jnuaury
Audio files: 9
LektroiD
Joined: Aug 23, 2008 Posts: 1019 Location: Scottish Borders
Posted: Thu Nov 18, 2010 3:19 pm Post subject:
Looks interesting. I have some LM1496's in my stash too. I guess a redraw of the schematic is in order. If you get this finished, let us know what it sounds like (maybe an mp3 demo), and if possible your revised 1496 schematic would be quite handy too. _________________ LektroiD |
JAMESveeder
Posted: Thu Nov 18, 2010 3:25 pm Post subject:
Yes I'd definitely like to see how this turns out, or read up on some more info about it |
Joined: Apr 03, 2004 Posts: 24468 Location: The Netherlands, Enschede
Audio files: 297
Posted: Thu Nov 18, 2010 5:19 pm Post subject:
It is a ring modulator of sorts .. but it is claimed to leave only one side band ... as such it would behave like a Bode frequency shifter .. I'm not sure how well it would suppress a sideband though ... it's a lot simpler than an actual Bode frequency shifter .. but then again ... a ring modulator does shift frequencies.
Just to be sure ... this is something different than a pitch shifter .. a pitch shifter will leave harmonic relations as they are, where a frequency shifter does not.
http://acapella.harmony-central.com/archive/forums.html/t-1030019.html has some info. _________________ Jan
Dego
Posted: Thu Nov 18, 2010 5:44 pm Post subject:
The paia 4710 Balanced modulator uses a mc1496. Its more than like ringmodulation then... But it is used as a VCA as well.
Audio files: 297
Posted: Thu Nov 18, 2010 7:16 pm Post subject:
Used as a VCA, yes ... basically ring modulation and VCA is the same thing ... a multiplier .. amplitude modulation, AM. Only thing is that many analog VCAs can use positive modulation voltages only, making it a two quadrant multiplier ... whereas for ring modulation you need four quadrant multiplication (where the amplitude controlling CV can be negative too).
Another difference would be that a VCA usually is used to apply an envelope, that is low frequency modulation, whereas for ring modulation typically audio rate is used ... but nothing stops you to control a VCA at audio rates .. and some simple trigonometry will show the frequency shifting stuff happening then. _________________ Jan
jnuaury
Audio files: 9
Posted: Sat Nov 20, 2010 8:03 am Post subject:
so i just made a parts order a couple days ago and totally forgot to pick up those chips! oops.
im familiar with various ring mods that use this chip, but am really curious to see how this "frequency shifter" will react
im tempted to pull the chip out of my doepfer ringmod to test it out sooner _________________ az/gde
Flickr
YouTube |
