diy loop sampler
Page 1 of 1 [17 Posts]
solusarpus
PostPosted: Sun Nov 16, 2008 2:31 am    Post subject: diy loop sampler
Subject description: diy loop sampler
hi, this is my first post here. Does anyone know of available schematics for a loop sampler, ala an akai headrush or boss loop station? I would like to build my own effects unit, a box with some lfos, a cv analog delay, and a loop sampler; I can't find any info on diy loop samplers. thanks everyone!!
Tasmanian Alkaloid
PostPosted: Sun Nov 16, 2008 6:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello!
This is a fantastic resource from forum member Bugbrand. You'll find some schematics for a lo-fi sampler/looper, and if you dig around, i am fairly sure he's got notes on his work with ISD sampling chips. I hope this helps you out!
http://www.bugbrand.co.uk/pages/electronics.htm
And also here's a link to the schematic archive of Experimentalists Anonymous, there is tonnes of stuff in there (including a couple of loop/ sampling circuits)!
http://experimentalistsanonymous.com/diy/Schematics/
solusarpus
PostPosted: Sun Nov 16, 2008 9:08 pm    Post subject: thanks! Reply with quote  Mark this post and the followings unread
thanks so much! that second link is amazing- first is really good too.
Lorenzo
PostPosted: Wed Jan 28, 2009 4:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello!
Bugbrand have a new site... I don't find the sampler on this new site!?
have you a direct link?
Looking for a cheep looper I found a kit for a recorder/player ICED4003
I think it is a modern version of ICED25xx ... but I don't understeand if it have a loop function .pdf here [click]
Lorenzo
PostPosted: Tue Mar 23, 2010 3:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
I found this analog lo-fi looper
based on an ISD 2560
Yes!
Oh Yeah!
Wow!
max92
PostPosted: Wed Sep 15, 2010 4:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe this thread (evan though old) fitted better than this:
http://electro-music.com/forum/post-307474.html&highlight=#307474
What I search is a Looper module which can record and playback and sync loop length to clock signal. Would that be possible?
Lorenzo
PostPosted: Sun Sep 19, 2010 4:26 am    Post subject: Reply with quote  Mark this post and the followings unread
it would be nice... but I think you have to look for a Korg CaosPad Crying or Very sad
Yes!
Oh Yeah!
Wow!
max92
PostPosted: Sun Sep 19, 2010 3:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
but I want it in modular form! Rolling Eyes
Lorenzo
PostPosted: Fri Sep 24, 2010 12:37 am    Post subject: Reply with quote  Mark this post and the followings unread
ah modular... ableton live + looper? Wink
(i'm joking...)
Yes!
Oh Yeah!
Wow!
stolenfat
PostPosted: Sat Sep 25, 2010 3:54 am    Post subject: Reply with quote  Mark this post and the followings unread
this is just an idea, but something i've always wanted to try.
It revolves around a modified cheap tape player and one of those really short loop tapes you can get.
the idea is to mod the tape player some how through the use of control voltage switches (...4066? maybe even mr mimms 555 switch) to bridge the connection between the record function contacts.
if the tape player is always on play, and you can figure out how to make the above idea work, you could have yourself a wonky CV tape looper.
Plus, i've had lots of success 'circuit bending' tape recorders to add distortions and even slowing the tape speed to a crawl.
Lorenzo
PostPosted: Sat Sep 25, 2010 12:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
WOW
Yes!
Oh Yeah!
Wow!
stolenfat
PostPosted: Thu Sep 30, 2010 2:59 am    Post subject: Reply with quote  Mark this post and the followings unread
you gonna try it lorenzo?
I've seen you do some pretty impressive stuff in years past, i bet you could pull it off with flying colours Smile
Lorenzo
PostPosted: Fri Oct 01, 2010 5:39 am    Post subject: Reply with quote  Mark this post and the followings unread
It could be a very interesting add-on for my Barbie karaoke recorder!!! !!!
I have many projects to complete yet Rolling Eyes
... this (and/or this) could be the next!!
Winter is very long here Very Happy Smile Crying or Very sad .... Wink
Yes!
Oh Yeah!
Wow!
Taylor
PostPosted: Tue Oct 12, 2010 1:19 am    Post subject: Reply with quote  Mark this post and the followings unread
http://tech.thetonegod.com/payback/payback.html
http://tech.thetonegod.com/payback_v11/payback_v11.html
These are 2 nice lo fi loopers using 2 different chip series. I made a PCB layout for the Payback 1, using 25xx chips. I've attached the files to this post.
It's not easy to find the chips these days, unfortunately, but hopefully this is useful to somebody.
payback traces updated.pdf
 Filename:  payback traces updated.pdf
 Filesize:  13.05 KB
 Downloaded:  599 Time(s)
payback components updated.pdf
 Filename:  payback components updated.pdf
 Filesize:  14.29 KB
 Downloaded:  604 Time(s)
payback components traces updated.pdf
 Filename:  payback components traces updated.pdf
 Filesize:  19.97 KB
 Downloaded:  527 Time(s)
payback components pads updated.pdf
 Filename:  payback components pads updated.pdf
 Filesize:  15.61 KB
 Downloaded:  611 Time(s)
Lorenzo
PostPosted: Tue Oct 12, 2010 3:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Taylor wrote:
25xx chips [...] It's not easy to find the chips these days, unfortunately,
My dealer says me that ISD25xx has been improved for many years.
They upgraded internal memory and sampling frequency...
I think he says to me that ISD4003 is a modern version of 25xx chips...
Yes!
Oh Yeah!
Wow!
PostPosted: Tue Oct 12, 2010 5:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Anyone seen this?;
Cool
http://www.etsy.com/listing/52993389/wicks-looper-wicked-sound-loops
ACHTUNG!
Taylor
PostPosted: Tue Oct 12, 2010 11:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Right, exactly. Other chip series have been designed since the 25xx, so the 25xx is obsolete and therefore hard to find. The schematics above will not work with 4003 or anything else besides 25xx.
