 Forum index » Instruments and Equipment » MIDI Controllers and Interfaces
What module to use?
Page 1 of 1 [3 Posts]
indycelt
PostPosted: Fri Dec 26, 2008 2:30 pm    Post subject: What module to use? Reply with quote  Mark this post and the followings unread
I am a music composer, and want to add strings and virtual instruments to my songs. I was recently given an M-Audio Keystation 61es. My question is this: what sound modules work best with this? I am a musician of many years experience, but with midi and virtual instruments, I am a novice. I also find that when working in my DAW, when recording one virtual instrument per track, what I record on one track will be "added" on top of whatever tracks I lay down next. Any help would be greatly appreciated.
PostPosted: Sat Dec 27, 2008 3:25 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome to the forum indycelt!
There are loads and loads of different plugins you can use with a DAW - which works best depends on what kind of music you do and what way of working you're after. Which DAW are you using?
/Stefan
indycelt
PostPosted: Sat Dec 27, 2008 6:53 am    Post subject: DAWs Reply with quote  Mark this post and the followings unread
Sonar 7
