do negative voltages really destroy cmos?
Page 1 of 1 [7 Posts]
synthesist
PostPosted: Sun Sep 25, 2011 6:05 am    Post subject: do negative voltages really destroy cmos? Reply with quote  Mark this post and the followings unread
I build the adsr-generator circuit from nicolas and it's supposed to spit out about -3 to +3 volts.
I also build a VCO out of the cd4046 cmos chip, it is powered by +9 volts and ground. It has an CV input where I fed the signal of the adsr circuit. Everything seems to work fine though.
But it shouldnt, or? everytime the signal reaches down to the negative voltage it is like the cmos chip gets poled the wrong way.
Or can I assume that it will break after some time?
Clack
PostPosted: Mon Sep 26, 2011 12:10 am    Post subject: Reply with quote  Mark this post and the followings unread
it probably isn't going low enough to pull the input of your VCO negative (but then I hav'nt seen your vco's layout so who knows)
A diode pointing from GND to your input should protect it
Clacktronics.co.uk
synthesist
PostPosted: Mon Sep 26, 2011 3:30 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for your answer.
Yesterday I connected the adsr- signal to the anode of a diode, the cathode is pointing to the CV input pin of the vco circuit. Works fine so far.
Is this also a way to secure it from the neg. voltage?
Clack
PostPosted: Mon Sep 26, 2011 10:55 am    Post subject: Reply with quote  Mark this post and the followings unread
yes that will also work , although you will experience a voltage drop of around .6 which wont really be noticeable with an envelope generator > VCO
Clacktronics.co.uk
synthesist
PostPosted: Mon Sep 26, 2011 12:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
you are right, the voltage drop isnt really noticeable.
by the way,
here is the schematic of the VCO. I used a second cd4046 VCO to feed a pretty high audio range signal into pin 14.
the output sounds like a ringmodulation. a pity that it comes with a constant anoying high tone. I think it's caused by the internal vco. If you turn the potentiometer you can pitchshift the audio input.
there are so many things to do with this IC. The perfect chip for a newbie to start with.
I saw this circuit at a homepage from "flo kaufmann". A similar one is also published in a nicolas collins book.
4046schmo.pdf
 Filename:  4046schmo.pdf
 Filesize:  9.36 KB
 Downloaded:  450 Time(s)
synthesist
PostPosted: Thu Nov 17, 2011 1:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
meow!
I just record something. A super psycho lfo modulates a 4046 vco wich modulates the circuit above.
sounds disgusting!!!
Cool
cd4046_vco_thing_modulated_by_sup.mp3
 Filename:  cd4046_vco_thing_modulated_by_sup.mp3
 Filesize:  1.28 MB
 Downloaded:  755 Time(s)
CJ Miller
PostPosted: Fri Nov 18, 2011 8:10 pm    Post subject: Re: do negative voltages really destroy cmos? Reply with quote  Mark this post and the followings unread
Rule of thumb is that you should not use signals which are less than the VSS/ground pin. So if your ground is actually zero volts, negative voltages coming into the chip can destroy it. I just played with some CMOS chips and powered them from -5V to +5V. So the total supply voltage is 10V and the chip doesn't care what I call it.
