gas soldering irons?
Page 1 of 1 [7 Posts]
macumbista
PostPosted: Tue Jun 09, 2009 5:39 am    Post subject: gas soldering irons? Reply with quote  Mark this post and the followings unread
Related to my solar-powered synth thread... I'd like to be able to work on small circuits outdoors, off the grid. Has anyone used these small gas-powered soldering irons? Any good ones?
macumbista.net
macumbista
PostPosted: Tue Jun 09, 2009 6:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Just realized that anything involving butane is completely prohibited from airplanes. And since I travel a hell of a lot, that makes things a bit difficult. Oh well...
macumbista.net
Audio files: 297
PostPosted: Tue Jun 09, 2009 7:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm .. yes ... I got one like 15 years ago and it was ideal to use on the ship that took me to the UK, on the flight back however I had to leave some stuff at the airport Wink
Lofi Ninja
PostPosted: Tue Jun 09, 2009 1:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
You can get some that run of batteries. But I think your still going to have a hard time getting them on a plane.
www.youtube.com/user/lofininja
LektroiD
PostPosted: Tue Jun 09, 2009 1:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think the heat may be a bit too much for PCBs (I may be wrong), but on the positive side, gas soldering irons have zero voltage leak at the tip.
LektroiD
Audio files: 297
PostPosted: Tue Jun 09, 2009 1:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Dunno, the one I had could be turned pretty low, but it's better to have it a bit too hot than a bit too cold IMO.
Ricko
Audio files: 27
PostPosted: Tue Jun 09, 2009 7:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have used a butane iron when seconded to a banana farm. I made the Velleman PIC USB interface kit successfully with it.
IIRC The heat control for small welds (individual pins) was really good, much better than my crappy electric, and fast but it did not have good heat retention so it was not so at good desoldering lots of pins at the same time (to remove a chip). Also the tip I had was not as dainty as I would like. It needed re-gassing every couple of hours.
I think I would prefer an good electric with temperature control, but the gas iron was perfectly serviceable. But obviously different designs will be better or worse.
