 Forum index » Instruments and Equipment » OSX as a music workstation
Aggregate Devices.
Page 1 of 1 [5 Posts]
BobTheDog
Audio files: 32
PostPosted: Fri Mar 20, 2009 7:30 am    Post subject: Aggregate Devices.
Subject description: Clocking issues.
Hi Guys,
I am having problems setting up an Aggregate Device containing a Motu 828mkii and a Fireface 800.
It seems to me like the clock drifts after a period of time, I have tried clocking from the motu and also from the fireface.
Should this work?
Also what is the Resample option?
Or is the best way to connect clock one from the other using hardware and if so how do you turn off the clock option on the aggregate device?
Any help would as usual be very appreciated.
Andy
EdisonRex
Audio files: 172
PostPosted: Fri Mar 20, 2009 11:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Just guessing, as I was playing with an aggregate device last weekend. The hardware setup on the MOTU (should be a panel in audio/midi setup) might give you clocking options, likewise there is probably a setup somewhere on the Fireface too. It does sound like your clocks are not synchronized.
Garret: It's so retro.
BobTheDog
Audio files: 32
PostPosted: Fri Mar 20, 2009 12:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
You Genius Smile
The motu has the ability to clock from firewire and it looks like core audio sends a clock signal via the firewire if I set the Fireface as the clock source.
Thanks for this.
Andy
dewdrop_world
PostPosted: Sat Mar 21, 2009 3:28 pm    Post subject: Re: Aggregate Devices.
Supposed to do sample rate conversion if the devices are running at different rates.
I would say, avoid if possible. I had Resample turned on for awhile and wondered why I got horrid clicking and distortion on the aggregate device (when my MOTU by itself sounded fine). Turning off Resample cured that one immediately.
James
EdisonRex
Audio files: 172
PostPosted: Sun Mar 22, 2009 11:21 am    Post subject: Reply with quote  Mark this post and the followings unread
BobTheDog wrote:
You Genius Smile
Thanks for this.
Andy
You are most welcome. Smile
