Simulating circuits
Page 1 of 1 [4 Posts]
wmonk
Audio files: 15
PostPosted: Thu Feb 19, 2009 1:07 pm    Post subject: Simulating circuits Reply with quote  Mark this post and the followings unread
Hi!
To test some of my mods for various circuits, I want to use SPICE, or other simulation software.
The problem with SPICE is, you can't use potentiometers (I didn't find a way to do that.)
Can anyone help with this problem?
Thanks,
Wmonk
DrJustice
PostPosted: Thu Feb 19, 2009 1:31 pm    Post subject: Re: Simulating circuits Reply with quote  Mark this post and the followings unread
You have to replace pots with two resistors.
DJ
Ricko
Audio files: 27
PostPosted: Sun Mar 22, 2009 11:47 am    Post subject: Reply with quote  Mark this post and the followings unread
TI-SPICE certainly has pots. The only trick is not to set them at 0% or 100%.
I thought some of the other SPICE repackages have pots too.
Rick Jellifffe
Inventor
Audio files: 267
PostPosted: Sat Mar 28, 2009 2:49 am    Post subject: Reply with quote  Mark this post and the followings unread
In a spice package that I forget now, I used to use a thing called "parameters" that would let you sweep a pot. Dang, I'm only 42, have I gotten so old that I can't even recall the name of that simulator? Apparently so!
