Does the Sound Lab faceplate need to be grounded?
Page 1 of 1 [9 Posts]
wallace
PostPosted: Thu Mar 24, 2011 5:21 pm    Post subject:  Does the Sound Lab faceplate need to be grounded? Reply with quote  Mark this post and the followings unread
Hi everyone, this is my first post and my first synth build. I'm just about done with the wiring of my sound lab. I noticed that the weird sound generator project page includes directions on grounding the faceplate. The SL page seems to make no mention of it, just wondering if thats because it's a given or because it's not necessary. Cool
jordroid
PostPosted: Sat Mar 26, 2011 11:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello and welcome!
Grounding the faceplate may help to reduce noise by acting as a shield, but is not necessary for the circuit to operate. If you are using a metal panel it's probably best to ground it, lest it act as an antenna for external interference.
Make sure to let us know how the sound lab comes out, it's a great little synth!
regards,
jordan
wallace
PostPosted: Sat Mar 26, 2011 11:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Jordan, I'll go ahead and ground it then. I'll post a pic once its finished... I just hope it all works!
jordroid
PostPosted: Sat Mar 26, 2011 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ha, yeah, you may be one of the lucky ones who builds it right the first time, i wasn't, but i got mine going with some help from people on this forum. If you get stuck we'll be happy to help. Smile
Monolab
PostPosted: Mon Oct 17, 2011 4:19 am    Post subject: Mini Synth Grounding/ Earth problem ... maybe .. Help Reply with quote  Mark this post and the followings unread
I hope you can help, i've just completed wiring on my Soundlab Mini Synth.. when i come to test sound.. all i get is a buzz from the output also when i touch the metal faceplate.. sounds to me like a Grounding /Earthing problem , it's my first build so any ideas / advice oh wise members of the forum ??
help
Pehr
PostPosted: Wed Oct 19, 2011 12:49 am    Post subject: Reply with quote  Mark this post and the followings unread
have you connected the potentiometers ground to the PCB-ground?
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
Monolab
PostPosted: Wed Oct 19, 2011 12:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah!! they are connected to the PCB Ground..
Pehr
PostPosted: Wed Oct 19, 2011 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
and the output-ground to PCB-ground?
YouTube channel
flickr photostream
Clack
PostPosted: Thu Oct 20, 2011 2:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Are your output jacks insulated? plastic? try connecting the case to GND with a crocodile clip to see
Clacktronics.co.uk
