw ?
varice
Audio files: 29
G2 patch files: 54
PostPosted: Sat Nov 06, 2010 5:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, there are also some screws on the bottom of the case that need to be removed, but there are many screws that do not. The instructions for installing the expansion board tell what needs to be done to properly open the case:
http://www.clavia.se/G2/V1_10/G2expansionboard.pdf
Good luck with your repair!
varice
onosendai
G2 patch files: 4
PostPosted: Sat Nov 06, 2010 6:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Done ! Thanks Smile
But i have new questions
Open <-- Check !!
Cut <-- Cut what ? Pitch Stick wire ?
Splice Wires X 8 (2 RED ,2 BLUE X 2 <-- What does that mean ?
add new part (Pitch Stick) <-- I see
Crimp on disconnects X 4 <-- What does that mean ?
Connect disconnects <-- What ? Smile
CLOSE <-- easy
PLAY <-- ahah too easy
SUCCESS <-- it will be nice
Nodular
G2 patch files: 7
PostPosted: Thu Jul 21, 2011 7:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello,
this is strange.
Pitch Stick weirdness started gradually on my G2X.
After a 2 months period the stick was working really bad so I ordered a couple of replacements.
They arrived quickly and I immediately replaced the faulty stick with a new one.
SURPRISE !!!
The problem is still there, even if a minimal improvement can be noticed.
Shocked
Any idea of what could have happened anybody ?
boxcolony
PostPosted: Sun Jul 31, 2011 11:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
It happened to me too, bad for me I ordered 2 pitch sticks. one came in as factory defect the other went well for two weeks then eventually wore off. Sad
As you check the Stick it has two main component, the resisitive plate (two) and other unknown white element (two) just on top of the 4 soldered red and blue wires.
My guess is that the two white components are the defective part/s.
Sad
[quote="Nodular"]Hello,
this is strange.
SURPRISE !!!
Shocked
 Filesize:  29.5 KB
 Viewed:  33660 Time(s)
Nodular
G2 patch files: 7
PostPosted: Mon Nov 25, 2013 6:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Nodular wrote:
SURPRISE !!!
Shocked
Well... this is strange. I'm returning with an odd fact. Gradually, slowly, but relentlessly, my repaired pitch stick, became more and more stable until now that it's working flawlessly every-time I turn up the synth. Shocked
Audio files: 296
PostPosted: Mon Nov 25, 2013 8:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
You didn't give the G2 any booze did you?
Nodular
G2 patch files: 7
PostPosted: Mon Dec 02, 2013 7:18 am    Post subject: Reply with quote  Mark this post and the followings unread
nope Smile
And maybe that's why the mic input is really dead on my G2X. I should have been more indulgent with booze. Rolling Eyes
