Advice on grounding for a DIY guitar pedal
Page 1 of 1 [4 Posts]
opg
PostPosted: Tue Feb 17, 2009 4:39 pm    Post subject: Advice on grounding for a DIY guitar pedal Reply with quote  Mark this post and the followings unread
I'm about to begin a project to build an analog bit crusher pedal. I purchased a plastic project box from allelectronics.com that of course comes with a brushed aluminum cover. What should I do to ensure it's grounded properly? Does a wire get soldered to the cover, and where is said wire connected to on the circuit board?
Also, I know all too well about hum problems with pedals. Anything I should know about this to prevent it before I start?
Thanks
One Player Game | OPG on SoundCloud
DrJustice
PostPosted: Tue Feb 17, 2009 5:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not sure how you make an analogue bit crusher... Got any references, I'm curious Smile
The alu panel is not easily solderable, it's probably best to use a screw and a solder lug. To combat hum, it would be best if the box was all metal, but since you already have a box, why not just try the circuit and listen for hum.
DJ
opg
PostPosted: Tue Feb 17, 2009 6:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool, thanks.
Here's the board layout:
http://www.geocities.com/worthekik/bitcrusher.html
DrJustice
PostPosted: Wed Feb 18, 2009 7:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Aha - it's a high frequency sample and hold that makes a staircase of you signal. So it'll sort of give the effect reducing both sample rate and bit depth - neat Smile
DJ
