yamaha pss-190
Page 1 of 1 [5 Posts]
andrezp
PostPosted: Tue May 13, 2008 7:21 am    Post subject: yamaha pss-190
Subject description: my 2nd bending - sugestions please!
hi folks,
I've just finished my 2nd circuit-bending experience, using an old yamaha pss-190.
Unfortunally this yamaha doesn't have FM chip, so I couldn't use that 270 tutorial someone posted on the yamaha topic (http://www.circuit-bent.net/pss-270-tutorial.html)
Still, I found some nice and noisy bending points, but no pitch resistor. And neither could I control the bending points with pots (I tried almost all of them, from 5k to 1m). Some guy told me that a lot of pcm keyboards need full current to short.
But I found six good bending points, which I turn on/off with toggle switches. These points can make a nice mix and play random noise.
Here's the video: http://www.youtube.com/watch?v=csy5XRvtJTA&e
Now there are these guys waiting to be bent: a casio sa-1, a pense bem multi (a brazilian children computer-toy, very popular on the early 90s) and a furby. Any sugestions?
thanks and sorry for the raw english.
Color TV
www.myspace.com/colortvbr
Alexander
G2 patch files: 4
PostPosted: Thu May 15, 2008 3:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, go for full current bends using triggers: normally-open switches, you can trigger a bend a lot shorter than the time it takes to use a switch!
This results in less crashes.
Combining a trigger like this with a pot, can help you as well! This bend should give you a lot of glitches on the sa-1.
What does pcm have to with variable resistance, just try different resistors, and recheck if you wired the pots correctly, using log pots could be a problem?
Furbies are great, they have a lot of complex circuitry inside them and the eyelids, etcetera are all waiting to be bent! I've seen a lot of 'm and destroyed and old one once, but that was before I knew what circuit bending was!
http://www.circuit-bent.net/furby-bending-tutorial.htm
How about that brazillian computer-toy!? Maybe you could post some pictures and/or sounds, if it's like those v-tech talking teachers, it's great stuff to bent. Very Happy
http://husc-sound.com
andrezp
PostPosted: Fri May 16, 2008 4:21 am    Post subject: Reply with quote  Mark this post and the followings unread
hey alex, thanks for the reply and the suggestions!
actually, I already opened that computer toy and it has some good stuff inside to be bent! here it goes: http://monotonico.files.wordpress.com/2008/05/img-1.jpg
when I finished it I'll post some pics and a video here.
Color TV
xelalien
PostPosted: Fri Jul 25, 2008 11:57 pm    Post subject: Re: yamaha pss-190
colortv wrote:
hi folks,
wow. can you show where the bending points are?
ive been thinking of doin' that to my pss190 Laughing
andrezp
PostPosted: Sat Jul 26, 2008 6:43 am    Post subject: Reply with quote  Mark this post and the followings unread
sorry man, I made that quickly in one afternoon and I didn't mark the bending points Sad
Color TV
