synthmonger
RF
Joined: Mar 23, 2007 Posts: 1502 Location: Northern Minnesota, USA
Audio files: 28
Posted: Sun Feb 22, 2009 12:24 pm Post subject:
Thanks for posting that synthmonger - looks interesting. _________________ www.sdiy.org/rfeng
(Herb Deutsch to Bob Moog ~1963) |
bingmachine
Posted: Sun Feb 22, 2009 2:44 pm Post subject:
And what is the expected input signal peak-to-peak for this to work well?
/Erik |
synthmonger
Posted: Sun Feb 22, 2009 5:20 pm Post subject:
| Haven't checked. I used a guitar and casio VL-1 which worked. |
bingmachine
Posted: Mon Feb 23, 2009 4:17 am Post subject:
That's all I need to know. Sounds great! Thanks!
All we need now is that single supply version of the Wasp-filter.
/Erik Forsling |
DGTom
Posted: Sun Jun 21, 2009 5:12 pm Post subject:
I breadboarded this yesterday, & it works pretty nice, I didn't have (nor did the local supplier) any 2M2, so after gettting it up & running with 2 x 1M + 200K I replaced the 2M2 w/ a 1M pot, played a little bit with adding resistors to the pot (1M, 200K - even tried a 4M7!) but just the pot alone seemed to work best.
I am getting quite alot of voltage on the output with no input - guessing that is normal, I have a diode on the input as well, just in case, what I wonder is could you put an op-amp on the in or out to clean it up a little? I quite like the basic way the cct. works, you can hear the cap discharging in a nice bubbly way & the pot gives quite good control, from zero following to overlapping, not getting every peak smoothed out following.
Might just put a pot as a voltage divider on the output again so you can adjust the output.
Any tips or ideas from anyone else who played around with this cct. would be great  |
synthmonger
Posted: Sun Jun 21, 2009 7:45 pm Post subject:
| DGTom wrote: | I breadboarded this yesterday, & it works pretty nice, I didn't have (nor did the local supplier) any 2M2, so after gettting it up & running with 2 x 1M + 200K I replaced the 2M2 w/ a 1M pot, played a little bit with adding resistors to the pot (1M, 200K - even tried a 4M7!) but just the pot alone seemed to work best.
If you're getting a constant voltage on the output try adding a 100k resistor tied to ground on the input. _________________ Youtube!
modular demos!
Whacky tunes! |
