DIY Top Octave Generator
Page 1 of 3 [58 Posts]
Goto page: 1, 2, 3 Next
Scott Stites
Audio files: 96
PostPosted: Sat Oct 04, 2008 7:30 am    Post subject: DIY Top Octave Generator
Subject description: Can we build one?
Another thing that I think would sell, but it totally beyond my ability, but might be easy for other members to implement (I don't know):
A TOG (Top Octave Generator) board/IC. I would think there would be a way to do it with one of them there programmable ICs. That whole area of synthesizers has just DIED along with the disappearence of the TOG IC. It would reintroduce something to Synth DIY that is practically unobtainium these days.
It seems to me organ repair centers do sort of the same thing, but they do it in the price range of the valued limb/first born.
Nothing fancy, just something that divides down to a high octave of twelve steps. Either a programmed IC, or a little board for it. I think that'd sell once people realized what they could do with it (for one thing, use JH's Solina thing to make a nice little string machine). Paraphonic would be back, baby, and that would be a good thing (IMO).
My Site
PostPosted: Sat Oct 04, 2008 3:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great ideas Scott,
Although I'm very slow with actually getting around to doing anything, both of these ideas have featured in my head soup over the last year or so. Well,... in a round about kind of way.
The first one sounds like a distant cousin of the Graphic ENV generator I told you about. (For everyone else, it's a collection of vertical sliders which are ganged together to form a custom ENV of however many stages you like)
The second one is related to the discussions Loss1234 and I have had about deriving chromatic tones by multiplying up and dividing down by various integer values. It's obvious to me now, both from what Scott just said, and Ian's new wavetable VCO, that just simply starting from a VHF signal and dividing down is the way to go. Of course, I'd prefer to implement it in common CMOS chips rather than a PIC. I just like them better. They take up more space, but present a lot less hard work IMHO.
I think I'll get a spreadsheet happening today!
Scott Stites
Audio files: 96
PostPosted: Sat Oct 04, 2008 6:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
You're preaching to the choir about CMOS Laughing
However, this is one of those cases where you'd have one hell of a huge board just to get the frequencies you wanted (there's a lot of dividing going on, and I'm not all that convinced multiplying signals is the best way to go).
You'd want something that started an octave or two above hearing, then divide down from that. That would be plenty of CMOS to wrap your iron around if you think about it. The waves would be pulse waves, but you could think about constructing sawtooths out of those waves as they divide down. Methinks some of the TOG synths did just that, with low notes being rich in sawtooth, and becoming more pulse-like as the frequency went up (because there were fewer pulse waves available to construct the harmonics for the sawtooth).
Another way to go about it, without TOG, would be to make standard boards that divided a specific, divided down note range. JH did this with his PS3XXX clone, IIRC. That would be a good selling point in a way - you would need twelve of them to construct a paraphonic synth.
I'd kill for freely available TOGs, though.
Cheerios,
Scott
My Site
PostPosted: Sat Oct 04, 2008 7:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Depends upon the scale you want, for a pythagorean scale it could make sense actually. You'd use rate multipliers for the multiplication then, which actually is division Laughing Any other scale would be horror with multipliers I think to figure out a good approximation ...
Using a processor to do it is not entirely trivial either, it better be a fast one, but having that you could make many scales which would be interesting as well and ... impossible ... with CMOS. The division itself in CMOS for one scale might be doable, but it's pretty large numbers you'll want to divide by, so it will be some of board space indeed.
Scott Stites
Audio files: 96
PostPosted: Sat Oct 04, 2008 8:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was thinking about the scale that fits on the white and black keys Laughing
I do have an old copy of Polyphony that covers even temperment using CMOS following a TOG, and that portion of it isn't tiny. Multiplication with CMOS can be tricky in certain instances, but if you have something to divide down, it wouldn't be an issue.
I was hoping FPGA's had come far enough? Division beyond that could be done with standard CMOS - a lot, but not an awful lot. You'd need to divide down six to eight times per note in a scale. The right counters would help to keep the parts count low.
My Site
PostPosted: Sat Oct 04, 2008 9:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
You'd need a separate set of counters for each note yeah?
So, say you start with 14080Hz, you get top A for free.
Don't you just use a couple of 8 bit counters for each note? Set a certain number through diodes to reset. And take the signal off whatever MSBs you like the sound of yeah? 2^14 is 16384, so you only need a 14 bit counter each. That's an 8 plus a couple to make up.
Have I missed something?
Scott Stites
Audio files: 96
PostPosted: Sat Oct 04, 2008 10:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Resolution. A TOG starts off at a very high frequency (in the MHz range) and divides down from that, because it's difficult (impossible) to divide to within a few cents of what you actually need without doing so. Each note is 1.059 times the frequency of the next lower note, which takes a lot of horsepower. No TOG actually divides to the exact amount, but gets close enough for horseshoes. And that's starting from RF land...
My Site
PostPosted: Sat Oct 04, 2008 10:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here are the frequencies down from a high A: -
A - 14080.0000
G# - 13289.7503
G - 12543.8540
F# - 11839.8215
F - 11175.3034
E - 10548.0818
Eb - 9956.0635
D - 9397.2726
C# - 8869.8442
C - 8372.0181
B - 7902.1328
Bb - 7458.6202
A - 7040.0000
If, for example, we reset at 13289, that's G accurate to 5 decimal places! That's a lot closer than horseshoes. How much more accurate should it be?
Most tuners don't go to 1/100th of a cent.
BTW I think we should split this off from the EM-PCB thread. Can I do that?
PostPosted: Sat Oct 04, 2008 11:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just checked the numbers, and if you bite the bullet and go for 2*8bit counters per note, then your division power goes up to 65536.
So, to make the most of it, take it all up by two octaves and two semitones to the B at 63217Hz.
But,....
I just checked, and we have a 14bit counter in the CD4020! So, if we stick with the "just inside audible" top note of B at 15804Hz, we've got the top octave from just 11 chips! and a shitload of diodes!! Rolling Eyes
Come on Scott!? This could be fun! Laughing
Scott Stites
Audio files: 96
PostPosted: Sun Oct 05, 2008 12:16 am    Post subject: Reply with quote  Mark this post and the followings unread
It's late here so i may not be thinking the clearest right now, but reset at 13289? Wouldn't you be dividing 14080 by 13289 if you did that?
Wouldn't you want to reset every time the 14080 frequency counted 1.0595 steps or something along those lines?
My Site
PostPosted: Sun Oct 05, 2008 2:00 am    Post subject: Reply with quote  Mark this post and the followings unread
No, actually you're right. Embarassed
I've just completely mixed up what the hell I was trying to work out!
Sometimes my brain just doesn't work as well as it used to.
Maybe it's the drugs! Shocked Laughing
What I was thinking is completely wrong. So utterly wrong I should wipe these posts! And, worse than that, it shows that I have absolutely no idea what the problem actually is. Still don't.
New postPosted: Sun Oct 05, 2008 2:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Okay,
I think my brain fart has subsided.
Next question, what's the highest frequency you can clock a 4020 with?
I'll see if I can find out for myself, but at least you know I'm thinking about it the other way up now. Laughing
New postPosted: Sun Oct 05, 2008 5:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Not chop it off to a public place then?
3.5 MHz @ 5V upto 12 MHz at 15 V.
Scott Stites
Audio files: 96
New postPosted: Sun Oct 05, 2008 6:58 am    Post subject: Reply with quote  Mark this post and the followings unread
If I had a nickel for every time my brain farted, I'd own this board. Laughing
Anyway, now you're thinking. This is why I still wonder if an FPGA didn't have enough gates to crunch out the hard divisions. If not, I think you could with a fist-full of counters. It would be a board that replaced an IC, but, hell, you can't get the ICs any more, so.....
 Filesize:  40.14 KB
 Viewed:  12722 Time(s)
My Site
New postPosted: Sun Oct 05, 2008 2:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah,.... Chop it!
New postPosted: Sun Oct 05, 2008 3:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
I had such a brain turn around last night, that I set up a dynamic spreadsheet and I was actually very close to finding these numbers!
Now that you've gone and spoilt my fun, I'm gonna make it my mission to find the 10bit set!
But first I think we should settle on a chip! The way I see it, we're gonna have a counter per note, so why not go to 14bit and use the 4020? I'll tell you why not!
8bit to audible means starting around 2Mhz
14bit to audible means starting around 128Mhz!! Shocked
But 10bit to audible could start around 8Mhz Wink
As Jan pointed out, (and I confirmed BTW) 8Mhz is okay if we're up around 15V. But can we control tuning at that frequency? Could we have a pre-count tuning mechanism which simply wasted clock cycles? I'll do some more number crunching.
New postPosted: Sun Oct 05, 2008 6:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, I feel guilty now... I've been using 2Ghz and 64bit floats... and using it to tune to integer multiples of 200Hz... and really liking that scale. Sorry. :¬)
New postPosted: Mon Oct 06, 2008 4:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Integer multiples of 200 Hz sound good because it tunes well with the mains hum I guess ... and 440 Hz is obviously a mistake ... or is 50 Hz the mistake ...
New postPosted: Mon Oct 06, 2008 5:12 am    Post subject: Reply with quote  Mark this post and the followings unread
I reckon they should split the difference and change to a standard of 55hz which wouldn't hurt much existing equipment, and is 3 octaves below A @ 440. Then we might finally "teach the world to sing, in perfect harmony! Grow apple trees, and honey bees, and la la la la la,........" Laughing
BTW Can you still chop this off Jan? From the bit about TOGs onwards. Maybe put Mosc's on topic post back afterwards. Oh, and I'll have a coffee too while you're at it, and are there any chocolate biscuits? Very Happy
New postPosted: Tue Oct 07, 2008 3:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Scott,
what ideas have you got about the master clock?
Is there an easy way to hook up an 2, 4, or 8Mhz crystal to a chip and get a nice clean clock out? Could you tweak the frequency on a crytal based clock generator like that?
Does the first note out of a TOG have to be any one in particular?
I was thinking about the 40103. Using a programable down counter such as that would simplify the board heaps as you wouldn't need to do external testing with diodes and/or gates.
I can't see how to up the bit count to 9 or maybe 10 without using external testing, which will mean gates, and diodes, and a lot more complicated layout. Unless we can find a 10bit programmable counter, or make the 40103 act like one?
Maybe it is the perfect place to go for the simplicity of 8bit for this reason, but I was kind of thinking that if we go to the hassle of making a DIY TOG, then we should make it better than the obsolete ones. What do you think?
I'm still working on finding the "magic" 10bit dividers. Maybe they don't exist, and then going up to 10bit would be a waste of time. Confused
I'll attach the spreadsheet I've been using, maybe you'll get inspired. Very Happy
Note Ratios TOG.xls
 Filename:  Note Ratios TOG.xls
 Filesize:  62.5 KB
 Downloaded:  262 Time(s)
Rykhaard
New postPosted: Tue Oct 07, 2008 7:23 am    Post subject: Reply with quote  Mark this post and the followings unread
This might seem quite silly but a year or more ago, in my investigations towards building my own string machine, I played with generating squarewaves from the simple but useful CD40106. Smile
It were stable! I'd set one up with 2 or 3 individual oscillators at different frequencies and they held their frequencies over a few hours, with no troubles at all.
1 x CD40106 = 6 different frequencies? That'd only be 2 of them for an octave. ??? Smile
For divide down - have your entire top octave done with 2 x CD40106's and then divide by 2 for each note of each octave below / etc.
No? Smile (What's wrong with this thought line of mine. I'm not awake enough yet, to figure any problem out. Surprised Smile )
EDIT: A few minutes after having typed this and I remember that out in the garage, I have the Farfisa VIP 400 that I still have to bring in to the studio - give it it's missing fuse and fuse holder and there's my 'string machine'. Doh. Surprised Wink Laughing
richardc64
Audio files: 26
New postPosted: Tue Oct 07, 2008 7:46 am    Post subject: Reply with quote  Mark this post and the followings unread
(Where was this thread split from?)
A board of a dozen or more ICs isn't going to be much of an improvement over the original 50240 and it might be worth it to accept the exorbitant price the organ repair co's want for a replacement. That, or persuade someone with the skills to provide a CPLD or FPGA recreation.
btw, 8-bit division is definitely not good enough and 9-bits is only "better."
That's surprising and good news about the 40106 osc stability. All could be tuned simultaneously with techniques discussed in the Lunetta forum.
Rykhaard
New postPosted: Tue Oct 07, 2008 8:13 am    Post subject: Reply with quote  Mark this post and the followings unread
That was using metalized polyester film caps. Smile (1n or 2n2. Can't remember which one.)
urbanscallywag
New postPosted: Tue Oct 07, 2008 9:38 am    Post subject: Reply with quote  Mark this post and the followings unread
A $1 CPLD would do it.
Scott Stites
Audio files: 96
New postPosted: Tue Oct 07, 2008 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Ed Space. We were wondering about other products we could put in the store to help support the forum.
That makes the most sense to me, though it's entirely out of my grasp to actually do it.
Let a thousand paraphonics bloom.... Very Happy
My Site
