How do you wire a normalized jack?
Page 1 of 1 [4 Posts]
RobotDad
PostPosted: Sat Aug 28, 2010 12:48 am    Post subject: How do you wire a normalized jack?
Subject description: OK, simple but I'm just not sure...
Maybe not the right forum, but it seems this is the most gnarly DIY one so feels right, Smile And yeah, I'm fairly new at this stuff, but I've successfully made a WSG and a gristelizer so I'm ready to start building something bigger and I really want to understand how to properly normalize a jack before making my next parts order. Very Happy
First off I recognize that this must be obvious as I can't find any detailed explanations anywhere... I understand what a normalized jack is but I have no idea how they should be wired. I'm looking at 3.5mm jacks, will mono work or do I need stereo type? I'm assuming mono will work but I'm confused about exactly how the mechanism of inserting the cable changes the connection.
I see a lot of mentions of needing to carefully label a panel to remember which jacks are normalized. Are there any easy blinky alternatives? For example, would there be a simple way to wire an led to remain lit when the jack was in its normal state and turn off when a cable is inserted?
Also, does closed or open style matter? I've noticed closed seem to be cheaper, is there a disadvantage with going with that style?
slacker
PostPosted: Sat Aug 28, 2010 10:05 am    Post subject: Reply with quote  Mark this post and the followings unread
For normalised jacks you need ones that have switched contacts, these have 2 contacts for each connection, so for a mono jack 2 for the tip and 2 for the sleeve. The 2 contacts are arranged so that when nothing is plugged in they connect together, when you insert the plug it breaks the connection and the jack works just like an ordinary one.
These are often referred to as switched or normally closed jacks, like these for example http://www.rapidonline.com/Cables-Connectors/Connectors-Audio-Video/Jack/3.5mm-Mono-PCB-jack-socket/63491
If you wanted to add a LED to indicate that the jack was normalised you could do it like this. Connect the LED and a current limiting resistor between power and the switched sleeve connection, and connect the other sleeve connection to ground. When nothing is plugged in the LED is connected to ground so it will light up and when you plug a jack in you break the connection and the LED goes off.
RobotDad
PostPosted: Sat Aug 28, 2010 9:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good explanation and knowing the proper term is a big help. I found little hunting on normalized, but switched gives a lot more results. These two pages were pretty good in terms of showing the schematic/picture of how these work.
http://www.prestonelectronics.com/audio2/ttip/problemjack.shtml
http://www.neutrik.com/content/technicalsupport/faq.aspx?faqId=205_747846926
Now I just need to decide if I stick with 3.5 or go 1/4 instead. Better manufacturers like Neutik and Switchcraft seem to only supplt 1/4 (Cliff isn't readily available from US suppliers that I saw). Or I may just give up on normalizing anything and just go (with) bananas.
Audio files: 309
PostPosted: Tue Aug 31, 2010 6:04 am    Post subject: Re:How do you wire a normalized jack? Reply with quote  Mark this post and the followings unread
jerryp941 wrote:
Well,to wire a normalized jacks,switched connections are inter-correlated with each other and swiched into a plugin so that it breaks the connection.With the Auto/Manual switch set to Manual, the revs can be swept from minimum to maximum. Set the switch to Auto, and in-built logic will simulate a three ratio transmission, gearing up twice during an upward sweep, and gearing down twice during a downward sweep.The left and right outputs are fed to a pair of jacks that have their normalized connections wired so that insertion into a single jack will give a mixed .You can play the module from a keyboard, though the results may not be what you expect, as the clock controls the triggering of the module's two fixed pitch sound sources.
Answer was copied from http://www.cgs.synth.net/modules/v8.html it seems .. and I didnt like jerry's sig .. posting from the India too .. some new SEO trick ... needs aban.
