Sample playback from ... Anything that works
Page 1 of 1 [7 Posts]
aerogramma
PostPosted: Fri Nov 07, 2008 4:46 am    Post subject: Sample playback from ... Anything that works
Subject description: Hardware loop player w/ VCA and ADSR: any device/set up reccomended?
Hello,
i need to build an array of sample players, let's say 6.
they'll need to run without a computer and play, loop and possibly be interfaced with sensors and triggers
I was thinking that the best thing would be do get a programmable RAM playback board and dump the samples there
any idea / suggestion on boards and alternative solutions?
thanks
Wink
aero
okvern
PostPosted: Fri Nov 07, 2008 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi aerogramma,
There are a bunch of examples of this for Arduino:
MP3 sample player: http://www.arduino.cc/playground/Main/VMUSIC
MP3 sample player: http://www.sport4minus.de/blog/?p=152
iPod control: http://www.jonasolson.se/content/arduino_tutorial/
Forum post on sampled audio: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1202279613
Playground article on PCM sampled audio: http://www.arduino.cc/playground/Code/PCMAudio
ladyada's Wave Shield kit: http://www.ladyada.net/make/waveshield/index.html
The last one is probably the easiest/quickest way to go--just add sensors and your loop programming, and I think you've got what you want.
Thanks,
Ole
aerogramma
PostPosted: Fri Nov 07, 2008 10:42 am    Post subject: Reply with quote  Mark this post and the followings unread
hey ole... i did had a re-look at arduino this afternoon and ordered a board Wink
thanks for the links... will look into it and let you know
be well
aero
aerogramma
PostPosted: Sat Nov 08, 2008 8:25 am    Post subject: gating mp3 devices on any sound sources using arduino Reply with quote  Mark this post and the followings unread
Hello again,
I just got this idea of using arduino to gate the analog output of , for example, an mp3 players.
I was wondering if there's a fairly easy solution using simple VCAs and possibily a ADSR connected to the output of these sound players .
The reason i would like to use an ADSR is to have a smooth attack and release everytime i want to gate the sound the mp3 player.
I'm attaching a pict to show my idea. I hope it's clear enough. Smile
any advice is much appreciated..
PostPosted: Sat Nov 08, 2008 10:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
You may want to take a peek at these very simple VCA's as described on Scott Stites "Birth of a Synth" web page. It is a Thomas Henry design that will get the job done with very little by way of parts:
http://mypeoplepc.com/members/scottnoanh/birthofasynth/id31.html
You could use one VCA for each channel of audio. Smooth gating can most likely be accomplished via a simple Attack/Decay circuit using a simple buffered Resistor/Capacitor combination. The buffered exponential capacitor voltage could then drive the VCA. This will be perfect as the VCA-1 responds linearly so driving it with an exponential voltage will be the best fit for the human ears perception to the changing volume level.
Hope this helps more Wink
Bill
aerogramma
PostPosted: Sun Nov 09, 2008 7:00 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks a lot for your reply and links!
it's definitely going to help..
be well
aero
PostPosted: Sun Nov 09, 2008 7:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Good luck with the project and if you need more specific information, please ask Wink
