 Forum index » Instruments and Equipment » OSX as a music workstation
Pro Tools LE 7.4/MBox 2 Pro Trouble
Page 1 of 1 [3 Posts]
JoeLouis
PostPosted: Wed Aug 27, 2008 6:00 pm    Post subject: Pro Tools LE 7.4/MBox 2 Pro Trouble
Subject description: Pro Tools LE 7.4/MBox 2 Pro don't run
Hi everyone,
I'm trying to work with Pro Tools LE 7.4/MBox 2 Pro, but as soon I hit Play, the following Warning appears: " A CPU overloaded occurred. If this happens often, try increasing the H/W Buffer Size in the Playback Engine Dialog, or removing some plug-ins"
Since I've tried with a Session that have just 1 Track (Click), no audio, no Midi, no plug-ins, I don't understand how a CPU overloaded could happen.
A similar situation happened to me with Digital Perfomer 6 and the MBox (I'm using MAS with the MBox selected as Audio Hardware). Could it be because there's a problem with the MBox or the PT LE software?
I'll appreciate any HELP!!!
Thanx
2.3 GHz dual Mac G5 - 2 GB RAM - OSX 10.4.11
BobTheDog
PostPosted: Sun Aug 31, 2008 8:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Are you on a LapTop?
Andy
EDIT: No your not I just saw your signature, mmmmm.
spacetimegod
PostPosted: Fri Sep 05, 2008 5:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Try increaseing the buffer size in the Play Back Enginge Dialouge.
Pro-tools can be tricky to set up at first. After you get good with it you will relize that it is full of bugs, All of which have ways of being worked with. Make sure your computer has enough RAM as well. Might need to upgrade your ram if you encounter this in other programs.
Never Mind. Probably not your ram. Just go in and tweak some settings. Watch the video that came with your set up. I know you got one.
