X-4046 VCO Page is Up
Page 5 of 7 [175 Posts]
TekniK
PostPosted: Fri Mar 04, 2011 4:12 am    Post subject: Reply with quote  Mark this post and the followings unread
My mate told me the layout,yes its abouth the sine shape
spitfire
PostPosted: Sat Mar 05, 2011 4:23 am    Post subject: Reply with quote  Mark this post and the followings unread
my sine wave doesn't work at all
PostPosted: Sat Mar 05, 2011 5:31 am    Post subject: Reply with quote  Mark this post and the followings unread
so if no-one who built itwith ryk's layout wants to chime in, i recommend doing a debug as usual. grab out the original schematic from thomas henry and check the board against it, starting with the sin shaper portion. check all connections and values, transistor orientation an so on. i call this greenlining, since i use a green pen to check off everything on the schematic that is okay.
Badcluster
PostPosted: Mon Mar 07, 2011 7:19 pm    Post subject: Vco
Subject description: Vco
Fonik can you share your PCB?
Tks
magneticstripper
PostPosted: Mon Mar 07, 2011 10:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
There is an error in the sine shaper with the connection of the 10k feedback resistor.
PostPosted: Wed Mar 16, 2011 3:22 pm    Post subject: Re: Vco
Tks
i got a go from thomas! so i will start to work on it. for me i made two layouts, one for the core and one for the waveshapers. i could combine them (which would safe money and logistic efforts), or leave them seperate (which would allow the usage of the shaper for other saw core vco's).
suggestions?
a100user
New postPosted: Thu Mar 17, 2011 12:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Excellent news Fonik and a big thanks to Thomas too Very Happy
http://a100usersplace.blogspot.com/
whomper
New postPosted: Fri Mar 18, 2011 6:26 am    Post subject: Reply with quote  Mark this post and the followings unread
I would very much like to have shapers stand alone as I am looking to add 2-3 shapers to my already crowded modular.
Erez Yaary
Buy my CDs at http://www.mellowjet.de
New postPosted: Fri Mar 18, 2011 11:57 am    Post subject: Reply with quote  Mark this post and the followings unread
this is how the PCBs look like (without any changes). if most would be fine with them i could make them available next month...
mattias
New postPosted: Fri Mar 18, 2011 12:13 pm    Post subject: Re: Vco
Subject description: save energy
suggestions?
I'm selfish and vote for the solution that consumes the least energy of fonik, so he can come up with further cool projects. Wink
Red is black and plus is minus. http://www.bild-schall.com
Danno Gee Ray
New postPosted: Fri Mar 18, 2011 5:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
The way they are now would be good for me.
I second Mattias' sentiments !
vtl5c3
New postPosted: Sun Mar 20, 2011 9:30 am    Post subject:   Reply with quote  Mark this post and the followings unread
Frikkin Awesome!!! I'll order at least two sets.
diablojoy
New postPosted: Sun Mar 20, 2011 9:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
good enough for me too mathias
will of course also take 2
perhaps a short announcement on your forum page listing a link back to here
for interest to be expressed if it's ok with thomas of course
i almost didn't see it
i think many might be interested and may miss it
dnode
New postPosted: Tue Mar 29, 2011 4:10 am    Post subject: Reply with quote  Mark this post and the followings unread
I would definitely be interested in two boards! With separate waveshaper boards I would even buy two shapers extra!
Thomas, Scott and Matthias, great work!
grtz, dnode
New postPosted: Tue Mar 29, 2011 5:58 am    Post subject: Reply with quote  Mark this post and the followings unread
i just came back from a business travel and will take care of this project from now on...
reve
New postPosted: Tue Mar 29, 2011 11:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Awesome!
I'd be in for 2-8 cores depending on price and a couple shapers.
- r. mosquito
SynthDIY Synthpop -> http://www.reverbnation.com/photovoltaik
raoulblues
New postPosted: Thu Mar 31, 2011 10:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
2 of each for me as well, thanks Matthias
New postPosted: Thu Mar 31, 2011 11:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks, guys.
place orders her, please:
http://electro-music.com/forum/topic-47213.html
we should not pollute this thread with the PCB stuff, but use it for circuit related talk. Very Happy
spitfire
New postPosted: Sat Apr 23, 2011 6:56 am    Post subject: Reply with quote  Mark this post and the followings unread
hello again.
I get about one octave with my x4046. Is that because I didn't matched the transistors, or because not +-15V, but -+12V, or because my CD4046 is not the right IC ?
MirlitronOne
New postPosted: Mon May 02, 2011 5:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Scott, did you ever test the RCA 4046s? Apologies if I missed the results somewhere.
Life is like an analogue sequencer. Twiddle the knobs to avoid boredom.
Rykhaard
New postPosted: Thu May 26, 2011 2:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Now that I've come back to designing and building again a few weeks ago, I found the quad PnP printout of the 4046 VCOs of mine. I searched for the error mentioned (in the Sinewave section).
In case it matters to anyone that still has one of their's lying around with the non-working Sinewave output - there's a 10k feedback resistor at the opamp connected to the transistor pair. It's wired between (on the PCB) the + and - pins of the opamp. It should be the - and output pins instead.
As to the error mentioned about the power supply connections to the opamps being incorrect - all of those connections, were just double verified, as correct.
I'll be building at least 1 of these VCOs as well as soon as I finish the alpha version of my Moog 960 sequencer clone / upgrade. (Hopefully within a few days from now.)
Sebo
New postPosted: Thu May 26, 2011 4:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Rykhaard for the update, I etched a PCB from your layout, and will start to build the VCO soon.
Sebo
My Music:
Aum Generator
New postPosted: Sat Sep 10, 2011 8:44 am    Post subject: Reply with quote  Mark this post and the followings unread
hello everyone
is there some easy way, how to build these with voltage controled SKEW of the rampoid?
( am going to build on fonik's pcbs)
warpboy
New postPosted: Fri Sep 23, 2011 6:11 am    Post subject: Reply with quote  Mark this post and the followings unread
hello,
I'm currently trying to build 4046 vco with Ryk's layout.
I can see on the schematic many 10nF (2 by IC) but on the part placement I don't see where I've to soldier them....
I joined the schematic .
any idea ?
thank you
Fabien
Sheet_0001.pdf
 Filename:  Sheet_0001.pdf
 Filesize:  886.68 KB
 Downloaded:  3111 Time(s)
New postPosted: Tue Oct 04, 2011 8:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Aum Generator wrote:
hello everyone
replace the skew pot by two vactrols.
while the resistane of one vactrol increases the other has to decrease, so you would need additional opamp circuitry to drive the diodes.
