seraph
Editor
Audio files: 33
seraph
Editor
Audio files: 33
 Posted: Fri Mar 07, 2008 3:56 pm    Post subject:
btw I've used the G2 coupled with LMSO application for microtonal purposes already. Check this out. _________________ homepage - blog - forum -  youtube
 	  | Quote: | 	 		  | Don't die with your music still in you - Wayne Dyer |
GovernorSilver
  Joined: Apr 26, 2004 Posts: 1349 Location: Washington DC Metro
 Posted: Mon Mar 10, 2008 2:49 pm    Post subject:
 	  | seraph wrote: | 	 		  | btw I've used the G2 coupled with LMSO application for microtonal purposes already. Check this out. |
Nice work!
Are you using LMSO to microtune the G2 via pitch bend?  I still feel kinda flaky for holding off on the Scala converter project. _________________ Current and recent work on Soundcloud
Some old stuff on VIRB |
seraph
Editor
Audio files: 33
 Posted: Mon Mar 10, 2008 4:50 pm    Post subject:
 	  | GovernorSilver wrote: |
Are you using LMSO to microtune the G2 via pitch bend? |
exactly
GovernorSilver
 Posted: Tue Mar 11, 2008 12:54 pm    Post subject:
Grazie, Seraph!
I might end up doing that too.  Learning Python, then refactoring the code to produce only the tuning component (so you're not stuck with electric piano all the time), and implementing .kbm file support is beyond my ability at the moment (lack of time). _________________ Current and recent work on Soundcloud
seraph
Editor
Audio files: 33
 Posted: Tue Mar 11, 2008 2:02 pm    Post subject:
 	  | GovernorSilver wrote: | 	 		  | is beyond my ability at the moment (lack of time). |
it is beyond my ability too. period   _________________ homepage - blog - forum -  youtube
ian-s
Audio files: 42
G2 patch files: 626
 Posted: Tue Mar 11, 2008 2:45 pm    Post subject:
 	  | GovernorSilver wrote: | 	 		  | so you're not stuck with electric piano all the time |
The python code only deals with the modules in the tuning section of the patch, and ignores any other modules. Just delete the dxpiano modules from G2SCL.PCH2 and paste in whatever synth you want for a new template.
You only need to keep the Keyboard1 module, and connect the output of mix1-1A1 to all the oscillators in the new synth.
The bug I though compromised the tuning I  tested just now. I can't perceive any pitch change at all from the fader leakage, even when multiplying the error by 16 and using the full fader range.
How does LMSO get around having pitch bend common to all the voices in a polyphonic patch? Do you need to run a mono version of the patch in all four slots? |
seraph
Editor
Audio files: 33
 Posted: Tue Mar 11, 2008 4:34 pm    Post subject:
 	  | g2ian wrote: | 	 		  | Do you need to run a mono version of the patch in all four slots? |
yes, 4 notes polyphony means 4 monophonic patches each on a different midi channel to be able to retune each one independently. _________________ homepage - blog - forum -  youtube
GovernorSilver
 Posted: Thu Mar 27, 2008 11:51 am    Post subject:
I just wanted to say big respect to both Ian and XJ for their hard work on their respective software.
I still intend to get my LMSO updated and I still intend to learn Python (I'm a Java programmer) and actually contribute something to the G2 tools effort. _________________ Current and recent work on Soundcloud
seraph
Editor
Audio files: 33
 Posted: Thu Mar 27, 2008 12:37 pm    Post subject:
 	  | GovernorSilver wrote: | 	 		  I just wanted to say big respect to both Ian and XJ for their hard work on their respective software.
absolutely   _________________ homepage - blog - forum -  youtube
