polysix repair
Page 1 of 1 [25 Posts]
DETOX
PostPosted: Sun Oct 04, 2009 1:17 pm    Post subject: polysix repair Reply with quote  Mark this post and the followings unread
i don't know wether i already posted this or anyone else did, the search function didn't result in any concrete matches.
i just got a polysix for free but as usual the battery was leaking and damaged the memoryboard. i already found an online tutorial on the repair and did all the steps of the board removal as described.
btw: before the removal the synth did still work more or less. the dco had some malfunctions as the attenuator and some other sections but it did work somehow.
now i'm at the point of the actual board restoration and battery replacement but i'm a little scared because i consider myself not as an overwhelming solderer ( i have basic skills so to say). the acid covers some traces and some legs of the ic being close to the battery (unfortunately i don't have a digicam atm so i can only describe it's condition).
my question is: what are the main mistakes i can make?
will it be doable for me as a relatively untrained technician?
will there be any problems before switching it on the first time after restoration?
thanks for your replies !
Waldorf Pulse
radek tymecki
PostPosted: Mon Oct 05, 2009 8:54 am    Post subject: Reply with quote  Mark this post and the followings unread
http://www.oldcrows.net/~oldcrow/synth/korg/polysix/crowlm367/klm367a_img.gif
get a multimeter and check all connections near ic30 and 31
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Mon Oct 05, 2009 2:14 pm    Post subject: Re: polysix repair Reply with quote  Mark this post and the followings unread
nice.
It actually uses VCO's. They have six linear VCO driven by a single Expo, they just put the expo before the final demux.
It is a very nice synth.
Mooger5
PostPosted: Mon Oct 05, 2009 4:51 pm    Post subject: Re: polysix repair Reply with quote  Mark this post and the followings unread
Practice first, get some trashed PCB and wires, and practice. Make all sorts of crazy soldering until you´re confident enough.
After cleaning the PCB, do the continuity tests as advised. If you find the acid corroded some copper tracks you´ll either have to solder insulated thin solid-core copper wires on the damaged spots or link the components directly, lead to lead (or IC socket pins).
Good luck.
DETOX
PostPosted: Tue Nov 15, 2011 9:30 am    Post subject: Reply with quote  Mark this post and the followings unread
wow !
believe it or not, i didn't finish the klm367 repair yet. i finally have got all parts together. the only part missing is the component called R17. i know it's a resistor array but because i live in germany i need to know the german word to tell the dealer what i'm actually looking for. can anybody 'translate' "resistor array" into german? i need the real name ! thank you.
btw: can i replace a resistor array by just soldering 8 10k resistors together?
Waldorf Pulse
DETOX
PostPosted: Tue Nov 15, 2011 9:39 am    Post subject: Reply with quote  Mark this post and the followings unread
okay, i found it out myself again !!!
Waldorf Pulse
DETOX
PostPosted: Tue Nov 15, 2011 3:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
i soldered everything together but the synth still doesn't work properly. the filter and envelope section seem to be okay, the arpeggiator also works as the effects section does.
the memory section doesn't really work......several leds lght up constantly but it seems not to work at all.
the vco section bothers me the most. i can't switch between pulse and saw. the only wave i can hear is a pulsewave, pwm works too. the sub oscillator seems not to work either. when i press down the memory board and hold it the subosc seems to work, but switching between octave 1, 2 and off doesn't work.
any solutions? i replaced the battery, the r17 resistor array, and the ic beneath. soldering is a bit messy but i think all traces should be connected properly.
did anybody of you order a cloned km367 board?
Waldorf Pulse
EdisonRex
Audio files: 172
PostPosted: Tue Nov 15, 2011 3:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
You might try checking the top board. When I powered on my Polysix after many years of dormancy, and after removing the battery (I had stored it in a way that left a nice corrosive spot on the back panel but didn't hideously damage the board), there were a number of issues, mostly with the front panel selections and the calibration (the voices were out of tune).
I haven't really started to restore the instrument, but capacitors go bad over time and I expect that has effects on the control. You might also have tin whiskers or other shorts which cleaning will help.
Garret: It's so retro.
Mooger5
PostPosted: Wed Nov 16, 2011 2:37 am    Post subject: Reply with quote  Mark this post and the followings unread
ICs 30 & 31 are traditional culprits. Replace IC30 too and luckily you´ll have the programmer problem fixed.
Download the service manual. On the KLM-367a page you´ll see ICs28 & 29 manage the Saw and SUB Osc commands. Old series 4XXX chips die. It might be the cause. With a multimeter set to DC check if around 5V reach pin 1 of IC28 when you select Saw. On IC29 there should be a change between 0V & 5V at pin 10 when switching between Sub Octaves 1 & 2. With Sub set to OFF you should read a little less than 5 at pin 9. If you don´t get any readings, check continuity to the respective connector.
Best thing I did to my Polysix. Worked on first try.
By your description of what´s working in your Poly it doesn´t seem in very bad shape so give it a few more tries to fix it.
philoop
PostPosted: Wed Nov 16, 2011 6:19 am    Post subject: Reply with quote  Mark this post and the followings unread
if many LEDs are on and sound misbehaving ts definitly the tracks on klm 367
to ic 30 31. I fixed three polys and it always was that problem....
thanks to oldcrow
[/quote]
Deploying dual-wavelength fNIRS, we interrogate 16 locations in the forehead when eight able-bodied adults perform deception and truth-telling scenarios separately.
DETOX
PostPosted: Thu Nov 24, 2011 1:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
oh, great advices from you guys ! thanks for that. i'll definitely give it another try (or even some more). it's sitting in my studio half naked anyway.
if it worked again i'd be so happy ! i fell in love with the filter so badly.
Waldorf Pulse
philoop
PostPosted: Thu Nov 24, 2011 1:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
hurry up to extract the battery or its going to corrode its way to the pcb even further...long live the polysix
DETOX
PostPosted: Thu Nov 24, 2011 4:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
oh, i already did so. i even followed old crow's instructions on that procedure but probably messed it up a bit because i couldn't wait for it to work properly again......shouldn't have cut all the traces that 'seemed damaged' two years ago or so. going to desolder everything added before and take a deeper look again. hopefully all of the important ics are still in good order and didn't get damaged by the heat of the soldering iron......
btw: if i do not manage to get it working again, does anybody of you know a person/people in germany (preferably in north-rhein-westfalia or even the ruhr-area) who could repair a polysix?
Waldorf Pulse
YashN
PostPosted: Sat Dec 31, 2011 3:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Undergoing the same process here.
DETOX
PostPosted: Fri Jan 20, 2012 3:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
managed it?
Waldorf Pulse
DETOX
PostPosted: Fri Jan 20, 2012 3:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
where do i get replacement boards?
Waldorf Pulse
djs
PostPosted: Fri Jan 20, 2012 7:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
replacement boards can be ordered here:
http://sites.google.com/site/jedjorgensen/
YashN
PostPosted: Sat Jan 21, 2012 5:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
One circuit is very damaged: there are so many breaks around the battery area. It's one of the old boards where the chips were mostly soldered on.
The other circuit, which also had battery damage, surprisingly seems good, and it's the newer version, with most chips socketed.
One of the Quad gate chips is dead, so the socketed ones can be reused.
While cleaning the old circuit, I damaged the resistor array, so I need to order a new one.
In both synths, I have no control over the Cutoff and Resonance.
Arpeggiator in the newer one is working.
Some sounds in both synth: a wailing, rising tone sound.
Still a lot of work to be done: buying sockets for the un-socketed one, with the replacement Quad gate chips and the resistor array too.
Can't wait to hear them restored again. I think they're going to be fabulous synths, and I will also mod them too, as I've been doing with all my resurrected synths.
DETOX
PostPosted: Sun Jan 22, 2012 3:40 am    Post subject: Reply with quote  Mark this post and the followings unread
the resistor array on my board was damaged too but i simply built a new one myself. as far as i understand a resistor array just consists of several resistors of the same values soldered together on one side/pole in parallel.
if that's wrong please correct me Very Happy.
how do you exactly measure the board? i connected the ground connector of my multi-meter to the big black ground connection of the board and measured every trace and ic pin by tipping the other electrode onto it. <- does it sound right?
Waldorf Pulse
JingleJoe
PostPosted: Sun Jan 22, 2012 11:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Different arrays have different internal wirings, look up the part number to find out for certain.
defog
PostPosted: Mon Jan 23, 2012 11:03 am    Post subject: Reply with quote  Mark this post and the followings unread
As far as repairing these and other old synths, in my experience it is always comes down to a single trace on the board or a single wire that does not appear to be physically damaged/cracked that is the culprit. A lot of times the ICs and everything else will work perfectly fine once they're found (except in the case of IC 31 on the Polysix).
I worked on one of these a few years ago that I pretty much had to rebuilt the entire bottom left corner of the PCB's traces with bus wire to get it going again. Took a little while and a very steady hand and exacto blade to make sure it was clean and no micro-bridges were made, but it worked perfectly afterward.
The Phoenix Vertigo is my Electronic alias. Check out my songs on soundcloud : http://soundcloud.com/charles-stieg/
DETOX
PostPosted: Fri Jan 27, 2012 2:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
i started "repairing" it two or three years ago when it was given to me (for free!!!!). due to impatience i probably did the scratching of the traces a bit to sloppy. will give it another try these days.
Waldorf Pulse
defog
PostPosted: Fri Jan 27, 2012 4:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just automatically lay down bus wire on cracked/scratched traces now when I do repairs to keep it from cracking again. I just make sure to follow the exhisting trace's shape to avoid any sort of RF craziness.
YashN
PostPosted: Fri Jan 27, 2012 8:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
That would be too much of a kludge for me when it's easy to order a cheap replacement.
I'm using a multimeter in Resistance mode, and testing one side of a suspicious trace and the other.
YashN
PostPosted: Fri Jan 27, 2012 8:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm prepared for that possibility, although hopefully I avoid it Cool
It's inevitable that I'll have to use wires and rebuilt some parts of the very damaged circuit one.
