CGS Power Supply Questions
Page 1 of 1 [18 Posts]
hopelessennui
New postPosted: Sun Jun 29, 2008 2:46 am    Post subject: CGS Power Supply Questions Reply with quote  Mark this post and the followings unread
Hello all!
I had a couple questions about the CGS66 PSU.
When i bought it i thought it i thought it was like the MFOS psu where you just use an AC wall wart adapter, but in the directions Ken talks about using a center tapped transformer. Its a bit over my head. I tried finding a center tapped transformer on mouser and got lost. Can someone point me in the right direction, or even better a link to the right one? Also how would I wire the transformer to the AC mains?
Ken mentions "where possible use a wall wart"
Can i use a wall wart instead?
Thanks a million.
andrewF
New postPosted: Sun Jun 29, 2008 3:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi
sounds like you will be better off with a 18VAC wallwart for now.
from Ken's page -
"it is possible to use a wall-wart between CT (the 0V connection on the PCB) and one 18V AC connection. The required pads are marked with large white circles. The result will be half wave rectification. If you use larger caps (3300uf) and limit the loading, you will be okay."
hopelessennui
New postPosted: Sun Jun 29, 2008 2:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
is half wave retification bad? any idea of how much load it could handle? or how many mA wall wart i should use?
Thanks
otherunicorn
New postPosted: Sun Jun 29, 2008 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Full wave is better than half wave, but that doesn't mean half wave is "bad". You would want a wall wart with at least 700ma. The higher the better. If you can find a 1A or a 1.2A, all the better.
http://www.cgs.synth.net/
Kartoshka
New postPosted: Wed Jul 16, 2008 1:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Another cgs66 question: does those lines (enlightened on the picture) meant to be bridged with piece of wire?
 Filesize:  51.6 KB
 Viewed:  16173 Time(s)
otherunicorn
New postPosted: Thu Jul 17, 2008 6:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes. Those are links.
zthee
New postPosted: Fri Jul 18, 2008 2:18 am    Post subject: Reply with quote  Mark this post and the followings unread
You might wanna flip that capacitor; as it says on the CGS website "The 10uF capacitor beside the -15V pin of the 4 pin MOTM style connector is also shown on the overlay backwards."
I think?
 Filesize:  98.9 KB
 Viewed:  16123 Time(s)
otherunicorn
New postPosted: Fri Jul 18, 2008 5:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think?
And rather annoyingly it is still backwards on the REV1.1 board....
Kartoshka
New postPosted: Sat Jul 19, 2008 5:57 am    Post subject: Reply with quote  Mark this post and the followings unread
true, how could i miss that. thanks guys again.
Tronato
New postPosted: Wed Aug 13, 2008 5:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello!
Ken mentions that he cut a track and I can see that he did. However he also mentions that a link has to be added right next to the cut that is indicated by a black marker line.
Did you add that link?
TRON
otherunicorn
New postPosted: Fri Aug 15, 2008 2:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Tronato wrote:
Hello!
TRON
That is only for the first version.
Tronato
New postPosted: Tue Oct 07, 2008 12:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello!
Any good electronic practice requires protecting your equipment... so where should I install fuses for the CGS66 and which should their value be?
I am feeding it with a 117V/36VAC CT 2 Amp transformer... actually a Stancor P-8672...
Oh... and are the LEDs absolutely necessary?
TRON
andrewF
New postPosted: Tue Oct 07, 2008 4:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
It is important to have a fuse on the 115V side of your transformer, this is for your personal safety. A fast-blow 0.5A should be fine.
Some designs also put fuses on the DC rails at the output of the regulators, others have fuses between the diode bridge and the regulators.
Have a google for images "regulated power supply", you should see lots of examples.
You don't need the leds and 1k resistors, but they don't cost much and will always let you know if the PSU is switched on and operating properly.
Make sure all the 115V wiring is securely clamped down so it can never be pulled loose. Another good safety technique is, once everything is working properly, drown all the 115V solder connections in silastic/sealant goo, so nothing can touch them and it helps hold all the wiring in place.
Tronato
New postPosted: Tue Oct 07, 2008 5:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello!
Thanks AndrewF!
TRON
otherunicorn
New postPosted: Wed Oct 08, 2008 4:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you ever intent to power your supply without a load attached, for testing etc., the LEDs do become necessary. The provide the minimum load needed to make the regulators function.
If you don't want the LEDs, install the resistors, and put jumpers where the LEDs go so the minimum load remains.
Tronato
New postPosted: Sun Oct 12, 2008 2:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello!
So how should the LEDs be installed here?
The PC Board has a small triangle where the LEDs should be insatalled... does the long leg of the LED go in the base of the triangle?
TRON
Luka
New postPosted: Sun Oct 12, 2008 4:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://en.wikipedia.org/wiki/LED
wiki is great for working out simple problems like component orientation
problemchild
melbourne australia
Tronato
New postPosted: Fri Dec 12, 2008 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello!
I am feeding 20VAC into the CGS66 from a supposedly 120/36VAC CT transformer, no load, leds light as expected but after adjusting the trimmers the maximum that is being output is (+/-) 12.75VDC.
Isn't it supposed to be (+/-) 15 VDC at least?
TRON
