by the curb:giant capacitors-great find!! what is it??
Page 1 of 1 [16 Posts]
loss1234
PostPosted: Sun Feb 24, 2008 9:39 am    Post subject: by the curb:giant capacitors-great find!! what is it?? Reply with quote  Mark this post and the followings unread
I found this out in the garbage!! It looks like a super heavy duty power supply.
But what are those rusty parts (batteries?) and is that GIANT blue tube in the bottom a really really big CAPACITOR??
i wonder if it still works..those transformers are BIG~ this thing weighs a ton.
thanks
 Filesize:  770.3 KB
 Viewed:  165 Time(s)
what are these rusted parts?
 Filesize:  842.84 KB
 Viewed:  181 Time(s)
 Filesize:  757.7 KB
 Viewed:  181 Time(s)
gavgomad
PostPosted: Sun Feb 24, 2008 9:56 am    Post subject: Reply with quote  Mark this post and the followings unread
According to this website...
http://www.qie.com/e.html
... it's an Emerson Power Supply. For what sort of beastie, though, your guess is as good as mine! Wink
It looks as though Emerson do power supplies for networking installations....
Gav.
Danno Gee Ray
PostPosted: Sun Feb 24, 2008 10:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Those rusted metal cans look like motor start capacitors.
PostPosted: Sun Feb 24, 2008 10:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Danno Gee Ray wrote:
Those rusted metal cans look loke motor start capacitors.
Maybe they are for power factor correction, would be useful for large power supplies.
Danno Gee Ray
PostPosted: Sun Feb 24, 2008 12:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Excellent. Very educational. Thank you.
RF
Audio files: 28
PostPosted: Sun Feb 24, 2008 4:33 pm    Post subject: Re: by the curb:giant capacitors-great find!! what is it?? Reply with quote  Mark this post and the followings unread
Those rusted ones are "oil filled" capacitors - usually rated for higher voltages and lower capacitances.
The big blue electrolytic one is likely just the opposite - higher capacitance at lower voltages. The values are probably printed on those somewhere.
Rusty oil filled caps - ewe. The thing is 'probably' too new to worry about PCB's in the oil...but they'll leak on you eventually.
bruce
loss1234
PostPosted: Sun Feb 24, 2008 10:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
well i plan on dissecting it for parts and then chucking the rest. there are some big caps on there (47000uf etc) which look good and lots of other useful stuff.
danielwarner
PostPosted: Mon Feb 25, 2008 6:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Be careful with those big capacitors, discharge them before you dissect the thing, use a screwdriver and short the two leads together while you're holding only the plastic handle. Seriously I've heard of people burned from big capacitors before, I don't know the values or at what threshold they become dangerous, I'd just take some precautions.
RF
Audio files: 28
PostPosted: Mon Feb 25, 2008 6:57 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm reminded of a certain "RF" tech who many years ago discharged a very large 700 volt oil filled filter cap through his body.... It felt like someone hit him with a baseball bat - and he hit the wall hard on the other side of the room. Immediately, his high voltage safety proceedures got significantly more rigorous.
Don't ask me how I know about it.
Clack
PostPosted: Mon Feb 25, 2008 7:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Um id be carefull doing that as well, they tend to spark if they are big - I dont know much about it - but you need to put a resistance in the discharging line so its not a massive flow of current all at once. A high watt resistor or somthing
Clacktronics.co.uk
PostPosted: Mon Feb 25, 2008 7:04 am    Post subject: Reply with quote  Mark this post and the followings unread
If you want to use them later, don't use a screwdriver. These big caps don't like being discharged so quickly, and it will seriously shorten their life. (You don't know how much life they have left, so why waste it?) Even just a 1Kor 2K 5W resistor will do the job alot less stressfully. Hold it with a pair of pliers.
RF
Audio files: 28
PostPosted: Mon Feb 25, 2008 7:16 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm sure there must be bleeder resistors on those caps - so unless they have failed (which happens) those caps would be discharged.
Throw a voltmeter on and take a look before you stress too much over the big spark possibility Smile
danielwarner
PostPosted: Mon Feb 25, 2008 7:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Whoops, my "screwdriver short" advice was derived from a guy I know who restores old televisions, radios, etc... I suppose he simply tosses the caps once they've been removed... or houses new caps inside the old ones, I've read about people doing that.
"I'm reminded of a certain "RF" tech who many years ago discharged a very large 700 volt oil filled filter cap through his body.... It felt like someone hit him with a baseball bat - and he hit the wall hard on the other side of the room. Immediately, his high voltage safety proceedures got significantly more rigorous. Don't ask me how I know about it."
Once of my teachers at school has his position because the guy who previously filled his position is dead. He was a licensed electrician, working in a basement somewhere. He had removed the safety ground plug from an electric drill with a metal chassis, for some reason had his neck against a water pipe, and accidentally drilled into the mains. The current went right through his brain stem, well above the "let go" threshold, and the home owner found him dead in the basement several hours later. Shocked
Anything high voltage, high current frightens me, with good reason.
PostPosted: Mon Feb 25, 2008 7:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Nasty! Shocked
I've been bitten a few times by 240VAC.
R_E_S_P_E_C_T........ Smile
RF
Audio files: 28
PostPosted: Mon Feb 25, 2008 7:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Daniel -
I use the screwdriver ALL the time on big caps I "know" to be discharged.
It's solid advice, and my standard procedure as a last assurance the thing is completely flat.
I also strap the terminals on big caps after removing them from service and keep new large caps strapped in storage.
factus10
PostPosted: Mon Feb 25, 2008 10:25 am    Post subject: Reply with quote  Mark this post and the followings unread
I know this'll sound apocryphal, but a friend (really!) used to use the screwdriver method too until one of the caps welded his screwdriver to the terminal.... If you do use a screwdriver, use a decent resistor to limit the rate of discharge.
