robovoice
Audio files: 12
Posted: Thu Oct 23, 2008 11:23 am Post subject:
Deleted. _________________ Roland SVC-350 Vocoder
Korg Poly-800 Synthesizer
Sennheiser Vocoder Demo Last edited by robovoice on Thu Nov 06, 2008 9:49 pm; edited 2 times in total |
robovoice
Audio files: 12
Posted: Thu Oct 23, 2008 11:38 am Post subject:
Sennheiser Vocoder Demo Last edited by robovoice on Thu Nov 06, 2008 9:50 pm; edited 1 time in total |
robovoice
Audio files: 12
Posted: Thu Oct 23, 2008 11:58 am Post subject:
Sennheiser Vocoder Demo Last edited by robovoice on Thu Nov 06, 2008 9:52 pm; edited 1 time in total |
Joined: Apr 03, 2004 Posts: 24484 Location: The Netherlands, Enschede
Posted: Thu Oct 23, 2008 1:35 pm Post subject:
Unfortunately the links don't work either, same problem, the underlying files are not valid.
Think it would be best to post the mov's here and remove all the other attachments, after that I'll clean up the then empty/meaningless mess(ages).
Personally I can't convert mov's ... I think that I can't even open them as I deleted everything starting with "i" or "Quick" and ending in "Tunes" or "Time" from this (Vista) computer (it didn't work properly, a Vista problem mostly I think), but will have a look, maybe one of my video converters will do it, or maybe someone else can help, we'll see. _________________ Jan
robovoice
Audio files: 12
Posted: Thu Oct 23, 2008 2:26 pm Post subject:
Posted: Thu Oct 23, 2008 2:28 pm Post subject:
Re: Roland SVC-350 Vocoder Recordings (Speaking, Not Singing)!!! Subject description: Korg Poly-800 Synthesizer as the carrier input!! |
robovoice wrote: | I'll have to re-record them since the originals were somehow rendered useless (turned into documents, too many file extension changes?). |
Bummer  _________________ Jan
robovoice
Audio files: 12
Posted: Thu Oct 23, 2008 2:51 pm Post subject:
Sennheiser Vocoder Demo Last edited by robovoice on Thu Nov 06, 2008 9:53 pm; edited 1 time in total |
Posted: Thu Oct 23, 2008 3:04 pm Post subject:
Maybe you can use VLC to convert the files, see http://www.webforth.com/?p=37 - there is an OSX version
no, zippy share didn't work for me. _________________ Jan
Posted: Thu Oct 23, 2008 3:40 pm Post subject:
I downloaded the mp3s, renamed the bad ones to mov, and then I can play them with VLC, but I can't convert 'm for some reason ... and I'm running out of time unfortunately ... they sound good .. that's what counts I guess  _________________ Jan
robovoice
Audio files: 12
Posted: Thu Oct 23, 2008 11:24 pm Post subject:
Deleted.
Description: |
 Download (listen) |
Filename: |
Roland SVC-350 Vocoder 1.mp3 |
Filesize: |
939.26 KB |
Downloaded: |
466 Time(s) |
Description: |
 Download (listen) |
Filename: |
Roland SVC-350 Vocoder 2.mp3 |
Filesize: |
1.57 MB |
Downloaded: |
437 Time(s) |
Description: |
 Download (listen) |
Filename: |
Hello.mp3 |
Filesize: |
586.28 KB |
Downloaded: |
448 Time(s) |
Description: |
 Download (listen) |
Filename: |
Response.mp3 |
Filesize: |
835.1 KB |
Downloaded: |
456 Time(s) |
Description: |
 Download (listen) |
Filename: |
Telephone Call.mp3 |
Filesize: |
2.14 MB |
Downloaded: |
427 Time(s) |
Sennheiser Vocoder Demo Last edited by robovoice on Thu Nov 06, 2008 9:54 pm; edited 1 time in total |
Posted: Fri Oct 24, 2008 3:41 am Post subject:
robovoice wrote: | I've installed VLC, but I don't see any type of conversion offered. |
It is hidden a bit ... and the last version works different than the on mentioned in the link I posted above, but it can be done.
Anyway, hello.mp3 works the others still have the same issue. _________________ Jan
