today> Various Artists September equinox Concert
Troubleshooting an Ensoniq Mirage
Page 1 of 1 [5 Posts]
danielwarner
PostPosted: Tue Mar 05, 2013 2:56 pm    Post subject: Troubleshooting an Ensoniq Mirage Reply with quote  Mark this post and the followings unread
Hey all, thought this would be appropriate for the DIY section. A friend of mine recently gave me a broken Ensoniq Mirage. When I power it up, the LCD is completely blank and there is audio output, but it's a constant, quiet, scrambled digital sounding signal.
I checked the power supply with a multimeter and it appears fine.
I'm wondering if anyone has any experience with these beasts. I suspect the floppy drive is the culprit.
PostPosted: Tue Mar 05, 2013 3:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Probably should give a look at this:
http://www.deepsonic.ch/deep/manuals/ensoniq_mirage_dsk-8_service_manual_revision_2.pdf
I have no direct experience with this synth.
good luck! Smile
danielwarner
PostPosted: Wed Mar 06, 2013 2:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, I'll check that out!
danielwarner
PostPosted: Thu Mar 07, 2013 1:53 pm    Post subject: It's alive! Reply with quote  Mark this post and the followings unread
I honestly don't know what I did right, I pulled and resocketed all the ICs available, reset the ribbon cables, and now it works Shocked Very Happy
PostPosted: Thu Mar 07, 2013 2:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sockets have migration problems over long periods of time. Could be one or more of them worked its way loose and you reseated it.
