blue_lu
Posted: Fri Feb 12, 2010 1:58 am Post subject:
"paper circuits" and how to make them durable |
I am pretty new around here and just recently my nose has been tipped into ciat lonbardes paper circuits. I am really a novice to most of this, although I have finished several guitar fx builds and a wtpa sampler.
After you constructed one of peters circuits with the help of his paper overlay, how do you mount the cirucit in a case? I mean can you expect the construction (components through paper, soldered together) will stay together in a working form, or will it fall apart really easily?
So what is the best way to get these circuits to be physically stable? use hardboard? wood? wwcnd?
Thanks for your guys' help! |
Posted: Fri Feb 12, 2010 2:49 am Post subject:
I think putting the paper overlay on a piece of perfboard, (the type with no copper, just holes) would make it as durable as any other circuit. The only issue might be if the layout was too big for a standard piece of perfboard. You could also try gluing it to a sheet of laminex, then drilling holes for the components. Any hard, thin, insulating material which could withstand the heat of soldering would do. _________________ What makes a space ours, is what we put there, and what we do there. |
macumbista
Posted: Fri Feb 12, 2010 5:56 am Post subject:
Pete came over to Berlin for a workshop last summer with some really HUUUUGE paper theremin circuits he called Deerhorns (after the Jaegermeister deer, I think...).
He had people take very heavy cardboard, fold the two-sided paper circuit (making sure front and back sides lined up), wrap it around the cardboard and fix it with spray adhesive. Then they used a heavy sewing needle (need-awl) to punch holes for the components. The finished circuits looked pretty solid and hung freely from cables in the exhibition space. He also puts them on fabric panels and sews those together.
So I'd say if they are robust enough to survive outside an enclosure, they could live pretty much forever if you mounted them firmly inside one.
Only problem with doing them on perfboard would be that I don't know if Pete uses any kind of raster when designing, so the holes might not match his rather freehand approach. Kind of a metaphor for the artist himself I think  _________________ Esoteric drones and nonlinear distortion
macumbista.net |
blue_lu
Posted: Fri Feb 12, 2010 6:14 am Post subject:
Hi Macumbista,
great to hear about someone attending peters workshop. I am a great fan of his work the cocolase delay (now cocostuber) is one of the most out there designs I have seen to this date. unfrotunately I am not yet able to afford them, so the possibility of building something that peter came up with is a great experience to have.
so how was the workshop? did you build some small noisemakers to take home, or what was it about? do you know if there any more plans of peter doing workshops in berlin (eu)?
Thanks, Lu
p.s.: ich bin auch Berliner - momentan allerdings in fränkischem Exil! |
macumbista
Posted: Fri Feb 12, 2010 6:23 am Post subject:
Hi Lu,
here's the proposal Pete sent us:
http://www.ciat-lonbarde.net/deerhorn.pdf
(Yes, it's public on his website.) The Deerhorns themselves were printed on something like A3 paper, so quite big!!!
Best im Exil!
D. _________________ Esoteric drones and nonlinear distortion
macumbista.net |
blue_lu
Posted: Fri Feb 12, 2010 6:39 am Post subject:
Thanks for the link - interesting
Uncle Krankus - thanks for the tip! |
prgdeltablues
Audio files: 12
Posted: Tue Feb 16, 2010 3:02 am Post subject:
I've built a few of Pete's smaller circuits, and laboriously soaked the paper in water and removed it from the circuit - happy hours with tweezers!, I then mounted the bare circuit on hardboard using acrylic paints/paste - incorporating the electronics onto the surface of a painting. I drilled holes through the board for short lengths of brass rod - about 3mm diameter - for the contact points. Likewise mounted a speaker from the back, with a painted grille showing on the front. The wiring between circuit and contacts, and the battery, are hidden behind the painting.
Acrylic paste is a pretty good adhesive. You do have to let it dry thoroughly though - the first time I tried the circuit too soon, and it didn't work - unset acrylic has a resistance in the high k/low megaohm range! Once dry it is an insulator.
His circuits are brilliant noisemakers. I now need to find a way to incorporate them in my embryonic modular. |
macumbista
Posted: Tue Feb 16, 2010 3:07 am Post subject:
@prgdeltablues:
photos, me boy! we want photos!!!!!! _________________ Esoteric drones and nonlinear distortion
macumbista.net |
Inventor
Audio files: 267
Posted: Tue Feb 16, 2010 3:32 am Post subject:
I saw these paper circuits at EM09. They were incredible. It's truly an alternative style of circuit prototyping.
macumbista
Posted: Tue Feb 16, 2010 3:46 am Post subject:
Just in case anybody is at this moment thinking "WTF are they talking about???":
http://www.ciat-lonbarde.net/paper/index.html
Of course, Pete's site is pretty WTF all by itself... _________________ Esoteric drones and nonlinear distortion
macumbista.net |
blue_lu
Posted: Tue Feb 16, 2010 10:18 am Post subject:
+1 on the pics!  |
Inventor
Audio files: 267
Posted: Wed Feb 17, 2010 2:13 am Post subject:
I like how you can soak the paper in water when you're finished, dissolving it and leaving a skeleton circuit that works! I'd like to see something like that done in three dimensions. Wow, how creative could that be?
-minus-
Posted: Wed Feb 17, 2010 7:15 am Post subject:
I agree Inventor... 3D soaked versions would be nice. I liked the mention of this paper circuit thing on your show yesterday. Would be nice perhaps to do an interview with Peter and broadcast it on your show... just a thought. |
Inventor
Audio files: 267
Posted: Wed Feb 17, 2010 12:11 pm Post subject:
-minus- wrote: | I agree Inventor... 3D soaked versions would be nice. I liked the mention of this paper circuit thing on your show yesterday. Would be nice perhaps to do an interview with Peter and broadcast it on your show... just a thought. |
I would be happy to interview anyone with experience creating paper circuits. All you need is the free Ventrilo client which is easy to set up.
I thought up a way to do this in 3D. You make paper wads out of ordinary printer paper, then secure and solder your circuit building as you go. When your monstrosity is done and tested, you soak it to remove the paper. That is too cool for school, I gotta try it!
fluxmonkey
Posted: Wed Feb 17, 2010 8:20 pm Post subject:
from peter's website. these circuits are the bee's knees! _________________ www.fluxmonkey.com |
droffset
Joined: Feb 02, 2009 Posts: 515 Location: London area
kriista
Posted: Sat Feb 20, 2010 4:12 pm Post subject:
macumbista, did you attend the workshop and make a deerhorn?
if you did, could you post pictures of the instruments. theres some components on the paper circuit that aren't explained in any of the paper circuits as to what they are, so seeing a completed one would go a long ways towards figuring that out.
thanks |
macumbista
Posted: Sat Feb 20, 2010 4:27 pm Post subject:
kriista wrote: | macumbista, did you attend the workshop and make a deerhorn? |
Hi Kriista... actually I was one of the organizers of the workshop, and was waaay too busy to actually be able to sit down and make one. The PDF I linked to isn't the actual paper circuit, it was more a proposal from Peter about what he would do. If he hasn't made the actual circuit and partslist public, it's probably because he wants to retain the possibility of doing further workshops with them. What I would recommend is that you contact him personally and see if he is willing to share with you.
There is a certain amount of obscurantism in his circuits, with very non-standard symbols and a rather personal mythology, which makes deciphering them quite challenging!
Otherwise, you could search the tag "sommercampworkstation" or "sommercamp workstation" in Flickr and see if any of the participants shot photos of the builds and work from there.
Best!
Derek _________________ Esoteric drones and nonlinear distortion
macumbista.net |
macumbista
macumbista
Posted: Sat Feb 20, 2010 4:43 pm Post subject:
Tangentially, there were several really interesting folks on that workshop, called sommercampworkstation, including Jessica Rylan with some chaos generators (posted in the Ian Fritz Chaos topic) and Tore "Origami" Boe with his Acoustic Laptops (wooden boxes and found objects amplified by a contact microphone) project:
More info on Acoustic Laptops here: http://www.museumsnett.no/alias/origami/boe/2.3-010.html _________________ Esoteric drones and nonlinear distortion
macumbista.net |
kriista
Posted: Sat Feb 20, 2010 5:54 pm Post subject:
He has that design on his webpage too. At least he did before. Yeah he had it up as 'euro deerhorn'.
He never made any partlists for any of the paper circuits. They are, generally, 'self-service'. The first one (lil-sidrassi) has a certain amount of explanation, but the rest just are as they are. You can make sense of them by comparing them, or reading the instructions for other things (rollz5).
I agree that he builds a sort of unclearness into the designs, which is nice. You figure it out, and you can build it. Which is why I'm posting on here, to see if anyone can chime in with what they've figured out.
I should've clarified more where I was coming from at the start, but I'm a big peter/ciat fan. Here is my collection of his instruments:
http://www.rodrigoconstanzo.com/Ciat-Lonbarde.html
macumbista wrote: | kriista wrote: | macumbista, did you attend the workshop and make a deerhorn? |
Best!
Derek |
macumbista
Posted: Sat Feb 20, 2010 6:02 pm Post subject:
Wow! That's some nice documentation there! _________________ Esoteric drones and nonlinear distortion
macumbista.net |
kriista
Posted: Sat Feb 20, 2010 6:58 pm Post subject:
Thank you! |
prgdeltablues
Audio files: 12
Posted: Thu Feb 25, 2010 12:08 pm Post subject:
Ok, here are some pictures of my paper circuits. Some parts of a Rollz-5 - on the paper, and after stripping the paper away. Then a Lil Sidrassi embedded in an acrylic painting. The contact points are short lengths of brass rod sticking up about 15mm. Played with fingers- best when wet. The speaker is behind the red blob in the bottom left corner. The red spot on the right is a push-button on-off switch for the battery.
(Sorry about the file sizes, first go at posting images)
Peter
Description: |
Filesize: |
32.26 KB |
Viewed: |
21275 Time(s) |
Description: |
Filesize: |
35.95 KB |
Viewed: |
21275 Time(s) |
Description: |
Filesize: |
22.69 KB |
Viewed: |
21275 Time(s) |
Description: |
Filesize: |
23.39 KB |
Viewed: |
21276 Time(s) |
Description: |
Filesize: |
25.77 KB |
Viewed: |
21275 Time(s) |
kriista
