what options for the Tellun Neural Agonizer ?
Page 1 of 1 [8 Posts]
Funky40
G2 patch files: 5
PostPosted: Thu Nov 20, 2008 6:51 am    Post subject: what options for the Tellun Neural Agonizer ?
Subject description: how did you built ? attenuators for CV Inputs recommended ?
Hello,
Scott from Tellun mentions lots of Options in the building docs.
1. Should i just follow the main instructions or are there things/values better done in a optional way ?
2. Do you miss somewhere on the CV Inputs Attenuators ?
please give some feedback if you have built the TNA, thanks.
(edited a tipo in the header)
peng
PostPosted: Thu Nov 20, 2008 7:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
I built three of these last year (maybe two years ago). They are a lot of work. I pretty much followed the standard build. I didn't include attenuators for the CV inputs because the panel is big enough! I built a 1U wide passive attenuator (two pots) with a mult thrown in. Never needed anything more than that (and they can be used with other modules).
There is a lot of trimming to do and some of those are 'to taste'. Be prepared for much experimentation and retrimming before its finally there.
Worth it, though.
If you haven't bought your tanks yet I strongly encourage going with the large tanks (top of the line Accutronics model). The smaller tanks are good, the large tanks are about twice as good. Well worth the extra space.
p.
Funky40
G2 patch files: 5
PostPosted: Fri Nov 21, 2008 4:39 am    Post subject: Reply with quote  Mark this post and the followings unread
I have in my notifications three attenuators, but yeah, big Panel
Your Idea with a separate modul is a very good one
My Cabinet for the Tanks is built since March. thanks to serenadi i have the Large Tanks Very Happy
thanks Peng !
neandrewthal
PostPosted: Sat Nov 22, 2008 1:21 am    Post subject: Re: what options for the Tellun Neural Agonizer ?
I once asked Scott this very question
Scott Juskiw wrote:
If I could add attenuators, I'd add them in this order:
1. Feedback
2. LPF
3. Deform
4. Drive
5-8. Stress/Trauma A/B
peng
PostPosted: Sat Nov 22, 2008 4:08 am    Post subject: Re: what options for the Tellun Neural Agonizer ?
1. Feedback
2. LPF
3. Deform
4. Drive
[/quote]
I would put Drive at 3. Maybe even one. VC Overdrive is pretty cool!
Funky40
G2 patch files: 5
PostPosted: Sat Nov 22, 2008 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks again !
i see now clear how to layout my panel.
time to populate the Boards Wink
Funky40
G2 patch files: 5
PostPosted: Tue Nov 25, 2008 2:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Boards are done, but now i'm unshure about the Format i should go.
query:
is the TNA a Modul you tweak _active_ the Knobs like lets say the Cutoff on a Filter ?
Or is it more that you adjust things and keep them so while jamming with The Synth ?
ohh, and if you would put attenuators on all CV inputs, but must deside between Traume and Stress,
what of both you would take ?
Luka
PostPosted: Tue Nov 25, 2008 3:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
my take on this module was that it was for extreme sound design, not for clean reverb sounds, hence the name of it Smile
i would say that live tweaking and cv control is most necessary
problemchild
melbourne australia
