Inventor
Audio files: 267
Posted: Wed Jan 21, 2009 12:21 pm Post subject:
1/4" Jacks for Dummies Subject description: Teach me please! |
OK, so it sounds very basic but to be honest I'm not very familiar with 1/4" jacks. Aside from the simple two-terminal mono jack, we have a contact on the tip which may be open or closed with no plug inserted. Some of my questions include:
What is the extra terminal used for? I presume it is something like detecting when a plug is present and/or providing ground to the input when not in use.
For the Digi-Key part number SC1123-ND, it is described as "double open circuit", what does this mean?
Thanks for educating me on these details. _________________ "Let's make noise for peace." - Kijjaz |
DrJustice
Joined: Sep 13, 2004 Posts: 2114 Location: Morokulien
Posted: Wed Jan 21, 2009 8:03 pm Post subject:
Here's the Switchcraft page, there's a link to a datasheet with a schematic drawing. As you can see, when the plug is inserted, the normally closed contact disengages from the plug terminal, and the plug makes contact instead. You get them in both mono and stereo/balanced versions, the latter using two such contacts for the tip and the ring. Switchrafct call the switches 'shunts' - haven't heard that before, but it makes sense.
The extra, normally closed contacts, can be used for grounding an unused input, detecting an inserted jack or disconnecting a normalized input signal - but you've got all of that already
DJ
Posted: Thu Jan 22, 2009 3:21 am Post subject:
The two normally closed switches are(were) most commonly used to short out the dropping resistors which you don't want in circuit when you don't have your headphones plugged in.
So it follows that the third connection is the right hand channel of your headphones. ie; Tip/Ring/Sleeve -> Left/Right/Ground
BTW Of course, if you're using mono plugs, the third connection is only connected to ground when a plug is present. That's why stomp-boxes use it as the ground connection for the battery. _________________ What makes a space ours, is what we put there, and what we do there. |
Inventor
Audio files: 267
Posted: Thu Jan 22, 2009 4:43 pm Post subject:
OK, thanks guys. You know, it's funny we can understand complicated stuff but sometimes the simplest of things escape us, or me anyway. Cheers! _________________ "Let's make noise for peace." - Kijjaz |
