easiest 3-bit random binary number generator?
Page 1 of 1 [14 Posts]
okelk
PostPosted: Mon Sep 08, 2014 9:29 am    Post subject: easiest 3-bit random binary number generator? Reply with quote  Mark this post and the followings unread
I something that outputs 3 bit random (or pseudo-random) binary numbers.
What's the easiest way to accomplish this? something with shift registers?
Hope you can help me!
gdavis
PostPosted: Mon Sep 08, 2014 1:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
How about a linear feedback shift register (LFSR)?
http://wiki.osdev.org/Random_Number_Generator#Linear_feedback_shift_register
DUBmatze
PostPosted: Mon Sep 08, 2014 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
mhm ... i have somthing like that in my lunetta ....
this is not realy random.
i use the same value for C1 - C4 and some close values for R1 - R4 (cant remember but somthing like 2,2 - 2,5 - 3 - 3,5
maybe you can bild this with just 3 osc.
U1 is starve down with the pot for changing the speed. U2 will nice up the signals with the schmitt inputs back to 5V...
 Filesize:  20.22 KB
 Viewed:  577 Time(s)
PostPosted: Tue Sep 09, 2014 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
You could use one of the circuits posted in the thread "Pseudo-Random Bit Generators" here: http://electro-music.com/forum/topic-52066.html
and just use 3 outputs instead of 4. They are based on shift registers.
James.
okelk
PostPosted: Wed Sep 10, 2014 7:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your help!
I think I'll will explore the possibilities with shift registers....I'm kind of trying to avoid the cd4006 though...
synaesthesia
Audio files: 85
PostPosted: Wed Sep 10, 2014 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
You could use a 4021 or 74HC595 as a shift register. The advantage of the 595 over the 4021 is that it has an edge-triggered RCLK input. You could send two high frequency inputs (>> sample frequency) to SER and SCLK and capture the state as a random value using RCLK.
The drawback of an LFSR is that when you clock it only once for a new random value and select the outputs from adjacent pins, two bits will always be copied from their predecessors. For example, you will never see a 000 following a 111 or vice versa. So for an LFSR use outputs a few bits apart, like Q0,Q3,Q6.
corex
PostPosted: Wed Sep 17, 2014 9:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
I sketched up the LSFR depicted here (wikipedia). Each of the 16-bits out (Q1-Q8 on each of IC1 and IC2) comprise the current state. I chose the 4094 because I have those on hand. Double-buffering is not used in this design, so STR is tied to CLK. Take bits from IC2.QS as output.
From the wiki article: "...the register cycles through the maximum number of 65535 states excluding the all-zeroes state." Assuming it doesn't start all-zero.
Edit: it needs a kick-start to IC1.D because it does start empty. The all-zero state is a dead state. If you clock at least one 1 into IC1.D, it will enter a valid state and cycle normally.
 Filesize:  4.76 KB
 Viewed:  612 Time(s)
okelk
PostPosted: Thu Sep 18, 2014 9:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! That's great. I think I will try that with a 2 cd4015 because I have some lying around...
I found this table on Scott Gravenhorst's site. It shows the taps for various bit lengths.
http://home1.gte.net/res0658s/electronics/LFSRtaps.html
I wonder if it is better to get my three bits out of the 16 by taking three bits that are next to each other and let the shift register run at at least 3 times the speed of the 'sampling' clock, or if I should just take one from the end, one from the middle and one from the beginning...
corex
PostPosted: Thu Sep 18, 2014 8:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for finding that LFSR taps table, that's pretty handy!
Couple things. I found an old post by blue_hell where he recommends XNOR instead of XOR. With XNOR, the dead state is all 1's, so when it starts in the all 0's state, that is a valid state and it begins running immediately. That would be a good change.
Second, because it's a shift register, if you tap three consecutive bits then bit 2 will go to bit 1, and bit 1 to bit 0. The bits of the pattern will shift through the each of taps, one after the other. If the taps were further apart this would still be true but less apparent.
PostPosted: Fri Sep 19, 2014 6:04 am    Post subject: Reply with quote  Mark this post and the followings unread
you can find more taps (and info) here.
okelk
PostPosted: Fri Sep 19, 2014 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm planning to use the 3-bit number on the preset inputs of a 4029.
So If I choose 3 consecutive bits bits, then I would run the on 4029 at 1/3 of the shift register's clockspeed. I could use a 4013 and the leftover xor/xnor for a divide by 3 counter.
If I understand it right, this would also have the advantage that when the pseudo random sequence runs though the lfsr for the second and third time the 'sampled' 3-bit number wouldn't be the same because 3 is not a factor of the shift registers length. maybe, that way one 8-bit shift register would even be enough for my purposes...
on the other hand, I just found a few К176ИР10 (russian cd4006 equivalent) for really cheap....so maybe I just use them...
good article, thanks!
okelk
PostPosted: Sat Aug 08, 2015 6:54 am    Post subject: Reply with quote  Mark this post and the followings unread
just for future reference...this link seems to be dead...
here's a link to a snapshot in the wayback mashine:
http://web.archive.org/web/20140627102757/http://home1.gte.net/res0658s/electronics/LFSRtaps.html
Steveg
PostPosted: Sat Aug 08, 2015 11:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello okelk,
I have some history with LSFRs and my take is that they are a waste of logic gates for a lunetta. It is much easier to build a rungler where you clock the shift register or whatever at the tempo you need and connect the data-input to a fast running oscillator. It doesn't have to be one specially dedicated to the task. Any LSFR that you can build with a reasonable number of chips will have a very short repetitive output.
If you do use a shift register rungler, don't use three consecutive taps unless you want each successive set of "random" bits to be strongly related to the last one. Using both halves of a 4015 and using taps 1, 3 and 7 would work well.
Personally I would use a couple of 4013s drive all the clocks from your tempo source and connect each data-in to a different audio oscillator. That would give you 4 high quality random bits for whatever purpose you need.
[Edit] And now I see that synasthesia gave the exact same advice earlier and this thread is resurrected from 2014 ... such is life.
JovianPyx
Audio files: 224
PostPosted: Wed Aug 12, 2015 7:48 am    Post subject: Reply with quote  Mark this post and the followings unread
That link is indeed dead.
Here is the same document on an actively maintained site:
http://scott.joviansynth.com/electronics/LFSRtaps.html
Time flies like a banana.
corruptio optimi pessima
