40106 oscillator trouble
Page 1 of 1 [3 Posts]
computer at sea
PostPosted: Mon Jul 19, 2010 11:02 am    Post subject: 40106 oscillator trouble Reply with quote  Mark this post and the followings unread
Has this happened to anyone else?
Occasionally when breadboarding a circuit (and sometimes on a soldered circuit) with a few oscillators off the 40106 one will stop working. As far as I can tell when this happens there aren't loose connections.
I can make oscillators on other pins but not in the spot that's the root of the trouble.
Any thoughts would be appreciated.
PS: 9volts
tjookum
Audio files: 26
PostPosted: Mon Jul 19, 2010 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah well, I would say part of the deal of getting 6 oscillators out of a 30c chip Smile .
But the more correct answer would be static from your hands. cmos are very sensitive to this and you might have fried a portion of the chip.
Hunter S. Thompson
movies
noise
Ajax
PostPosted: Mon Jul 19, 2010 3:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you arent using all of the inputs, tie them to ground with a pulldown resistor. Without em, things can get a bit wonky Razz Also try moving the chip to another area on the breadboard, just in case.
