 Forum index » Instruments and Equipment » iOS - iPad/Phone/Pod etc
Alchemy no more...
Post new topic   Reply to topic Moderators: mosc, v-un-v
Page 1 of 1 [3 Posts]
DES
PostPosted: Fri Jan 09, 2015 8:52 am    Post subject: Alchemy no more... Reply with quote  Mark this post and the followings unread
Looks like Camel Audio closed their doors and Alchemy Mobile is no longer available....
www.davesneed.com
GovernorSilver
PostPosted: Fri Jan 09, 2015 11:39 am    Post subject: Reply with quote  Mark this post and the followings unread
This was posted on the iPad Musician FB group by a member who got this reply from Camel - instructions on backing up your Alchemy stuff:
We are currently working on a few ways to back up iOS libraries so that you'll be able to reinstall them in the future. For now, you can use a free desktop app called 'iFunbox'.
Note: Song files will need to be backed up separately via iCloud or Dropbox.
Backing up using iFunbox (http://www.i-funbox.com):
1) Connect your device to your computer
2) In iFunbox, expand 'User Applications' using the disclosure arrow (circled below)
3) Go to Alchemy / Library and drag and drop the 'Private Documents' folder to the backup location on your computer (in our example above, we've created a folder called 'iFunbox Backup'. This could take a few minutes depending on how many libraries you have saved on your iOS device
4) Next, highlight 'User Applications', to see a grid of your installed application icons.
5) Right click Alchemy and select 'Backup to .ipa package' -> 'Without Personal Data'
6) It makes sense to save it to the same place as the Private Documents folder.
Restoring Alchemy Mobile + Libraries From Backup Using iFunbox:
2) In iFunbox, select 'Install App' from the menu bar at the top of the window
3) Locate the .ipa file that iFunbox created when backing up the app
4) Double-click the .ipa file to install Alchemy to your device
5) Next, expand User Applications as above, and go to Alchemy/Library
6) Drag and drop the 'Private Documents' file across. If given the option to Replace or Merge, select 'Merge'.
Some old stuff on VIRB
DES
PostPosted: Fri Jan 16, 2015 7:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Has anyone been able to generate the .ipa package as mentioned in the directions? Doesn't work for me. Maybe an issue with iOS 8.1.2? Downloaded the latest i-funbox... Sad
www.davesneed.com
