schematic: +v pins as CV IN pins on CMOS with SCHEMATIC
Page 1 of 1 [24 Posts]
loss1234
PostPosted: Mon Aug 11, 2008 9:39 am    Post subject: schematic: +v pins as CV IN pins on CMOS with SCHEMATIC Reply with quote  Mark this post and the followings unread
This trick which has been floating around in some of these threads for a bit now (i have seen jnuary and RF both mentioning the successful use of it), and for those who havent seen it or tried it,well i highly recommend it.
after working up a giant mess of breadboard stuff today, , i was trying to plug a cv into an oscillator with having to make a big vco on breadboard, when i remembered the CV to +v trick.
wow. it works great with a 40106 and i am sure it would work with others. to me it doesnt really sound like a starve at all though you do get some weird results (in a good way)
this might not be the direction you want to take for precision BACH concertos but for lunetta stuff, i think it works a lot better than a vactrol on a 40106.
(and easier too)
anyway. i just wanted to make a thread about this so no one would miss it and so maybe we could get some ideas bouncing around about how to add features like offset, hi and low limits, etc. one thing i'd like to be able to do for sure is shift the whole CV signal down an octave or two and i think this can be done with offset but i am never sure.
anyway, thanks to Jnuary who first turned me on to this.
RF
Audio files: 28
PostPosted: Mon Aug 11, 2008 10:07 am    Post subject: Re: using the +v pins as CV IN pins on CMOS chips Reply with quote  Mark this post and the followings unread
loss1234 wrote:
...works a lot better than a vactrol on a 40106.
Dan - What vactrol were you using - and what was your experience with it?
loss1234
PostPosted: Mon Aug 11, 2008 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
lets see i think i tried home rolled ones and also tried a vactec of some kind. my problem was it didnt seem to respond to as wide of a range. that could be my memory serving me wrong but it seemed that if i went up into super high freqs i didnt get much of a reaction (i think i posted once about that even...looking for ways to offset the signal)
anyway, i know it is possible because i even have a schematic i DREW that i used a vactrol to a 40106 but i really think this voltage trick is better for my quick and dirty use.
super simple and effective.
loss1234
PostPosted: Tue Aug 12, 2008 7:10 am    Post subject: Reply with quote  Mark this post and the followings unread
double post
loss1234
PostPosted: Tue Aug 12, 2008 7:10 am    Post subject: schematic Reply with quote  Mark this post and the followings unread
Here is a schematic showing exactly what i now have on my breadboard except The 40106 values are NOT what i have on my board (they are really just shown to show that the 40106's are being used as oscillators of some kind...insert your own values for low hi or ultra hi)
also, take the outs from wherever you wish. (since this R2R only has 6 ins and there are tons of outputs to choose from)
if anyone has any method on choosing which outs to take (is there much difference between out 1 or out 4 on the 4094? arent they just the same but delayed from each other?
i added a range pot to my CV in on the 40106 which helps to go from very low pitch to super high.
anyway, endless noises with this setup. I AM LOOkING FOR any ADVICE On how to integrate more stuff (4051,etc)
thanks
EDIT: schematic fixed (opamp pins)
ENDLESS NOISE FIXED.pdf
great cv source for weirdness if you just take the out of the opamp and plug it into a vco.
 Filename:  ENDLESS NOISE FIXED.pdf
 Filesize:  48.46 KB
 Downloaded:  1044 Time(s)
fluxmonkey
PostPosted: Tue Aug 12, 2008 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
wow, that looks a lot more involved/refined than what i tried.
i had several oscillators built on a single 40106 chip (outputs mixed together thru resistors). on the same breadboard, i also had a 4093 wired as 4 oscillators, each one gating the next... pretty large cap values, so it was slow. then i just disconnected the power from pin 14 of the 40106, and fed the output of the last 4093 oscillator into the 40106 power pin. instant freq out!
not sure i'd call it CV or "modulation", more like brute force, but a very cool trick.
bbob
www.fluxmonkey.com
loss1234
PostPosted: Tue Aug 12, 2008 12:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
keep in mind if you dont want to go for the brute force method (i like that) then you could JUST as easily stick the output of the R2R into an external vco. or you could put it into a vco AND A comparator to wrestle some gate signals out of it to put into a vca or A/R gen.
CJ Miller
PostPosted: Sat Aug 16, 2008 11:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Another option is to use a 4024 or LM3900 as a pulse-counter, so that the voltage ramps up for each pulse it receives. Adjust how many pulses and you could have some sort of rhythmic modulation.
loss1234
PostPosted: Sun Aug 17, 2008 6:21 am    Post subject: Reply with quote  Mark this post and the followings unread
can you explain that a little more?
i dont think i have ever used a pulse counter.
thanks
loss1234
PostPosted: Wed Aug 20, 2008 12:45 am    Post subject: Reply with quote  Mark this post and the followings unread
ERROR
bugs spotted a crucial error in my schematic.
the pins on the opamp are reversed (+ and -)
thanks
CJ Miller
PostPosted: Sat Aug 23, 2008 11:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
A pulse counter is a circuit which outputs a voltage, this voltage level depends upon how many pulses are counted. A typical application might be a chip putting out zero volts with a zero count. It could count up to, for instance, 24 pulses. So for a +12V supply would mean that for each pulse input, the output increases by 0.5V. At the 24th pulse it would have ramped up to 12V and reset to zero.
This is another percussion application I learned from Thomas Henry, via his "Electronic Drum Cookbook". He calls it a "Beat Follower", his counts from 0 to 127. I played with it on breadboard once long ago, and have meant to make some more versions of such for some time. Also I was reading about this in some LM3900 application notes, along with the other hundreds of things those chips can be used for.
jnuaury
Audio files: 9
PostPosted: Sun Aug 24, 2008 1:48 am    Post subject: Reply with quote  Mark this post and the followings unread
ive been away from the internet for most of this month!
cant believe this i missed this thread...
would you mind pointing me towards RFs post on this? i dont think i searched for the right keywords
this technique has been one of my favorite things to do since i started fiddling with electronics but i could never find any projects people have done with it (there HAS to be somebody who did this back a couple decades ago....)
using an op amp to add an offset has been something that although makes things more "proper" ive found makes things maybe more complicatedly than it needs to be
i like how mystical the circuit seems when you dont need that extra power cable... of course this perspective has nothing to do with practicality
i also hardly use frequency pots for oscillators on the 40106 when using the power input as CV method - theres so much variation you can get by altering the voltage that i like fixing the values of the oscillators and adding a pot to adjust the current of the incoming voltage and sometimes a second pot wired as a voltage divider
i havent found the perfect values yet but i like using three inverters at audio rates wired to one output and three at subaudio to another so i can derive funny audio or a more complex CV from any CV source
one pot and three jacks is a panel friendly layout than having 6 frequency knobs thrown in i guess it all depends on whether the voltage input is a extra feature or the main function....
loss1234
PostPosted: Sun Aug 24, 2008 6:04 am    Post subject: Reply with quote  Mark this post and the followings unread
well let me explain how i am using it.
i think in my situation, the more pots the better, because it is now becoming almost a CV BRAIN/sequencer/PSUEDO RANDOM DEVICE.
LET ME EXPLAIN:
first of all, on my model, the opamp pins 2 and 3 are flipped. so i took the output from the opamp and i sent it to a breadboard that has
1. the 2nd 40106 which is about to be controlled VIA CV.
2 BUt i also took another output from the CV/power area (the same junction that goes into pin 14 of the final cmos chip. here i simple put a jack
3. This means that i have a lot more options for controlling my modular.
a. i can take the 40106 output and use it TO FM MODULATE things. or i can use it as an audio source, or to modulate the Filter at audio frequencies, or just as a CV source wherever. and with all the pots on the panel, you can easily turn the module into a sub audio monster or a screeching random note high frequency bomb! it really makes me feel like i can play it like an instrument.
also, the non audio output, the straight CV output, can obviously be used to control a VCO, or can be fed into a comparator to get gates out of it, or can be used with, well, any thing.
I also added some switches that (monetary switches) interrupt the 4094, flip the resets High on the 4015, and select 2 different data or clock ins on the 4015 or 4094. and when you start getting those buttons going, wow...the infinite weirdness just keeps going and going..
i must say this is now my FAVORITE control modular. if hooked up to mults and done right, i have been able to get stuff that sounds like a sequencer or others that sound like appregiators, or trills, or crazy stuff!
the key is feeding the two outputs to different places, and really getting creative with how the modulation comes into play.
IF i do a pcb of this, i would also like to add some CV INS onto the board
nothing fancy, just maybe some vactrol control of the clocks and maybe a 4016 to give cv control of turning the resets on and off, etc.
i will post a sample later!!!
thanks to the LUNETTA FORUM for getting these ideas flowing
jnuaury
Audio files: 9
PostPosted: Sun Aug 24, 2008 6:27 am    Post subject: Reply with quote  Mark this post and the followings unread
i hope you didnt think i viewed your circuit as invalid!
i just like making the simplest circuit i can and then complicating them later via patchcords Cool
looking forward to your samples
loss1234
PostPosted: Sun Aug 24, 2008 7:07 am    Post subject: Reply with quote  Mark this post and the followings unread
nah
dont sweat it!
i think its great for people to see that you can build these projects in different ways according to your needs!!
thanks again
jnuaury
Audio files: 9
PostPosted: Mon Aug 25, 2008 2:50 am    Post subject: Reply with quote  Mark this post and the followings unread
mp3 demonstrations are coming soon!
i recorded a few 30 secondish clips but im having trouble uploading them...
hopefully computers/internets will wise up by the end of tonight
loss1234
PostPosted: Mon Aug 25, 2008 8:59 am    Post subject: MP3's!!!! Reply with quote  Mark this post and the followings unread
hmmm
having trouble uploading mp3s
hope i am not out of space
is something wrong with server?
Audio files: 297
PostPosted: Mon Aug 25, 2008 9:42 am    Post subject: Re: MP3's!!!! Reply with quote  Mark this post and the followings unread
Yes, uploads seem to not work currently.
loss1234
PostPosted: Mon Aug 25, 2008 11:18 am    Post subject: Reply with quote  Mark this post and the followings unread
hmmm
well as soon as they are back online i have some great new samples! this endless noise is nuts.
Audio files: 297
PostPosted: Mon Aug 25, 2008 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
It should work again, so let's hear 'm!
jnuaury
Audio files: 9
PostPosted: Mon Aug 25, 2008 1:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
as promised...
this is a one chip circuit using a 4093
the clips werent made to sound musical or cool but just provide simple interaction between a CV source and the chip
two are just a stepped random voltage (always between 0 and 5 volts) powering the 4093 once without a "starve" pot and once with it adding resistance (no knob tweaking)
the other one uses an audio source (sine wave vco) for the power input causing the 4093 to act as a waveshaper i set the starve pot so it would mangle the sine wave but let you still identify the "notes" playing (which are of course random) at the beginning of the clip the rate of the random notes is slow and then later i turn the rate knob up a bit and then lighten up on the starve effect near the end
lunettaSH.mp3
stepped random voltages
 Filename:  lunettaSH.mp3
 Filesize:  655.95 KB
 Downloaded:  1263 Time(s)
lunettaSHstrv.mp3
stepped random voltages and a pot used to starve the current from the CV to the chip
 Filename:  lunettaSHstrv.mp3
 Filesize:  721.46 KB
 Downloaded:  1271 Time(s)
lunettarandosine.mp3
sine wave vco playing random notes plugged into power input
 Filename:  lunettarandosine.mp3
 Filesize:  938.81 KB
 Downloaded:  1313 Time(s)
loss1234
PostPosted: Mon Aug 25, 2008 3:53 pm    Post subject: samples Reply with quote  Mark this post and the followings unread
Ok
these samples are either of the my ENDLESS NOISE schematic with ONLY the output of the +V cved 40106 as the audio OR my modular being controlled by both the CV OUT jack AND the +v CVED 40106 audio out at the same time.
some of the clips experimented with having the audio from the 40106 AND the audio from the CVED vco go through an XOR
or some other combos i cant remember.
i got some great interactions though. i want to add more reset, reload, and input change toggles (not on schematic) to this.
plus v cv 40106 1.mp3
 Filename:  plus v cv 40106 1.mp3
 Filesize:  955.37 KB
 Downloaded:  1317 Time(s)
plus v cv 40106 2.mp3
 Filename:  plus v cv 40106 2.mp3
 Filesize:  563.09 KB
 Downloaded:  1342 Time(s)
plus v cv 40106 3.mp3
 Filename:  plus v cv 40106 3.mp3
 Filesize:  730.7 KB
 Downloaded:  1245 Time(s)
plus v cv 40106 4.mp3
 Filename:  plus v cv 40106 4.mp3
 Filesize:  346.22 KB
 Downloaded:  1363 Time(s)
final duet modular and endl.mp3
 Filename:  final duet modular and endl.mp3
 Filesize:  2 MB
 Downloaded:  1324 Time(s)
loss1234
PostPosted: Mon Aug 25, 2008 3:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
and a few more
cv1.mp3
 Filename:  cv1.mp3
 Filesize:  738.18 KB
 Downloaded:  1295 Time(s)
cv2.mp3
 Filename:  cv2.mp3
 Filesize:  1.08 MB
 Downloaded:  1304 Time(s)
RF
Audio files: 28
PostPosted: Mon Aug 25, 2008 7:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey guys - those are all inspiring samples!
Thanks for posting them - I gotta get back to working with mine!
bruce
