Looking for a bit of help with modulars
Page 1 of 1 [20 Posts]
04tm34l3
PostPosted: Sat Aug 06, 2011 9:01 pm    Post subject: Looking for a bit of help with modulars Reply with quote  Mark this post and the followings unread
Dear Forum,
I've been browsing and stalking for a bit of time, and I was just wondering if I could get a bit of help with assembling a modular.
For the past few months, I've saved my dish washing money for a synthesizer before I've got to pay for all my college (about 14 months). For some reason I got a TI2, which was in fact, a big mistake so I returned the darn thing.
The only thing is my budget is a tad limited (looking to keep it around 2k). I've been looking at the Doepfer A-100 Mini, but theres a few things Id like to have in my system that aren't included.
So I'm just kind of wondering how I can get the best of my money, and what are the basic modules that a good system should have. Id like to get the a-100p6 suitcase rack as well for transportation, leaving a little more than 1.4k for the modules themselves (or perhaps an a100p9? the extra money for the space might be worth it in the future) I've put together a list of modules below that hopefully are good enough.
ok so heres the list i composed...
doepfer
a190 midi/cv
a140 asdr envelope generator (perhaps 2? or mabey instead a maths?)
a106 vc lpf/hpf
a130 vca
a114 ring mod
a145 lfo
a147 vclfo
a138a mixer
a119 envelope follower
Synthesis Technology
e340 cloud generator (for a vco, would it be wise to get another such as dopfer a110 or a malekko oscillator?)
The Harvestman
malgorithm
excluding the case and cables, it comes out to about 1.6k .
my lasting questions are is there anything I should cut for the amount of funding i have. and are these relatively hard to assemble? (I plan to order from analog haven, unless there is somewhere better to get them in the us.)
I'm sorry i have so many questions, its just this stuff keeps my pondering mind up all night, and i was just looking for some help.
-04tm34l3
wmonk
Audio files: 15
PostPosted: Sun Aug 07, 2011 3:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi 04tm34l3!
firstly, I don't know stuff about eurorack, but I can give some general comments on your list.
For a small system it would be wise to know if you're looking for drones, soundscapes, or more looking for bass and lead sounds. The midi2cv suggest the latter, the ringmod and e340 the first.
Then the comments on the list. For a ringmod to work you need two sound sources. So I would suggest at least another VCO.
For more modulation options, VCAs are very useful, for example to control the amount of modulation.
Different filters give a different character. I think it is wise to start with a multimode filter.
Woody
Weblog!
PostPosted: Sun Aug 07, 2011 9:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Good advice!
There are some similar threads here that should contain information that applies in your case too.
Flickr
04tm34l3
PostPosted: Sun Aug 07, 2011 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
hey! and thank you.
as far drones/soundscapes/leads/basses go i suppose im trying to get a a bit of everthing, however im more interested in drones and basses.
but do you think the maths could substitute the need for an lfo and an envelope generator?
PostPosted: Sun Aug 07, 2011 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
A software modular synth might be a good starting point in order to figure out what you need in order to build a basic system that makes sense to you.
The Clavia G2 demo software is free. You could try that one.
Flickr
04tm34l3
PostPosted: Sun Aug 07, 2011 4:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok thanks, ive just downloaded it!
im still a bit curious about assembling these. is it relatively hard to get your head around? or should i have it assembled elsewhere? is there a good place were i could learn more about this (ive looked but could not find much)
PostPosted: Sun Aug 07, 2011 4:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Assembly is easy. We are talking about mounting modules in a frame and connecting a few cables. Don´t worry. There are people here who can help. Very Happy
Flickr
DrJustice
PostPosted: Sun Aug 07, 2011 5:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
04tm34l3 wrote:
...but do you think the maths could substitute the need for an lfo and an envelope generator?
It may be better to start out with an extra envelope, or even an lfo, rather than the malgorithm module (assuming that's what you mean by 'maths'). Unless you specifically want to use the "digitized lo-fi" sound that a bit crusher gives a lot. It's often good to have a couple of each of the more standard modules before starting to add specialty modules - but you may find out for yourself by trying the G2 demo, as elektro80 suggests thumleft
DJ
04tm34l3
PostPosted: Mon Aug 08, 2011 3:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok thank you! to be honest i was very worried because on all the websites they have this big thing that warranties do not cover when you plug in a cable backwards. and then i got extra worried when i read things like the dophfer midi to cv module needed a different voltage.
and justice by maths i mean maths http://www.analoguehaven.com/makenoise/maths/
but regardless i see your point Smile
i just saw it suggested elsewere but wasnt sure if it was the right move
and how many patch cables should i get? i was planning on getting those stackable ones (however i do not recall the make of them)
ndkent
PostPosted: Sun Aug 21, 2011 7:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
one adsr and one maths isn't a bad start. 2 ADSRs and Maths would be even better since you might use Maths for something like an LFO or slew besides 2 simple envelopes or one regular style envelope
a114 ring mod
it's a no frills dual ringmod and you have very few signal sources so other than processing external sounds you might be a bit lacking with gear to use it with. Also other ringmods may have more features, The Oakley one comes to mind for more options
a145 lfo
a147 vclfo
can't hurt but I wouldn't get 2 low frequency sources before you get more vcos. Maybe just the a147
No it's not a substitute for a proper VCO at all. It's a digital generator of some interesting specialized sounds. Generally 2 proper VCOs is a good idea for a wider variety of sounds and modulation options.
The Harvestman
malgorithm
Another specialized digital device. Certainly worth getting if it inspires you but it would not be part of a typical basic system.
You have no proper random sources like Noise.
04tm34l3
PostPosted: Sat Aug 27, 2011 7:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
well all, thank you for the realistic feedback (helped me alot)
also from working with the g2 i realized how my 'set up' was full of too many specialty stuff, yet was lacking basics
anyway, edited my list again, any sort of feedback would mean a lot
kept the a190 midi, a147vclfo, and a106 filter
vcos
tiptop z3000, and (questionably) pittsburgh modular oscillator (didnt really hear anything bad, seemed like a basic pitch accurate osc)
a140 adsr env (x2)
a130 mixer
a ring mod (oakley one the kent mentioned looked well, is krisp1.com is a fine site?[planning on ordering the rest from analog haven])
pittsburgh audiomixer attenuator (rather than an a138a, is the difference between a mixer and an attenuator far?[the pittsburgh attenuator doubles as both however])
and a pittsburgh outs (was gonna get this or the malekko one)
and a 4ms noise swash (rather than the malgorithm)
id like to include the maths in here, but id really prefer to keep the cost of the modules under 2k.
sorry for the lengthiness, just trying to get all of my questions out
BobTheDog
PostPosted: Sun Aug 28, 2011 12:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have a Z3000, its not that great I think.
04tm34l3
PostPosted: Tue Aug 30, 2011 3:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
any alternative suggestions?
BobTheDog
PostPosted: Tue Aug 30, 2011 11:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
How about an AFG
http://www.livewire-synthesizers.com/
04tm34l3
PostPosted: Wed Aug 31, 2011 12:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
i've actually heard alot about this one!
my only concerns are if it has pitch accurate cv control (would that be the 1v oct cv input)
and ive heard these aren't regularly avaliable (in recent times atleast), is this true?
BobTheDog
PostPosted: Wed Aug 31, 2011 11:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
It has accurate pitch control for me but there have been some people complaining on the internet that it can go a bit wonky after a few hours, mine is fine though.
I got mine while they were in stock, from what I can see now you have to order one and then wait for it with baited breath!
Andy
04tm34l3
PostPosted: Thu Sep 01, 2011 12:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
detuning mabey has something to do with the temperature, and the analog?
hmmmmmmmmmmm... alright. im planning to get this from analog haven, would it be worth it to shoot them an email about it? or should i just be more patient?
BobTheDog
PostPosted: Thu Sep 01, 2011 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would look for some videos and sound clips first to make sure you like the sound of it first, after all it is not a cheap osc.
Maybe some others could chip in with some osc advise as well, I am not an expert Smile
I really like the afg though, you can get lots of different sounds out of it.
04tm34l3
PostPosted: Fri Sep 02, 2011 12:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah ive been watching some demos, and poking around on muffwiggler about this thing, still well, researcher.
im liking the maths alot more than i did before.
and for the second vco i was thinking the bubblesound ulfo? not sure, still thinking about that second vco
EATyourGuitar
PostPosted: Sat Oct 15, 2011 9:39 am    Post subject: Reply with quote  Mark this post and the followings unread
just respoding to the list in the OP. looks good. I'm building a similar system in MOTM built around a e340 cloud generator. I played with ring mods too much in my life so I wont be adding one for a while. some people in euro like to start with a dark energy so they get the USB + MIDI + power. check out flight of harmony for a super cheap power solution. about $60 for power. if you dont like the dark energy on the side, you can get the dark energy euro module and a midi module. maths is an awesome module but the versatility makes it less intuitive. most people never use them to the fullest of their potential. its also not in production anymore so the price is higher than it should be for what it is / was. dont forget to have one passive multiple, one buffered multiple, one or two mixers. lots of VCA's, a noise source, some kind of distortion or clipping or bit crushing. always build the attenuators, adapters, mixers, passive multiples from blank panels. these are easy as fuck to build.
