Adding CV to 808 accent circuit
Page 2 of 3 [63 Posts]
tommi
PostPosted: Tue Apr 21, 2009 7:50 am    Post subject: Reply with quote  Mark this post and the followings unread
You want to put a vactrol in place of the tune pot?
http://tideofsound.net
creatorlars
PostPosted: Tue Apr 21, 2009 8:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Sort of -- One of these...
http://www.bridechamber.com/bridechamber.com/VC%20Res%20PCB.html
tommi
PostPosted: Tue Apr 21, 2009 9:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Please post some sample when you 're done with that!
I am sure it will be fun especially on bd tune control.
funkyfarm
PostPosted: Tue Apr 21, 2009 6:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
what is "accent" ?
just more voltage into vca cv input ? just more volume ?
a boost for velocity ?
creatorlars
PostPosted: Tue Apr 21, 2009 7:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's meant to simulate velocity -- I'm not sure whether it's just a simple volume boost or if it adjusts the dynamics or presence of the drum voice as well -- I haven't wired mine up yet and never used a real 808. I'd guess it might also depend on which drum voice we're talking about.
Luka
PostPosted: Wed Apr 22, 2009 12:30 am    Post subject: Reply with quote  Mark this post and the followings unread
there is an accent in on my xoxbox IO mod kit
it is simply a signal hitting a 100k resistor going into the base of a 547 which hits the accent transistor. emitter to ground and collector to the accent transistor of the env in the xox
hope that helps
problemchild
melbourne australia
creatorlars
PostPosted: Wed Apr 22, 2009 6:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Perfect, thanks Luka!
tommi
PostPosted: Wed Apr 22, 2009 9:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Now I 've built Snare Drum and Clap. They are working, I just had to invert the wiring to some potentiometer. So I added noise input jack for both. I am feeding them with noises from Noise Cornucopia and I noticed some weird graininess on the decay. It's unique and beautiful, but now I found the schematics for noise on the 808 and it's specified that its noise output is +/-130mV rms. I think that Noise Cornucopia is outputting something like +/-5VPP. So I believe this weird graininess is caused by distortion. I thought I could add an attenuator on the noise input and see what happens. Or maybe a new pot on the panel...
Link to the noise circuit: http://xlargex.xl.funpic.de/projects/808/schema/808_NOISE300dpi.jpg
creatorlars
PostPosted: Wed Apr 22, 2009 9:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Awesome! Yeah, I'm excited about experimenting some with running the noise sources through an effects loop with Send/Receive!
Just FYI, I am almost finished with a PCB layout for Noise+Accent+Schmitt Trigger, using the same power header as the microLARGE PCBs and with enough output headers for all the 808 modules/mods -- these are the missing PCBs from that site. I'll post it when I'm done with it (sometime this week.)
I also have a PCB layout finished for Thomas Henry's Trigger Conditioner/LED Driver, but I can't post that -- let me know if you own the book and I'll send it to you, though. (It is available from Magic Smoke.) It has provisions for three different trigger inputs and one trigger output. In my case, the inputs will be 1) trigger input jack, 2) a MIDIbox-based Midi-to-Trigger, and in some cases 3) a panel-mounted pushbutton trigger. The conditioning circuit will make sure that the output trigger from all of these sources going into the 808 board is identical no matter what the source. And the built in LED driver is handy, because the 808 doesn't have LEDs for each module.
tommi
PostPosted: Wed Apr 22, 2009 9:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Wich book? I got 'The VCO Chip Cookbook' but I am sure you 're not talking about it! Nice solution the trigger merger, maybe I could add it to my system in the future. For now I am ok with the SEQ01 wich have 12 trigger outs. Also I got no more space on my racks... I filled 3 floors of eurorack!
By the other side, I would be pretty happy to add trigger leds to this modules!
creatorlars
PostPosted: Wed Apr 22, 2009 10:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool! The book is "The Electronic Drum Cookbook".
KrIVIUM2323
PostPosted: Thu Apr 23, 2009 6:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi everybody.
CreatorLars/Tommi i wish to thank you opening this thread as it answer on a lot of question i was asking about the BD of the 808.
I've trying to breadboard the circuit some weeks ago but it wasn't working.
Beside many fault on the layout even if it was ok it won't have work 'ok' anyway as my seq can't reach +15v on the cv output (Doepfer Regelwerk) and the gate signal maybe a bit weak to.
So i decided to use the trigger conditionner from Mr. T.HENRY for the gate input (nice and simple cost effective circuit! BUY THIS BOOK you who are interested in drum synth... you can't regret it!).
Now i've to deal with the accent circuit. My thought about it is to use two part of circuits which fly around the net:
The first part of the circuit would be an inverting opamp dc coupled with a gain of 2 to get the cv in the range 0/10v (precision should'nt matter tomuch i think it's only accent anyway...).
Then i would use a part of the circuit from the Tellun TLN-861 Dunsel, more precisely the 'A+5' :wich offset +5v the signal at input to reach a usable range of 5/15V for the cv input.
Does it make sense for you?
Don't be to hard if it doesn't make sense it's my first approach to design something to solve a problem... Wink
I think this way i'll have acces to the 'normal' behavior of the kick regarding accent and CV from the Doepfer seq. I don't need a push button to trigger by hand on the face of the module like you but it shouldn't be difficult to implement a switch to do that anyway if i need it (tying +15v to accent and input to trigger conditionner)...
Could you give me your opinion about that? Smile
creatorlars
PostPosted: Thu Apr 23, 2009 7:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi! I'm glad the information was useful!
Absolutely!! The Trigger Conditioner circuit is worth the price of the book alone, perfect for these kind of projects.
The Doepfer DIY page has two simple schematics that will help you with 1) Mixing the triggers together at the Trigger Conditioner input (see "Or-wired sockets") and 2) The manual pushbutton gate. If the pushbutton is going into the trigger conditioner, no "gate-to-trigger" circuit is needed.
http://www.doepfer.de/DIY/a100_diy.htm
Your suggestion for the accent circuit seems good to me. So basically what you're suggested is...
1) Sequencer's trigger out goes to TH Trigger Conditioner, then out to BD trigger input.
2) Sequencer's CV out goes to op-amp (you want NON-inverting, see above page for a simple schematic), you up the gain by 2, effectively giving you 0-10V instead of 0-5V. Then you add an offset of +5V, effectively giving you 5-15V. This is sent to the BD Accent input.
Sounds perfect. This will allow you to send a full velocity range to the BD. However, this is not the "true" accent circuit -- which is triggered rather than voltage controlled. My implementation is a direct clone of the 808's accent circuitry, with a CV mixer added so that you can 1) trigger global accent, 2) set global accent level, and 3) voltage control the global accent level. I don't have accent control over the individual voices (like you will), but that's okay for me.
Let us know how it works out!
creatorlars
PostPosted: Thu Apr 23, 2009 7:25 am    Post subject: Reply with quote  Mark this post and the followings unread
I thought I'd share my 19" rack, Serge-grid-style 808 drum panel layout. I'm sure I've forgotten lots of awesome stuff I could add, but it should be pretty crazy when done. It connects to my "Master Drum Control" module which distributes MIDI triggers to all the voices, behind the panels.
The V8 Sim is CGS and I just threw it on there because I had an extra slot. In hindsight maybe some sort of an effect is better. 909 BD is also there for extra space (and because I want two, and after building my 9090, I'll have 'em!)
 Filesize:  147.23 KB
 Viewed:  317 Time(s)
tommi
PostPosted: Thu Apr 23, 2009 8:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi KrIVIUM2323 !
This Forum helped me too! When I saw that Creatorlars had successfully builded the 808 modules using xlargex's PCB I 've gone directly with PCBs and they worked! I only had a bug with bd but it was only a broken pwr bypass cap.
I think your plans for trigger and accent are ok. Since I 'll trigger the drums with a variable trigger I simply tied trig and accent together and I can confirm that this setting is velocity sensitive, cause yesterday I put an attenuator between trigger out and bd's trigger in and the amplitude changed.
Nice panel creatorlars! Also crowded! I 've seen you 've added nice features, like noise gain, boost for 808 bd, noise/ osc for 'brass drums', mix out... REALLY NICE!
P.S. I added attenuation trims for noise inputs on sd and clap and it's better now.
KrIVIUM2323
PostPosted: Thu Apr 23, 2009 8:56 am    Post subject: Reply with quote  Mark this post and the followings unread
CreatorLars,Tommi, Thank you answering so fast! Wink
Well in fact the Tellun Part of the circuit i plan to build is inverting input so i suppose it must be inverting input on the 'x2 gain op amp' to.Excuse me i wasn't clear about that in the message. Anyway i 'll try the 2 kind of circuit just for science and see what append... Wink
Thank for the link to doepfer... should have search there first.
Ok i've got it now! Wink I first didn't understand your need about a CV accent. After rereading the contribution and links from Tommi i now understand you needs!
The need for individual accent is something i really would...
I'll try everything this week end as i'll have spare time to do.
If the kick don't react as a real 808 i could add a 3080 VCA (from Mr. Henry to! 'making music with CA3080 OTA' Wink ) driven by the trigger conditionner to 'shape' the accent gate.
Maybe 1ms is a bit short for the vca to respond cleanly...i'll see!
Thank you really! Everything gets clearer and clearer! Smile
Off Topic:
Last night i downloaded the new publication from M.Henry and Magsmoke from LULU 'noise generator cookbook'. Fabulous as all things Thomas wrote... How this man can explain things so easily and never beeing boring... I'm amazed!
creatorlars
PostPosted: Thu Apr 23, 2009 9:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Glad to hear it! The panel is dense but the artwork is misleading -- the lines around each knob aren't the size of the actual knobs (which are 1/2").
Please let me know! I've never tried adjusting the trigger-length. I'm guessing you could replace a cap in the trigger conditioner with a different value to stretch the trigger, but i'm not sure.
You are right I'm sure... I don't know enough to give much educated advice on this. Smile
KrIVIUM2323
PostPosted: Thu Apr 23, 2009 9:40 am    Post subject: Reply with quote  Mark this post and the followings unread
That's it : time is givien by relation RxC. so in case of the trigger conditionner 1OOk x 0,01µf: 0,001seconds arrow 1ms.
You could play with the resistor value too if you don't have the cap at hand.
This is the way it's done on compressor sidechain/control circuitry to modify attck/release time constants.
For the tellun part of circuit:
inverting 2xGain op amp: 0 to -10v arrow Offset inverting opamp : 5v to 15v (minus x minus: positive value).
Wink
Your panel is great job! The 808 boost is a mod from the 808 forum?
And with your 909 kick did you use the JS mod (comp) or somthing else?
And do you use 'noise section' of your panel to feed the 909 kick or did you build some dedicated noise?
creatorlars
PostPosted: Thu Apr 23, 2009 5:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
The BD Boost and other mods have PCB layouts here...
I haven't built the 909 kick yet, but it's based on a PCB I found -- I'll dig up the link. I am pretty sure it has an onboard noise generator, but if it doesn't I will send it the 808 white noise.
creatorlars
PostPosted: Fri May 01, 2009 8:50 am    Post subject: Reply with quote  Mark this post and the followings unread
I wired up my Noise/Schmitt/Accent circuit board layout last night but am having trouble getting the accent to behave properly. Rather than try to debug the circuit (which is a little over my head), I decided to come up with my own using a CD4053 as a logic-controlled switch.
Here's the schematic -- can anyone tell me if this looks right? The diode at the External CV input is what I'm most worried about -- the intended purpose of this is to remove any negative voltage from the external input. Will it work that way? CD4053 can only accept a 15V p-p input signal range, so I tied negative power pin to GND (and that's also the point of the diode on the Ext CV input.)
The circuit should produce a constant +5V when not triggered, but +5V to +15V when triggered.
 Filesize:  52.42 KB
 Viewed:  249 Time(s)
creatorlars
PostPosted: Mon May 04, 2009 8:00 am    Post subject: Reply with quote  Mark this post and the followings unread
After a very long weekend of work, I'm happy to report that this new accent circuit works great (with a couple resistor changes). Please let me know if you'd like an updated schematic.
My PCB layout for Noise+Schmitt Trigger works fine too, but I need to revise it for easier etching before posting (if there's interest.)
Also, the vactrol VC mod for BD tuning works as well! It doesn't respond well to audio rates, but LFO/Envelope inputs work fine.
Sebo
PostPosted: Mon May 04, 2009 5:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Creatorlars:
This week I will be re-taking the work on my 808, I want to make individual
accents for every drum sound, all controlled by a single accent knob. I was
thinking in use CD4053s so if you could share your circuit, will be great.
Thank you.
Sebo
My Music:
creatorlars
PostPosted: Mon May 04, 2009 10:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sebo -- no problem, I'll post it tomorrow. The circuit is pretty clean as-is and works great. If you have no need for a CV summer and are using all three channels of the CD4053 you can avoid the op-amp and associated resistors entirely I think.
creatorlars
PostPosted: Tue May 05, 2009 9:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Okay, here are two versions of the circuit. The full CV/Buffered version is working and tested.
The minimal version shouldn't have any problems at all (I doubt the output buffer is really necessary). Furthermore, you could easily access the remaining B and C pins on the 4053 to get three accent circuits out of a single 4053, making this an extremely lightweight solution.
 Filesize:  28.13 KB
 Viewed:  13906 Time(s)
 Filesize:  61.33 KB
 Viewed:  239 Time(s)
Sebo
PostPosted: Tue May 05, 2009 7:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was thinking in something like the first circuit (the simpler one).
Thanks a lot!!!
Sebo
My Music:
