Inputs and Outputs
Page 1 of 1 [7 Posts]
PostPosted: Wed Apr 02, 2008 2:02 am    Post subject: Inputs and Outputs Reply with quote  Mark this post and the followings unread
This pdf by Magnuson shows some basic input/output protection/indication I thought you might find interesting.
http://www.hoohahrecords.com/resfreq/analog/modular/gl1a/GL-1A.pdf
Adam-V
PostPosted: Wed Apr 02, 2008 11:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good stuff. Thanks Uncle K.
Reminded me that it is probably not a bad idea to put some sort of output short protection in as well as input overvoltage protection.
Adam-V
loss1234
PostPosted: Sun Aug 10, 2008 9:09 am    Post subject: Reply with quote  Mark this post and the followings unread
link down?
Audio files: 308
PostPosted: Sun Aug 10, 2008 9:15 am    Post subject: Reply with quote  Mark this post and the followings unread
hoohahrecords.com expired on 07/04/2008 and is pending renewal or deletion.
That's pretty much like down Wink
stolenfat
PostPosted: Wed Feb 25, 2009 12:42 am    Post subject: Reply with quote  Mark this post and the followings unread
hey, i've heard you should ground all your jacks... but i've got a bunch of phono rca jacks that i wanted to use in my next lunetta. Could i get away with using ungrounded jacks? Would it cause any terrible problems?
stolenfat
PostPosted: Wed Feb 25, 2009 1:13 am    Post subject: Reply with quote  Mark this post and the followings unread
well upon further inspection you can ground phono jacks, my bad
PostPosted: Wed Feb 25, 2009 3:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey, that sounds like a good use for RCA/phono jacks.
God knows they're not much use for anything else! Laughing
