Step Sequencer Question
Page 1 of 1 [6 Posts]
PostPosted: Mon Oct 10, 2011 7:45 am    Post subject: Step Sequencer Question
Subject description: 4029 and 4514
I am making a sequencer using a 4029 and 4514. I am having some trouble testing it on breadboard. My board is old and stuff works when i press it in and hold it, but stops when i let go. This is making it difficult to test, so i figured i will just go ahead and solder it up the way it 'should' work. But i have two questions:
1. Do i want the 4029 to run in binary or decimal mode?
2. What do i connect to the Strobe pin on the 4514? I have no idea what that pin does.
PostPosted: Mon Oct 10, 2011 8:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Judging from the decoder your using, the binary mode would be your choice.
Decade mode will just count to 9 and recycle to 0.
This is a level triggered LATCH enable pin and the decoder will hold the last decoded outputs when held at a logic low. Just tie it high and the device will decode the inputs and transfer to the outputs immediately.
Hope this helps you.
Bill
PostPosted: Mon Oct 10, 2011 8:38 am    Post subject: Reply with quote  Mark this post and the followings unread
It helps a lot. Thanks!
PostPosted: Mon Oct 10, 2011 9:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Very good then. OK, shout if you require any more clarifications.
have fun !
Bill
PostPosted: Mon Oct 10, 2011 1:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi. I do have another question. Should all the jam inputs, carry in clock, and carry out clock be grounded on the 4029?
andrewF
PostPosted: Mon Oct 10, 2011 4:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
carry out can be left unattached
carry in to ground
jam inputs to ground, then you can use pin 1 (PreEn) as a reset input
or you can set the Jam inputs to do something else and get some really interesting things to happen.
