kxspxr
Joined: Apr 03, 2004 Posts: 24392 Location: The Netherlands, Enschede
Audio files: 296
Posted: Tue Dec 30, 2008 2:58 pm Post subject:
I'm not sure ... just some thoughts ...
A Wheatstone bridge setup measures resistance in a very sensitive way, and as such it would not make sense to put a buffer before it (erm .. I don't see it, I mean ).
But I'm wondering if measuring resistance is the thing to do, or that maybe some activation potential would be more interesting ... in the latter case it would make sense to not have a bridge but go into a instrumentation amplifier directly (an opamp with good common mode rejection).
I've no idea what plants do ... electrically I mean, I know you can smoke 'm of course. _________________ Jan
seraph
Editor
Audio files: 33
kxspxr
Posted: Wed Dec 31, 2008 1:20 am Post subject:
Blue Hell wrote: | A Wheatstone bridge setup measures resistance in a very sensitive way, and as such it would not make sense to put a buffer before it (erm .. I don't see it, I mean ). |
Oh yes of course. Dang! My mind must have flicked or something. Thanks.
Blue Hell wrote: | But I'm wondering if measuring resistance is the thing to do, or that maybe some activation potential would be more interesting ... in the latter case it would make sense to not have a bridge but go into a instrumentation amplifier directly (an opamp with good common mode rejection). |
I did amplify the action potential in plants some years ago and that was exactly the way I did it
EDIT: Ooops - My memory played a trick on me. I used a very sensitive meter to measure it. I didn't build the unit myself though. _________________ "Posthumanity is a discrete set of processes with arbitrary return codes." |
frijitz
Audio files: 54
Posted: Thu Jan 01, 2009 12:06 pm Post subject:
Ummm ... that's not a Wheatstone bridge.
The lower 1k resistor should be connected to "top of leaf", rather than ground.
But to answer your question, the usual approach would be to feed the differential signal into an instrumentation amp. You can buy these as an IC, or make one out of three opamps.
Ian |
kxspxr
Posted: Fri Jan 02, 2009 3:07 am Post subject:
frijitz wrote: | Ummm ... that's not a Wheatstone bridge.
Ian |
Thanks Ian! Hmm... I see what you mean about the bridge. Good thing I posted here first. I have a bunch of quad opamps so I'll just make an instrumentation amp from those.
-Kasper _________________ "Posthumanity is a discrete set of processes with arbitrary return codes." |
frijitz
Audio files: 54
Posted: Fri Jan 02, 2009 9:50 am Post subject:
Interesting project! Please keep us posted on your progress.
Ian |
kxspxr
kxspxr
