Yet Another VCO
Page 1 of 1 [8 Posts]
RF
Audio files: 28
PostPosted: Wed Apr 29, 2009 6:10 am    Post subject: Yet Another VCO
Subject description: 40106, two caps, 1 resistor, 1 Var resistor.
Control voltage serves as the supply voltage, and it starts oscillating at about 1.5 volts - which really works well with the output from my Lunetta's R/2R.
Linear? Expo? Bah - It is what it is - a simple VCO.
I don't recall where I saw this idea - but I breadboarded it, played with the values, and it works pretty well.
bruce
 Filesize:  15.84 KB
 Viewed:  903 Time(s)
YAVCO.mp3
 Filename:  YAVCO.mp3
 Filesize:  361.22 KB
 Downloaded:  1817 Time(s)
www.sdiy.org/rfeng
jnuaury
Audio files: 9
PostPosted: Wed Apr 29, 2009 8:09 am    Post subject: Reply with quote  Mark this post and the followings unread
perhaps it was the first post in the lunetta sound samples thread Laughing
i also posted this lonely thread over a year back
http://electro-music.com/forum/topic-24474.html
wow we sure have been lunetta-ing for quite some time now!
ill be making a post on more or less an identical vco on my blog thing later this week http://microhacking.blogspot.com/ i just want to make some new sound samples first... i have a few simple goofy extensions of the vco that you might think are fun
thanks for posting!
RF
Audio files: 28
PostPosted: Wed Apr 29, 2009 8:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Jeeese - those posts were a while ago lol - lots of CMOS has passed under the bridge since then.
I did some starving of chips early on (based on information in your post) and got some really interesting sounds - I posted one starvation experiment down the first page of the sounds thread.
In the first Lunetta I made I built starve pots built into the oscillators, and also had the ability to run a CV right into the power inputs - but I never got this same sort of result.
I think the second inverter 'buffer' makes it act much more like a tamed VCO compared to my early results with starvation... which were generally interesting but unpredictable.
bruce
www.sdiy.org/rfeng
jnuaury
Audio files: 9
PostPosted: Wed Apr 29, 2009 9:05 am    Post subject: Reply with quote  Mark this post and the followings unread
yep! the unpredictably is what i enjoy most about these circuits
one thing ive tried has oscillators made out of most of the inverters on the chip and then using a CV as the supply voltage
it generates some super dense washes of sound
you (or someone else playing with this circuit) may want to add a switch that lifts the lug on the pot going to ground. this way you have the option to starve the current going to the chip. this usually works best when you make use of several inverters though
Rykhaard
PostPosted: Wed Apr 29, 2009 9:21 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll keep the pot leg lifting in mind when I bread board my own test version of this YAVCO.
I'd mentioned on my BB after Bruce had posted the schematic yesterday, of setting up 3 x buffered 'oscillators' all controlled by the same tuning control. As long as the caps and resistors are as close to each other as possible, this could provide a wonderful thick sound over a hopefully decent tuning range.
Shall see, once I bread board it. Smile
slacker
PostPosted: Wed Apr 29, 2009 10:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks and sounds pretty cool. I'll definitely give it a try.
richardc64
Audio files: 26
PostPosted: Wed Apr 29, 2009 10:36 am    Post subject: Reply with quote  Mark this post and the followings unread
It might be interesting to see/hear if there's any difference in starving via Vcc or Vss (Gnd).
synthmonger
PostPosted: Fri May 01, 2009 7:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Info on that has actually been discussed in this thread:
http://www.electro-music.com/forum/topic-27712.html&postorder=asc
Youtube!
modular demos!
Whacky tunes!
