<on air> Various Artists September equinox Concert
5-channel Attenuverting Mixer 2nd run
Page 3 of 9 [214 Posts]
PostPosted: Mon Aug 25, 2008 8:09 am    Post subject: Reply with quote  Mark this post and the followings unread
a.b.o.z. wrote:
fonik wrote:
sent out the first batch today. i don't have the time to PM everyone today. nevertheless everyone whos PCBs have been sent will receive a PM this weekend...
didn't get that PM. hmmm
I've sent payment. Did you get it?
Or you didn't had time to send PMs.
my fault. you are right, i did not have the time, yet, which is not what i wanted...
Peake
PostPosted: Mon Aug 25, 2008 9:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you very much!! Your time and effort are appreciated!
a.b.o.z.
G2 patch files: 4
PostPosted: Mon Aug 25, 2008 11:21 am    Post subject: Reply with quote  Mark this post and the followings unread
hei no problemo at all.
thxn
Danno Gee Ray
PostPosted: Tue Aug 26, 2008 9:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Received my two boards today. They look great!
Thanks Mathias.
numbertalk
PostPosted: Tue Aug 26, 2008 2:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Got mine too - thanks!!!
a_guy_called_tom
PostPosted: Wed Aug 27, 2008 9:10 am    Post subject: Reply with quote  Mark this post and the followings unread
mine arrived too, they look great. Thanks alot!
a.b.o.z.
G2 patch files: 4
PostPosted: Thu Aug 28, 2008 10:00 am    Post subject: Reply with quote  Mark this post and the followings unread
got mine today.
great!!
thnx M.
ericcoleridge
PostPosted: Thu Aug 28, 2008 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
I also got mine today. Beautiful job. Very Happy
Peake
PostPosted: Thu Aug 28, 2008 5:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Received! Thank you very much! Very Happy
Edit: I don't see any 1% resistors indicated in the documetation. I'll thus take it that there are none required or recommended? That the trimpots negate the need? Thanks!
rjd2
PostPosted: Fri Aug 29, 2008 12:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
so ive got a question here, sorry to be daft about this, but need to confirm something...
do the individual input pots work like this: hard R=full gain, hard L=full gain inverted, 12 oclock=0 gain?
it just popped into my head that if i am reading this right, this would be a hugely utilitarian module for me down the line. if so, are there any spare boards available? thanks.
PostPosted: Fri Aug 29, 2008 12:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
you are absolutely right. BTW i am always using 1% resistors since they are not much more expensive at the store i buy them...
PostPosted: Fri Aug 29, 2008 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
correct. the trimmers are needed to calibrate the 0V at 12 o'clock (potentiometers usualy have tolerances about 10-20%)
there are still PCBs left.
just tell me how many you need.
rjd2
PostPosted: Fri Aug 29, 2008 7:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
question on caps-any of the values should be film or polystyrene or anything? im planning on using these as VCO summers, among other uses.
crashlander42
PostPosted: Sat Aug 30, 2008 2:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Got my boards today! They look great!
When they plug me in the lights go down in Hong Kong.
My DIY stuff Flickr
PostPosted: Sat Aug 30, 2008 3:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
there are no capacitors in the audiopath. using poly for decoupling is a good choice, i think.
Fungitec
PostPosted: Mon Sep 08, 2008 1:45 pm    Post subject: Still boards available...? Reply with quote  Mark this post and the followings unread
Is there by any chance boards left here Fonik? If thats the case, I would like a pair of them. Please sign me up for two if you still got any spares... plz. Smile Thanx
/thure
PostPosted: Mon Sep 08, 2008 10:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
still some boards left. check PM.
loopcycle
PostPosted: Wed Sep 17, 2008 7:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
received my boards. beautiful work! thanks for this.
Peake
PostPosted: Tue Sep 23, 2008 2:39 am    Post subject: Reply with quote  Mark this post and the followings unread
I've got a board up and running- great stuff! My first intent is to use it to substitute for a power supply for the Moog Modules, until I get one built: 12V, -6V, and -10V rails are required (the classic power supply does not regulate the -10V). For some reason, I was only getting 1V at the internal/jack normal'd source, so I jumpered R29 to pass the full 15V to the pots. Presto, just set the pots to the desired voltages. I don't know if this will work in powering the modules yet, but it's fun to play with Smile
Thanks a bunch for the second run!!
loss1234
PostPosted: Tue Sep 23, 2008 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
does anyone think i could get away with using SINGLE TURN 50k trimmers?
i really want to get this built (mainly as an audio mixer) and i have tons of single turn trimmers but NO 50k multi turn.
thanks
PostPosted: Tue Sep 23, 2008 8:26 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks
actually you could get away without a trimmer and a fixed resistor instead. the trimmer is just to calibrate the processing potentiometer to OV at 12 o'clock.
PostPosted: Tue Sep 23, 2008 8:31 am    Post subject: Reply with quote  Mark this post and the followings unread
try a single turn trimmer. you could get set it with patience and a tranquil approach...
LektroiD
PostPosted: Tue Sep 23, 2008 9:53 am    Post subject: Reply with quote  Mark this post and the followings unread
can I take one please? Wink
PostPosted: Tue Sep 23, 2008 1:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
sure, check PMs.
LektroiD
PostPosted: Wed Oct 01, 2008 12:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Oops... should I remove and change these?
 Filesize:  103.51 KB
 Viewed:  279 Time(s)
