macumbista
Posted: Mon Sep 19, 2011 1:25 pm Post subject:
OK, digging in a little deeper... since my modular already has several oscillators, two analog multipliers and two DC mixers, the only thing missing from this block diagram are the phase shifters.
Can anyone EE-skilled enough look at the phase shifter schematics and tell me what components would have to be changed in PS 2,3 if I replaced the dual-gang 300K pot (hard to find) with either a 200K or 500K?
According to Waite:
Integrated circuits IC3 and IC4 are simple voltage followers that unload two RC networks while providing a low output impedance.
So how could I recalculate the RC network with a different variable resistor?
Source of both images is Mitchel Waite's Projects In Sight, Sound And Sensation, as linked to earlier in this thread.
124.64 KB |
| Viewed: |
292 Time(s) |
128.7 KB |
| Viewed: |
280 Time(s) |
_________________ Esoteric drones and nonlinear distortion
macumbista.net |
Joined: Apr 03, 2004 Posts: 24499 Location: The Netherlands, Enschede
Posted: Mon Sep 19, 2011 2:56 pm Post subject:
The RC product is interesting, so when you go from 300 to 200 K you'd want to scale up the caps with a factor 1.5; also the fixed resistors could be rescaled, with a factor of 2/3 then.
Likewise, when going to 500k rescale the fixed resistors too with 5/3 and the caps with 3/5. _________________ Jan
macumbista
Posted: Mon Sep 19, 2011 3:08 pm Post subject:
muchos gracias!
200K 1.3K 0.0015uF/1.5nF
300K 2.0K 0.001uF/1.0nF
500K 3.3K 0.0006uF/0.6nF/600pF (or 560pF, which is what is more common)
now I'm thinking about vactrols  _________________ Esoteric drones and nonlinear distortion
macumbista.net Last edited by macumbista on Tue Sep 20, 2011 1:01 pm; edited 1 time in total |
bugbrand
Posted: Tue Sep 20, 2011 4:31 am Post subject:
Oh, I actually did a basic layout for those sections - though I haven't really tried it out too much.. I also had to use a different value pot, so just played with a variety of different caps (trial and error!). Also, I used AD633s for the ring-mod sections - very good chips and simple to implement (though they're a little bit pricey). I really should get the little circuit mounted into a panel and set a system up with the layout suggested, but with regular VCOs instead of the 8038 ones. _________________ http://www.bugbrand.co.uk
macumbista
Posted: Tue Sep 20, 2011 3:14 pm Post subject:
I've used AD633s before, they're quite simple. One thing Waite writes about that I don't get how to do with them is X/Y balancing:
If the circuit is operating properly, P1 should make the waveform vary from amplitude modulation to suppressed carrier modulation. Potentiometer P2 will vary the symmetry of the modulated signal.
This isn't the DC offset function you could use at pins 2 and 4 of the AD 633 is it? See Roman Sowa's ringmod schematic (although he uses the DC offset at pins 1 and 3 instead)....
EDIT: quick look at the MC1495 datasheet tells me yes, Waite's "balance control" is a simple offset control. Thanks internets...
100.38 KB |
| Viewed: |
36603 Time(s) |
66.54 KB |
| Viewed: |
36603 Time(s) |
53.83 KB |
| Viewed: |
288 Time(s) |
macumbista.net |
creekree
Joined: Mar 30, 2006 Posts: 192 Location: Morgenland Neukölln
Posted: Wed Mar 14, 2012 3:38 pm Post subject:
ok I am pushing this topic back to the top to ask if anyone has the attached files saved to their harddisk?
They seem to be lost, and I´d like to try this Oscillographics thing, I have a small portable TV that would fit perfectly into my modular!
Thanks for helping!
Christian |
creekree
Posted: Fri Mar 16, 2012 9:37 am Post subject:
ha, I dont know how I managed to not find the files....
your project is what ignited my interest in the first place!
how exactly did you manage to use the TV as a display?
from the little that I have read by now I gather that the Oscillographics circuit was designed to drive a 2 channel oscilloscope.
this is not what I want- I´d like to have a dedicated portable TV built into a module, for the sole purpose of looking good in my modular (yes, I am that shallow)
Christian (who has to admit that he did not spend very much time reading about the subject at hand) |
Posted: Fri Mar 16, 2012 12:42 pm Post subject:
| creekree wrote: | ha, I dont know how I managed to not find the files....
how exactly did you manage to use the TV as a display? |
nice that it inspired you (that's why I put it online)
using the TV isn't very complex. feed the signal of the oscillographics circuit
(or whatever you want to display) to an audio amplifier and attach the
speaker outputs to the TV's deflection coils. Off course you have to remove
the original wires first. I used a switch myself so I can still use it as a TV.
For the amplifier I used one from a set of computer speakers.
I have done this with a TV and computer monitor before and it worked fine
but in this case it didn't. Displaying the signals worked but the image was
very dim. This had to do with the fact that a part of the TV is powered in
series with one of the deflection coils. So by removing that connection it
couldn't work like it should. (JovianPyx knows more about this). I solved it
by using a speaker coil with a series resistor as a mock deflection coil.
I just used what I had laying around, I think the speaker was 8ohms/50Watts
and I used a 15ohms/1Wattt series resistor (which does get warm).
I didn't want to experiment too much since it worked and was too afraid I
might detroy the TV and that would mean end of project.
| Quote: | | I´d like to have a dedicated portable TV built into a module, for the sole purpose of looking good in my modular (yes, I am that shallow |
that's something I've been planning to do too, allthough besides looking
awesome I think it's useful aswell. I'm probably gonna add a sawtooth
generator and a better amplifier so it's works better as a scope (if possible).
(was also thinking of adding a pong game with the sounds converted to
gate signals )
btw having it in a seperate case like I have now does give you the option
to easily hook it up to anything. But yeah I'm probably still gonna make a
module too and I also want to build a HAL9000 module and maybe a KITT
module (knightrider). (how's that for shallow ) _________________ "My perf, it's full of holes!"
creekree
Posted: Tue Mar 20, 2012 10:47 am Post subject:
phobos,
Thanks for the advice.
When I get back home I will give it a shot. Being short of a set of computer speakers that I can gut, I think I will just build a set of LM386 amps to drive the deflection coils. |
Posted: Tue Mar 20, 2012 1:05 pm Post subject:
| creekree wrote: | phobos,
never tried an LM386 for it but I think it'll work. good luck and be careful
(you can find some more information here) _________________ "My perf, it's full of holes!"
