Wren latest version - 2025.4.10.0
Page 1 of 11 [263 Posts]
Goto page: 1, 2, 3, ..., 9, 10, 11 Next
Audio files: 297
PostPosted: Sun Feb 23, 2014 5:54 pm    Post subject:  Wren latest version - 2025.4.10.0
Subject description: 2025.4.10.0
for downloads: https://bluehell.nl/wren/
for info: https://bluehell.nl/blogje/
As of version 2022.1.5.0 32 bit versions are no longer supported.
The changelog: https://bluehell.nl/blogje/
The help: https://bluehell.nl/wren/wiki/
Wren version 2022.3.28.0 or later makes use of an istaller - updates can be done from Wren itself.
Wren version 2025.4.10.0 or later also publishes a simple zip file again for manual installation.
cebec
G2 patch files: 31
PostPosted: Tue Feb 25, 2014 6:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Very nice, thanks!
Are there near-term plans for alternate knob control modes (via the mouse), e.g., vertical and horizontal in addition to circular?
http://www.soundcloud.com/cebec
Audio files: 297
PostPosted: Tue Feb 25, 2014 12:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, I will consider that, it never occurred to me people actually use that Shocked
In fact I just added the modes which was half an hour of work or so, but will have to mess a bit to make it usable ... which is not trivial it seems ... and will have to check if the mode is always set over all knobs .. with adding modules & such.
cebec
G2 patch files: 31
PostPosted: Tue Feb 25, 2014 12:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Understood! Laughing
Thanks.
Audio files: 297
PostPosted: Tue Feb 25, 2014 4:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
It was not trivial indeed ... update posted to https://bluehell.nl/wren/
Not quite what I'd want, but workable I think.
edit : url update.
edit: another url update
cebec
G2 patch files: 31
PostPosted: Tue Feb 25, 2014 7:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Works for me, thanks! Cool
Audio files: 297
PostPosted: Sun Mar 09, 2014 3:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
New version 2014.3.9.0
Added a couple of modules mainly and a search function.
The new modules are : Rectifier, MinMax, Integrator/Differentiator, MIDI note receiver, MIDI CC receiver, MIDI note transmitter, MIDI CC transmitter.
The MIDI modules work with MIDI over TCP, and this needs support by an external program. I made my netMIDI server available from my site, but the format used should be compatible with the MidiTangle program too.
http://bluehell.electro-music.com/wren/forums.html has some more info on this.
edit : url update.
Audio files: 297
PostPosted: Fri Mar 14, 2014 12:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
Bugfix - see first post in this topic.
Audio files: 297
PostPosted: Fri Mar 28, 2014 3:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Added stereo to wave players and there is a new 6x6 matrix mixer, chainable, and it has a control input for each knob.
Edit: there was an unintended dependency on my Led unit, providing the MIDI LEDs, I removed that one and made a new source code release. This does not really affect the program itself, some round LEDs are square now.
Audio files: 297
PostPosted: Tue Apr 01, 2014 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
New version 2014.4.1.0 - see first post for all details. Fresh source code was posted for this as well.
The main new feature is the HrastOsc made by HrastProgrammer, this is an anti-aliased multi waveform oscillator. Thanks for that Hrast Cool
BobTheDog
PostPosted: Tue Apr 08, 2014 3:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Interesting stuff Jan.
Can XE5 build it for OSX?
Audio files: 297
PostPosted: Tue Apr 08, 2014 4:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes it can .. but not this source code unfortunately .. it needs a different component set for that and then my code uses a lot of winapi stuff too.
Oh and I could not test it ... it wants 10.6 minimal, I have 10.5.8.
BobTheDog
PostPosted: Tue Apr 08, 2014 11:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah, Ok.
I thought I was being optimistic Wink
Audio files: 297
PostPosted: Tue Apr 29, 2014 1:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
New version uploaded .. quite some changes ...
Key items would be ... Hrast Filter added and old patches are incompatible, sorry for that, but had to do that to make the knobs work better.
Some modules got removed, but most became variations of new more general modules.
Hope I didn't introduce too many new bugs Rolling Eyes
Audio files: 495
PostPosted: Tue Apr 29, 2014 3:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks like quite an overhaul... And I like the new look. Smile
Now where did I put that spare time I set aside...
hrastprogrammer
Audio files: 64
PostPosted: Wed Apr 30, 2014 5:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Those new MP3 demos are really nice Very Happy
Audio files: 297
PostPosted: Wed Apr 30, 2014 11:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Audio files: 297
PostPosted: Wed Apr 30, 2014 2:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some small bug fixes ...
Audio files: 297
PostPosted: Mon May 05, 2014 5:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
And a couple more buggies killed in 2014.5.5.0 ... Bug squash
Also made the sample rate and buffer size configurable ... the synth needs to be stopped to change those, but even then it may crash later on,
Best to quit wren after a change there and then start it again.
It does sound better at higher sample rates and its less glitchy with larger buffer sizes, but the latter will add latency, and the first reduces the possible patch size.
Audio files: 297
PostPosted: Sat May 17, 2014 12:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
New version ... added a couple of new modues and smoothed the envelopes a bit, less clicky now unless you want them to click.
Attached below is a demo featuring the formant and reverb modules, as well as the older HrastFilter.
2014-05-17--Blue Hell--Wren Demo 04.mp3
A WREN demo track, formant filter, HrastFilter and reverb.
 Filename:  2014-05-17--Blue Hell--Wren Demo 04.mp3
 Filesize:  5.52 MB
 Downloaded:  1812 Time(s)
cebec
G2 patch files: 31
PostPosted: Mon May 19, 2014 5:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Good stuff and love the demo!
Audio files: 297
PostPosted: Sat May 24, 2014 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, hey, somehow I didnt see this .. thanks!
Audio files: 297
PostPosted: Sat May 24, 2014 1:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just made another new version, and another demo.
2014-05-17--Blue Hell--Wren Demo 05, Doctor Frederick von Meier.mp3
Doctor Frederick von Meier - direct recording from a Wren patch
 Filename:  2014-05-17--Blue Hell--Wren Demo 05, Doctor Frederick von Meier.mp3
 Filesize:  24.03 MB
 Downloaded:  1786 Time(s)
Audio files: 297
PostPosted: Sat May 24, 2014 5:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://electro-music.com/forum/post-400000.html#400000 has that previous patch used in a mix, way nicer :-)
Audio files: 297
PostPosted: Thu May 29, 2014 3:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some minor changes, see first post in topic.
