loss1234
wmonk
Joined: Sep 15, 2008 Posts: 529 Location: Enschede, the Netherlands
Audio files: 15
Posted: Mon Sep 15, 2008 7:02 am Post subject:
Hi!
I'm following this forum for about half a year or so, but didn't post yet.
You can divide by 12 with de 4040 (which is 12 bit ripple counter)
Same for 14 (4020) and the 4060, which is a 14 bit ripple counter with internal oscillator.
Woody |
richardc64
Audio files: 26
Posted: Mon Sep 15, 2008 10:13 am Post subject:
Um...a 12 stage ripple counter doesn't divided by 12, it divides by 2 twelve times: 4096. _________________ Revenge is a dish best served with a fork... to the eye |
Joined: Apr 03, 2004 Posts: 24587 Location: The Netherlands, Enschede
Audio files: 309
Posted: Mon Sep 15, 2008 11:26 am Post subject:
| richardc64 wrote: | | It's quite OK to make music with tea spoons and rubber bands! |
Uh oh
Re. the Q.
I had a quick browse for an equivalent in CMOS but nothing showed up ... you can use two dividers though, one set to divide by three and another to divide by four. The 4017 would be suitable, you'd need two. For the 4017 you simply connect one of the outputs to its reset input, the output selected determines the division.
Other options would be the 4018 but that needs a bit of extra logic to make it divide by three. Or the 40103 could be used as well, for that one you set up a count on the jam inputs but it looks like it might need some logic to make it work properly. _________________ Jan
robthefiddler
Mikmo
Joined: Dec 01, 2005 Posts: 150 Location: Copenhagen - Denmark
JovianPyx
Audio files: 224
Posted: Thu Oct 30, 2008 9:38 am Post subject:
Does anyone know if the above 4027 divide by 3 circuit produces a 50% duty cycle output?
Also, in the divide by 3 counter diagram, there is an error. Pin 2 is shown as Q, but it should be Q-bar since it is an inverted output. _________________ FPGA, dsPIC and Fatman Synth Stuff
Posted: Thu Oct 30, 2008 2:02 pm Post subject:
| ScottG wrote: | | Does anyone know if the above 4027 divide by 3 circuit produces a 50% duty cycle output? |
I haven't really checked it out, but I would propose that it would be impossible to divide by 3 using flip-flops and get a 50% duty cycle.
It will divide by 3 by counting to 3, so you could get 33% or 66% only. _________________ What makes a space ours, is what we put there, and what we do there. |
JovianPyx
Audio files: 224
Posted: Thu Oct 30, 2008 2:22 pm Post subject:
Now that you say that, it is impossible because the clocks to both flipflops are the same so the circuit cannot react except on one edge. I designed a 50% duty cycle divide by 3, but I manipulate the clock to one flop with logic to make that happen. My circuit uses 2 JK flops and an NOR gate. _________________ FPGA, dsPIC and Fatman Synth Stuff
urbanscallywag
Posted: Fri Oct 31, 2008 4:07 pm Post subject:
Great find Scallywag!  _________________ What makes a space ours, is what we put there, and what we do there. |
urbanscallywag
Posted: Fri Oct 31, 2008 4:47 pm Post subject:
Thanks. I was looking into odd clock division for top octave dividers and remembered seeing divide by 3 with 50% duty cycle. The original application note I found might have been for programmable logic.  |
Mikmo
Posted: Mon Nov 03, 2008 4:14 am Post subject:
I just checked the Mims book that the schematics in my previuos post comes from, and it does not mention anything about the duty cycle. _________________ Stay Cool
Mikael
http://www.mikmo.dk |
