Deleted
Page 2 of 2 [36 Posts]
Goto page: Previous 1, 2
robovoice
Audio files: 12
PostPosted: Thu Oct 23, 2008 11:23 am    Post subject:   Reply with quote  Mark this post and the followings unread
Deleted.
Roland SVC-350 Vocoder
Korg Poly-800 Synthesizer
Sennheiser Vocoder Demo
robovoice
Audio files: 12
PostPosted: Thu Oct 23, 2008 11:38 am    Post subject:   Reply with quote  Mark this post and the followings unread
Deleted.
robovoice
Audio files: 12
PostPosted: Thu Oct 23, 2008 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Deleted.
PostPosted: Thu Oct 23, 2008 1:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Unfortunately the links don't work either, same problem, the underlying files are not valid.
Think it would be best to post the mov's here and remove all the other attachments, after that I'll clean up the then empty/meaningless mess(ages).
Personally I can't convert mov's ... I think that I can't even open them as I deleted everything starting with "i" or "Quick" and ending in "Tunes" or "Time" from this (Vista) computer (it didn't work properly, a Vista problem mostly I think), but will have a look, maybe one of my video converters will do it, or maybe someone else can help, we'll see.
robovoice
Audio files: 12
PostPosted: Thu Oct 23, 2008 2:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Deleted.
PostPosted: Thu Oct 23, 2008 2:28 pm    Post subject: Re: Roland SVC-350 Vocoder Recordings (Speaking, Not Singing)!!!
Subject description: Korg Poly-800 Synthesizer as the carrier input!!
robovoice wrote:
I'll have to re-record them since the originals were somehow rendered useless (turned into documents, too many file extension changes?).
Bummer Crying or Very sad
robovoice
Audio files: 12
PostPosted: Thu Oct 23, 2008 2:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Deleted.
PostPosted: Thu Oct 23, 2008 3:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe you can use VLC to convert the files, see http://www.webforth.com/?p=37 - there is an OSX version
no, zippy share didn't work for me.
PostPosted: Thu Oct 23, 2008 3:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
I downloaded the mp3s, renamed the bad ones to mov, and then I can play them with VLC, but I can't convert 'm for some reason ... and I'm running out of time unfortunately ... they sound good .. that's what counts I guess Laughing
robovoice
Audio files: 12
PostPosted: Thu Oct 23, 2008 11:24 pm    Post subject:   Reply with quote  Mark this post and the followings unread
Deleted.
Roland SVC-350 Vocoder 1.mp3
 Filename:  Roland SVC-350 Vocoder 1.mp3
 Filesize:  939.26 KB
 Downloaded:  466 Time(s)
Roland SVC-350 Vocoder 2.mp3
 Filename:  Roland SVC-350 Vocoder 2.mp3
 Filesize:  1.57 MB
 Downloaded:  437 Time(s)
Hello.mp3
 Filename:  Hello.mp3
 Filesize:  586.28 KB
 Downloaded:  448 Time(s)
Response.mp3
 Filename:  Response.mp3
 Filesize:  835.1 KB
 Downloaded:  455 Time(s)
Telephone Call.mp3
 Filename:  Telephone Call.mp3
 Filesize:  2.14 MB
 Downloaded:  427 Time(s)
PostPosted: Fri Oct 24, 2008 3:41 am    Post subject: Re: Roland SVC-350 Vocoder Recordings (Speaking, Not Singing)!!!
robovoice wrote:
I've installed VLC, but I don't see any type of conversion offered.
It is hidden a bit ... and the last version works different than the on mentioned in the link I posted above, but it can be done.
Anyway, hello.mp3 works the others still have the same issue.
