 Forum index » Instruments and Equipment » MIDI Controllers and Interfaces
Hardware midi processor/converter
Page 1 of 1 [9 Posts]
torsig1967
PostPosted: Wed Sep 17, 2008 6:59 am    Post subject: Hardware midi processor/converter
Subject description: Are there any of these around?
I'm wondering if there are any hardware midi processors/converters around anymore.
I believe Philip Rees made things like that in the past but I haven't got a clue if anyone is making stuff like this anymore.
I'd like to do these conversions:
1. modulation wheel (midi cc: 1) to channel pressure
2. some other cc to pitch bend (with low resolution I know)
3. Filter out note on/off on a specific channel
But I don't want to carry a whole computer for this task.
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Sep 17, 2008 7:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't have time to check out the specifics, but maybe this would do the trick:
http://www.midisolutions.com/prodevp.htm
BobTheDog
Audio files: 32
PostPosted: Wed Sep 17, 2008 10:01 am    Post subject: Reply with quote  Mark this post and the followings unread
I looked at this before, it is a pretty neat device.
There is an expanded one as well http://www.midisolutions.com/prodepp.htm which has a bit more ram.
Andy
torsig1967
PostPosted: Wed Sep 17, 2008 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great, just what I was looking for.
I believe it's gonna work fine to program even though I have a Mac. Since programming the interface can be done off-line, I can use any PC.
seraph
Editor
Editor
Audio files: 33
PostPosted: Wed Sep 17, 2008 2:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
in the 80's I used to have a Yamaha MEP4 (it had 4 midi event processors). Only programmable in Hex Exclamation Geeky stuff Cool
I don't know if you can still find one.
grantb3
PostPosted: Fri Jul 31, 2009 4:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
I still have my MEP4 and would recommend it if you can find one. It's a bear to use, but if your requirements are reasonably simple then it's not too bad. I mostly just use it as a MIDI monitor these days.
davebr
PostPosted: Sun Oct 25, 2009 1:16 pm    Post subject: Re: Hardware midi processor/converter
I ended up making my own. I use it to filter real time messages and to map specific controllers. Everything is public domain and posted on my site http://modularsynthesis.com/processor/processor.htm
A side benefit is it powers off the MIDI. This does reduce margin but it seems to work OK.
grantb3
PostPosted: Mon Oct 26, 2009 8:15 am    Post subject: Reply with quote  Mark this post and the followings unread
I was going to mention earlier that the DMC MX-8 would probably do some of what you are looking for too. Like the MEP-4 it's a 1U rack device.
Good work "davebr" and nice tools! What software did you use for the schematic & pcb?
davebr
PostPosted: Mon Oct 26, 2009 9:56 am    Post subject: Hardware midi processor/converter Reply with quote  Mark this post and the followings unread
It's ExpressPCB. They provide free tools that only work with their service. That is a mini-board which is a standard size and 3 quicks for $51. It makes for a reasonable small-board option. That was probably my second board. It's easy to learn. It includes the schematic capture so that's what I use as well.
