Lunetta visuals
Page 1 of 2 [37 Posts]
electri-fire
G2 patch files: 4
PostPosted: Sat Jul 31, 2010 5:55 am    Post subject: Lunetta visuals
Subject description: Idea to Lunetta video production
There's circuitbent SK-1's with video output.
http://www.youtube.com/watch?v=JU_SB88RXTw
The video output is connected to (I think) a chip select line at the SK-1's RAM/ROMs . Those put out 5V squarewaves. Waves are depending on sound select and keypress.
Here's a schematic.
http://www.getlofi.com/wp-content/uploads/2007/02/casio_sk-1_video_out-2.JPG
This has led me to the idea a Lunetta could be used to generate visuals, but it will take me some time to do it. You fast builders may give it a try.
tjookum
Audio files: 26
PostPosted: Sat Jul 31, 2010 7:43 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for making that connection electri-fire.
Did a little search to find out what kind of voltages are required and how the signal works:
http://www.rickard.gunee.com/projects/video/pic/howto.php
hmmm, seems like all you have to do to get something going is limit the voltage to 1V. sweet!
Hunter S. Thompson
movies
noise
electri-fire
G2 patch files: 4
PostPosted: Sat Jul 31, 2010 4:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmmyeah, but here it says 2 Volts.
http://electronics.howstuffworks.com/tv9.htm
It is of minor importance as it would be most interesting to have a potmeter to tweak the analog level anyway.
At EM2010 there will be a "Lunetta Maelstrom" performance, so I still have a month to come up with some kind of interface to connect the Lunettas IF there will be a beamer available at the theater stage (as is still not the case at this moment).
Options would likely be Composit video , S-video or VGA.
-minus-
PostPosted: Sat Jul 31, 2010 8:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh... There's a thread here on E-M somewhere with some circuit bent TV stuff.... but I cant remember where. Has anyone tried to plug a lunetta output into a TV yet? I'd be interested to try this but don't have a TV.
droffset
PostPosted: Sat Jul 31, 2010 10:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
I started reading up on how to do the proper synch signals for a TV signal but couldn't really get my head around it. I think if someone had a plain language explanation of it with maybe a basic schematic.
Alternately, maybe there's a simple video toy that can be hacked into to just make use of the signal format stuff.
Edit: Spelling mistakes.
tjookum
Audio files: 26
PostPosted: Sun Aug 01, 2010 1:39 am    Post subject: Reply with quote  Mark this post and the followings unread
It says somewhere gijs uses a seperate hardware device with a time base corrector(tbc). some more info here:http://www.karlklomp.nl/inf/faq.html
It says a device with tbc will stop the picture from scrolling, very important.
Of all the cables and connectors in the house I don't have one for video Sad, really want to try this
Hunter S. Thompson
movies
noise
tjookum
Audio files: 26
PostPosted: Sun Aug 01, 2010 9:47 am    Post subject: Reply with quote  Mark this post and the followings unread
ok got myself a cable and decided to just wing it and see if it will accept squarewaves right away. Hooked up a oscillator, added a 1n4148 and a 100k pot and measured the voltage at 0.5-0.7 volts. I was really carefull about this cause I only have 1 working tv Wink.
And.....nothing happened, no surprises there. I think it mostly has to do with my quite modern THOMAS bargain tv, it just says no signal. I guess for this to work you would need an older model wich just displays whatever it's fed.
And then there's still the little issue about the sync function, but it seems someone has done all the hard work for us:
http://www.arduino.cc/playground/Main/TVout
There might be something out there for pic too.
Hunter S. Thompson
movies
noise
RF
Audio files: 28
PostPosted: Sun Aug 01, 2010 8:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
well - good try anyway, tjookum.... Smile
Thanks for the progress report.
bruce
www.sdiy.org/rfeng
adambee7
PostPosted: Mon Aug 02, 2010 10:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
casper electronics knows a thing or two about video manglement. He got old nintendo consoles and casios. From my college days i remember playing around with a video effects mixing deck thing which used to be used at the BBC and some of the effects are similar to bent gear. Very lofi. Very Happy Very Happy
PostPosted: Tue Aug 03, 2010 7:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Wasn't there a guy who was going to circuit bend his TV via the flyback transformer?
I never heard back from him...
tjookum
Audio files: 26
PostPosted: Tue Aug 03, 2010 8:39 am    Post subject: Reply with quote  Mark this post and the followings unread
haha, I saw it too and it looks very tempting but anything involving deadly currents is not for tinkerers like me...
Rolling Eyes Im kind of hoping someone drops in who actually used the composite video signal mod, Im really interested in low tech video signals but just can't get my head wrapped around this one.
Hunter S. Thompson
movies
noise
electri-fire
G2 patch files: 4
PostPosted: Tue Aug 03, 2010 2:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Exhaustive list of useful videocircuits.
http://www.epanorama.net/links/videocircuits.html
slacker
PostPosted: Wed Aug 04, 2010 3:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't know if it's any use but the CMOS Cookbook has a circuit snippet for generating a composite video signal using a CD4066. It's supposed to be hooked up to something that generates the proper sync signals, but you might get something out of it just hooking up random signals.
If I get chance I'll try it out and see if I can get anything useful out of it.
droffset
PostPosted: Wed Aug 04, 2010 4:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
I had a similar thought Slacker about making use of an existing video signal to 'borrow' the hsynch signal. The hsynch part of the signal seems to be the important bit and is the only negative going portion. So if it's inverted and maybe amped a bit it'll be a single positive going pulse that a circuit can be built around to use as a trigger to switch between the existing signal and whatever lunetta madness you'd want to insert. Not sure if that makes sense, but 4066 would do it.
edit to add:
http://www.videouniversity.com/articles/engineering-primer
http://www.maxim-ic.com/app-notes/index.mvp/id/734
http://www.maxim-ic.com/app-notes/index.mvp/id/1184
http://www.djdesign.com/tutorial/sync.html
slacker
PostPosted: Thu Aug 05, 2010 11:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Success Very Happy
Hooked up the circuit from the CMOS Cookbook and it works. The original circuit is supposed to take a 60Hz V sync signal and a 15,750Hz H Sync signal together with a serial stream of 1s and 0s into the video input and produce a monochrome composite output. The H and V sync input had RC one shots on the inputs to generate the correct length pulses, but I couldn't get it to work with these on so I ditched them.
Happily just feeding a bunch of clock signals into the 3 inputs produces an output that my TV will display Smile
The picture's monochrome, but it's a start. I didn't have time to get any video so a photo will have to do for now.
Obviously, if you build this, you do so at your own risk and I take no responsibility for any damage you do to your TV, your Lunetta or most importantly yourself.
 Filesize:  131.49 KB
 Viewed:  338 Time(s)
 Filesize:  41.03 KB
 Viewed:  369 Time(s)
tjookum
Audio files: 26
PostPosted: Thu Aug 05, 2010 2:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Exclamation thank you so much slackers, that looks great! Really great that you found the time and did the effort to get this one working thumb up
Im gonna get myself a 4066 and give it try.
Hunter S. Thompson
movies
noise
electri-fire
G2 patch files: 4
PostPosted: Thu Aug 05, 2010 5:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Interesting, thanks Slacker.
I already had some idea the V and H sync not to be essential as video outputs of circuitbent stuff don't have that either. Apparently, as long as you have "some" Lows available, they'll somehow be interpreted as sync signals.
Considering V sync , H sync and Video can be random Lunetta signals, I wonder what is the absolute minimum amount of circuitry necessary.
V sync and H sync let through a 5V High when both are High. Else Low.
The Video signal bypasses the 1k5 resistor. So the composite video output is one of three options: Low, when In is Low, and two levels depending on the state of the Video signal.
As the level determines the brightness more level options could maybe lead to more varied visuals. Maybe instead of the 1k5 resistor use a smaller one (47 ohm?) and a potmeter, 1k or 5k.
And as we'd be varying voltage anyway, maybe an R/2R or passive resistor mixer could take in more Lunetta signals to provide more level options.
 Filesize:  33 KB
 Viewed:  370 Time(s)
-minus-
PostPosted: Thu Aug 05, 2010 10:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Exciting developments! I'll be watching this one with interest. After nearly 3 years without TV, I'm almost tempted to pick up an old one and try this. Best thing since TV! Laughing
Inventor
Audio files: 267
PostPosted: Fri Aug 06, 2010 6:25 am    Post subject: Reply with quote  Mark this post and the followings unread
I too am excited by this possibility. I see a really fun and useful set of circuits emerging to address this technical hurdle and give us really cool video of our Lunettas! It's also fun to read up on the thread.
Mathe, please don't go overboard trying to get us video for em10 as I don't want to see you stressed out at the festival. We have enough to do with documentation and stuff, so chill bro!
Looking forward to future developments on this one.
Les
electri-fire
G2 patch files: 4
PostPosted: Fri Aug 06, 2010 6:33 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm good Les, this is what I love to do, and apart from "domestic chores" I got all day to do it. I spend too much time doing research and "planting" ideas though, and not nearly enough to actually build something. Ah well...
Inventor
Audio files: 267
PostPosted: Fri Aug 06, 2010 6:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool man, well then enjoy!
Les
slacker
PostPosted: Fri Aug 06, 2010 9:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the comments, it's a fun thing to mess about with, makes an interesting little modulator for audio as well.
electri-fire thanks for redrawing the schematic, makes it easier for other people to see how it works.
Your simplified version should work, the V and H switches are just making an AND gate so any stream of pulses should work just as well. Replacing the 1k5 with different values does change the brightness level, like you suggested. As far as I can tell anything that produces voltages in the correct range with the occasional 0 volts to act as a sync should work.
Adding colour will be trickier I think.
tjookum
Audio files: 26
PostPosted: Fri Aug 06, 2010 9:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Another succes, got mine working today.
I followed the slacker schematic and with my modern tv it wouldn't recognize the signal but I could see the image changing. After switching to an older set it worked perfectly the first time, bands of monochrome goodness passing over the screen. Using some very high frequency clocks I almost got the image stationary and it worked very intuitive a little like tuning a drone.
Because I had no 1k5 and 100r I used 2 2k trimpots, at first dialed in on the same resistance wich gave nice black and white. But by increasing the resistance I got more definition and it would follow the music better and with lower resistance it started going into red and some different greys.
I shot a video where im feeding it a signals from a melodygen going through a YAVCO(probably a xor in there too). I started with the high resistance setting and somewhere halfway switched to lower resistance with some red showing through. The rainbow prism effect is due to my crappy camera and it has a lot more fine detail in real life but it shows what can be done.
Thank you guys for the inspiration and the schematic, Ive had a blast playing with this new toy all afternoon.
If I find the time Im going to try to dial down the exact frequency for the sync inputs.
Hunter S. Thompson
movies
noise
slacker
PostPosted: Fri Aug 06, 2010 10:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Great video, I love how in the Lunetta world things can go from ideas to reality so quickly.
Looks like you've been able to get a much brighter image than I have, I'll have to experiment with resistor values.
I had a thought about getting colour. The colour signal is something like a 3MHz sine wave superimposed on the monochrome signal, so you might get something if you fed a fast enough clock into pin 2 instead of just connecting it to 5 volts and then AC couple or lowpass filter the output a bit.
tjookum
Audio files: 26
PostPosted: Sat Aug 07, 2010 7:42 am    Post subject: Reply with quote  Mark this post and the followings unread
What kind of system are you using? Im using PAL wich maybe very different from NTSC.
I think the 100R is too low and just there as a safety measure, with my 2k trimmer I can turn it all the way up and it gets really bright and perfect monochrome black and white.
I did some experiments today to get the V sync right. I made a 60hz 555 timer and fed the output through a inverter to make a very narrow pulse. I can see the timing is almost correct because I can use a trimpot to steady the line on the screen. But I think it requires a very precise pulse length to lock on and without an oscilloscope it's nearly impossible. All I get is a white line wich pulsates to the audio and slowly wobbles up and down on the screen. Does the cmos cookbook have a suggestion for a circuit to generate those pulses?
Im really curious how you get on with colour, would be nice to have a change from the b&w.
Hunter S. Thompson
movies
noise
