monokinetic
Posted: Wed Jul 23, 2008 2:48 am Post subject:
Lunetta and WSG Mashup Subject description: Any tips on how to cross breed? |
Hi all,
I’m pretty sure this isn’t my first post at EM, but memory fails me at the moment
I’m planning in the distant future a “big” modular using all of the fantastic resources here, but unfortunately I don’t have so much time currently. However, due to the relative simplicity of the Lunetta circuits my interest has been fired again… plus whenever I see Tom Bugs stuff I go all green with envy!
I have been lurking and tried to read up all I can before harassing you all with some questions/ideas:
As mentioned I have been looking at bugbrands amazing modules. It seems that he has two types of sockets, which I presume are split into control/clock signals and audio signals. Is this correct? Is there any risk cross connecting the two types of connector?
I am half way through building a WSG on stripboard (thanks Unkle Krunkus!). I realised that it is based around lots of similar ideas as some of the circuits here on the Lunetta board (which is why I hope this is the right place to ask this…). I’m thinking about patching out some of the elements of the WSG to my front panel to give more possibilities crossing elements with the Lunetta circuits. Do you think this is worthwhile? If so, any tips where to patch out from?
I’m currently planning a minimodular extension to the WSG with Lunetta circuits. After a lot of reading through this forum I think I will start to experiment with the bugbrand 4X Oscillator and XNOR (sound generation) and a basic sequencer from the milkcrate site. Do you think this is enough to get started with? Any suggestions for other simple modules to compliment this basic set up?
Coming from a more traditional modular synth background, I’m not sure how I use the shift registers etc. Could anyone explain how I use these in a patch?
Thanks in advance for any help/comments
Dave mK |
RF
Joined: Mar 23, 2007 Posts: 1502 Location: Northern Minnesota, USA
Audio files: 28
Posted: Wed Jul 23, 2008 5:41 am Post subject:
Hi Dave
I want to encourage you to build up a couple circuits and just 'have at it'.
Yes - Those circuits you mention are enough to get started.
Last night I was playing around with the Bugs 4*osc and 4015 shift register on perfboard with aligator clips - just those two 'modules' are capable of a great variety of odd sound - and apparently quite tolerant. I was cross connecting and mixing audio rate signals and clocking signals and ins and outs with reckless abandon and didn't manage to fry any chips.
It really got crazy when I 'starved' the osc. of power (as mentioned elsewhere in this forum) - it does some really great, unusual things.
This stuff is just fun.
Lots from a completed WSG could be patched in and out if you want to, but after playing with these two chips last night I'm just going to keep at the 'single chip to patch points' concept for my Lunetta.
The shift register creates patterns, divisions, audio and/or clocking signals based on what signals (audio rate/clock rate or both) you input. It's kind of an unruly sequencer. Way cool.
Good luck
bruce |
Pehr
Joined: Aug 14, 2005 Posts: 1307 Location: Björkvik, Sweden
monokinetic
Posted: Wed Jul 23, 2008 8:30 am Post subject:
| RF wrote: | I want to encourage you to build up a couple circuits and just 'have at it'.
Yes - Those circuits you mention are enough to get started. |
Hi bruce,
thanks for the encouragement, I think it's time for a visit to the local electronics shop
Your info on the shift registers clarifies things a bit for me, I shall be bread boarding this weekend!
best
Dave |
monokinetic
Posted: Wed Jul 23, 2008 8:36 am Post subject:
Hi Pehr,
thanks for taking the time to reply...
| Pehr wrote: | The WSG is more or less a lunetta put together ina box, with a filter and no patchpoints. It actually includes a gated and voltage controlled 40106 oscillator (weird osc)  |
aha, that's exactly what I was thinking thanks for confirming this for me, it makes me sure this experiment may be interesting!
| Pehr wrote: |
Good patchpoints are:
WK2A, out
ZA1A, out
leg 1 of R5, out
1M to Odd, in
100kOhm to the base of Q1, in
1N4148 anode to leg 1 of R14, in |
fantastic info, thanks a million! If I come up with anything else I will list it in this thread...
| Pehr wrote: | | I think that the filter could be made voltage controlled somehow... |
Interesting, I hadn't thought of this. Do you think a vactrol would be worth trying here, or were you thinking of adjusting the design itself?
Well, I think the soldering iron will be kept busy for the time being, I'm sure I will be back with more questions
geez this forum is just so inspiring and encouraging! thanks to one and all...
Dave |
Pehr
scriptstyle
Posted: Wed Jul 23, 2008 11:18 am Post subject:
as of right now i have 1/4 not even really finished lunetta:
556 dual osc with cv ins and starve
shift register x2
baby 10 seq
and a 40106 osc project on breadboard
wow dosnt look like much in type? but it sounds awesome!! i also built a wsg and it hasn't been put into a proper case maybe it will become part of my lunetta someday?
i really should get motivated to finish this up!! |
