Lunetta style Atari Punk Console
Page 1 of 1 [6 Posts]
elektrouwe
PostPosted: Fri Jan 16, 2015 9:08 am    Post subject: Lunetta style Atari Punk Console Reply with quote  Mark this post and the followings unread
just came up with this Lunetta style APC idea : 3 of them fit into 1 40106 ( or even 5, if you use 1 master astable multivib. & 5 slave one-shots ).
I did not breadboard it yet, so it would be nice if someone could do it over the weekend and confirm it's working Smile
Lunetta style APC
 Filesize:  85.21 KB
 Viewed:  776 Time(s)
elektrouwe
PostPosted: Fri Jan 16, 2015 12:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
YES ! it sounds really APC-ish; just got the time to breadboard it.
Also nice kind of filter-sounds without D1 ( worth to use a switch)...
synaesthesia
Audio files: 85
PostPosted: Wed Jan 28, 2015 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Interesting! Need to give your circuit a try. Thanks for sharing it.
I ran into a stepped tone generator once accidentally when messing around on my bread board. This is the circuit I had.
 Filesize:  15.64 KB
 Viewed:  705 Time(s)
elektrouwe
PostPosted: Thu Jan 29, 2015 3:53 am    Post subject: Reply with quote  Mark this post and the followings unread
synaesthesia wrote:
... Need to give your circuit a try....
I also built a version with a 4093. Needs even less components, but only 1 APC per chip...
your "accidental" circuit uses a digital sampled feedback. I would expect a kind of "aliasing" sounds. Perhaps you can post mp3s of both sounds !?
4093 Atari Punk Console
 Filesize:  41.32 KB
 Viewed:  563 Time(s)
synaesthesia
Audio files: 85
PostPosted: Fri Jan 30, 2015 1:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sure. Smile I can even post a recording of all three sounds. Each recording has two full sweeps forward and back of the main potentiometer.
Lunetta style APC.mp3
 Filename:  Lunetta style APC.mp3
 Filesize:  584.9 KB
 Downloaded:  1027 Time(s)
APC digital sampled feedback.mp3
 Filename:  APC digital sampled feedback.mp3
 Filesize:  544.49 KB
 Downloaded:  1089 Time(s)
4093 Atari Punk Console.mp3
 Filename:  4093 Atari Punk Console.mp3
 Filesize:  541.63 KB
 Downloaded:  1190 Time(s)
elektrouwe
PostPosted: Fri Jan 30, 2015 3:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very Happy thanks "schneller Löter"
