 Forum index » Clavia Nord Modular » G2 Patches - Completed » Synth
WaveTable Filter modulation synth
Page 1 of 1 [8 Posts]
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Mon Oct 27, 2008 12:41 pm    Post subject: WaveTable Filter modulation synth Reply with quote  Mark this post and the followings unread
again, for some reason I like the resonance knob. I like added a waveshaping 3bit (8 levels) transformation after the filter in the G2 which is affected by the resonance level, the high level idea is from the waldorf2/xt waveshaper filter. It is a starting point.
I will work on it more, cuz I know I need at least 5 bits not only 4 (1 16 value sequencer used as waveshape) which make things too chunky. And to have some other wavetables scanned using a mux. and scanning with multiple muxs using the same sequencers as wavetables means less cpu.
I love the G2 DSP CPU. The power they and the Clavia programmers can produce, is so sweet.
enjoy.
/Dasz
WavShapeFilterDZ.pch2
 Filename:  WavShapeFilterDZ.pch2
 Filesize:  2.42 KB
 Downloaded:  2567 Time(s)
kara
G2 patch files: 5
PostPosted: Tue Oct 28, 2008 12:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Very interesting idea,
To make it a bit more musical, it should sound a bit more fluid. But I guess that is what you mean with bits?
I'm a musisian not a math guy Confused
k
Free samples, Vsti's and Artist hosting at www.kara-moon.com
Music forum at www.kara-moon.com/forum
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Tue Oct 28, 2008 12:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
what are you thinking, more fluid? I know I would be putting the waveshaped stuff through a bandpass filter and more eq but i don't know when I will put more energy into this one.
I also hate math, that is why I like the simple interface of the nord.
by bits I mean how many steps are used to transform the output of the filter (if you use 1 sequencer you get 16 steps or 4 bits, if you use 2 or 32 steps then you have 5).
/Dasz
iPassenger
G2 patch files: 78
PostPosted: Tue Oct 28, 2008 1:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
As I had never tried to use two or more of them before to make a more complex shaper, just knocked this up:
PATCH:
Two ctr seqs used to shape a couple of osc's.
Var 1 basic, Var 2 + 3 are a couple of ideas on the theme with lots of effex.
So would you best using a muxer for when using several more CTR SEQs?
Two SEQCTRs.pch2
 Filename:  Two SEQCTRs.pch2
 Filesize:  2.2 KB
 Downloaded:  2216 Time(s)
iP (Ross)
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Tue Oct 28, 2008 3:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Ross,
of course i can crossfade between 2 different wavetables, but I thought to use more than 3 or 4 to simulate a wavetable in a waldorf ...
/Dasz
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Tue Oct 28, 2008 3:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
ideas to improve the original patch
another idea is to band reject the cutoff where the built in resonance is used and to supplement (with a bandpass) it with the waveshaped processing once resonance is cranked and the waveshaped stuff is up
/Dasz
Estarriol
PostPosted: Sun Sep 01, 2013 2:21 am    Post subject: Reply with quote  Mark this post and the followings unread
The first patch sounds awesome. Had to login and up a 5yr old thread to say that :-)
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Mon Sep 02, 2013 6:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
