LDR with really low minimum resistance for a VACTROL vibrato
Page 1 of 1 [8 Posts]
wax+wire
PostPosted: Thu Jul 23, 2015 11:42 pm    Post subject: LDR with really low minimum resistance for a VACTROL vibrato Reply with quote  Mark this post and the followings unread
so i'm building a vactrol for a vibrato in a bent Casio SK 5 with a LTC 1799 alternative crystal clock. I have a little 555 circuit that is creating a breathing LED to be my pitch vibrato.
Thing is I want my LDR to oscillte between 0 Ohms and say 1K Ohms. Is this possible? is anything like this possible?
What sort of LDRs are out there
PostPosted: Fri Jul 24, 2015 12:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Have you tried a resistor in parallel with the vactrol's resistance side?
wax+wire
PostPosted: Sat Jul 25, 2015 6:31 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah i have. from my understanding, putting say a 500 Ohm resistor in parallel with a LDR that has a range of 5K-500K will result in the resistance varying around 500 Ohms, but never getting close to zero.
It'll change the range, but not lower it.
PostPosted: Sat Jul 25, 2015 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
no, you're not going to get it lower, they usually have a range somewhere between 500 ohms and >10M.
Well you probably could put a bunch of them in parallel all controlled by either the same LED or maybe
a couple LED's, But that still wouldn't get you a very low resistance. Maybe using a FET instead could work.
Or drop the LTC1799 altogether and use a 74HCT4046 instead, which has a build in VCO so you can contol
it directly with a voltage. You could still use the vactrol setup or connect it (with some adjusting) instead of the LED.
wax+wire
PostPosted: Mon Jul 27, 2015 12:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Phobos.
Any tips/links on the 74HCT4046?
I found this http://www.electronics-tutorials.com/devices/74hc4046.htm
PostPosted: Tue Jul 28, 2015 12:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
hmm let's see, you don't need the whole comparator phase locked loop stuff, just the VCO section which is very simple.
just a small capacitor (between pins 6,7) and a resistor from pin 11 to GND which sets the range, you could also use a pot here.
I think in your case the best solution would be to use a small mixer circuit on the CV input (pin 9). With a potentiometer
to set the pitch and an input for your tremolo (with a pot. used as an attenuator). This will let you control the pitch
and tremolo depth independently. You could take a look at this circuit: http://electro-music.com/forum/post-372062.html#372062
I think the 74HC4046 would actually more useful than the 74HCT4046, but a standard CD4046 will be too slow for your needs.
Another thing I was thinking about is that you could use the LTC1799 but with a smaller capacitor, this would give you
the same speed at a larger resistance so then the Vactrol might work. I don't know how you're using it though.
Bogus Noise
PostPosted: Sun Aug 02, 2015 9:09 am    Post subject: Reply with quote  Mark this post and the followings unread
The H11F1 is also a really decent alternative to a vactrol. It doesn't have any of the slew that vactrols have so you can pitch your modulation osc up really high and get some wicked clangy noises.
I'd also be tempted to use a TL071/TL072 for the LFO, as 555 waveforms lose their shape when they're pitched up too high.
Circuit Bent Sonic Absurdity:
www.bogus-noise.co.uk
http://www.youtube.com/user/BogusNoise
wax+wire
PostPosted: Sun Sep 06, 2015 11:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
sorry to revive this, but some more discoveries!
the LTC 1799 datasheet describes it as having a VCO setting - https://cds.linear.com/docs/en/datasheet/1799fc.pdf with a oscillating voltage between 0-1.13V
now that is a tiny voltage range, but i was thinking a circuit designed to create a pulsing LED with a few resistors might do the trick?
thoughts?
