diablojoy
Joined: Sep 07, 2008 Posts: 809 Location: melbourne australia
Posted: Mon Dec 13, 2010 12:46 am Post subject:
maybe throwing you a curve ball, not sure. pic's are not my thing yet
however that debug code may be pointing you in a reasonably logical direction to follow
[quote] | Quote: | void Init_PIC(void){
OSCCON = 0b01111100; //osc à 8 MHz
<edit>
there is a choice of 6 possible speeds for the internal clk
see page 37 onward of the data sheet
I could be way off but maybe worth a look in that area
and yes I think you are correct. to use an ext osc would require reconfig of I/O as one of the ext clk pins is being used for I/O from what i could see from the schematic so that would be very difficult but in any case as this appears to have worked for others the cct should work and the code should work as is, i think . does the pickit2 auto detect what clk and at what speed is being used by the PIC I would have assumed it would have too but....
hope this is some help anyway and not a distraction  |
Joined: Apr 03, 2004 Posts: 24499 Location: The Netherlands, Enschede
Posted: Mon Dec 13, 2010 6:48 am Post subject:
| diablojoy wrote: | | does the pickit2 auto detect what clk and at what speed is being used by the PIC |
I don't know for sure for the Pickit, but more expensive dubug tools like ICD2 and RealIce do not auto detect processor speed. _________________ Jan
Posted: Mon Dec 13, 2010 7:13 am Post subject:
anyways, if someone successfully built this module, the problem will not be in the code (porimary). could it be a bad collaboration between the PICkit2 and the code?
i have the feeling, that i am way too deep in the issue - actually it should not be any issue, if others build this project without any issue...
i am puzzled. _________________
Tech Buddy at Random*Source |
diablojoy
Posted: Tue Dec 14, 2010 1:23 am Post subject:
perhaps a gentle enquiry to rykhaard he has bought a pickit3 some few months ago he may have come across this or something similar enough
I do have a feeling it is something simple in the communication between
the PIC and the pickit2 however as jan said using the internal osc and having a midi interface is not great perhaps an out of spec PIC ? though the internal clock is trimmable going by the data sheet . have you tried another PIC yet ?
please post your result if you do resolve this as i do have an ulterior motive, I was planning to buy a pickit2 myself early next year
for the acoupel master clock and cv recorder projects and therefore problems like this one are of some concern to me |
Posted: Tue Dec 14, 2010 5:20 am Post subject:
| diablojoy wrote: | | perhaps a gentle enquiry to rykhaard he has bought a pickit3 some few months ago he may have come across this or something similar enough |
since i am pretty clueless i will try that.
| Quote: | I do have a feeling it is something simple in the communication between
the PIC and the pickit2 however as jan said using the internal osc and having a midi interface is not great perhaps an out of spec PIC ? though the internal clock is trimmable going by the data sheet . have you tried another PIC yet ? |
unfortunatley the thread title states the MIDI2CV, however i am trying to build the quantizer.
anyways, i tried another PIC without success, and i have been able to burn a test program to another PIC.
the current status as i can see it: i created a hex file from the c code file and successfully programmed the PIC (i was able to verify the programming, after setting the code protection to OFF in debug mode).
i quadruple checked the peripheral circuitry and found no error.
so it would be helpful if anybody would/could send me a programmed and proven working PIC (all to my cost for sure!). i then could narrow the error down a little bit more... _________________
Tech Buddy at Random*Source Last edited by fonik on Tue Dec 14, 2010 10:07 am; edited 1 time in total |
ejr27233
Posted: Tue Dec 14, 2010 9:36 am Post subject:
As the OP I've tried everything and still cant get it working......
what it has done is make me look into PIC's and Midi > CV and I'm thinking of trying to design /program a combination of 16fXXX PIC (external crystal) and one of these
http://docs-europe.electrocomponents.com/webdocs/0e43/0900766b80e439ff.pdf
to get 6 CV's, 6 velocities and 6 triggers. Ideal for midi guitar and very cheap as the DAC is about 8 euros.
Does anyone know if this combination would work?? |
Posted: Tue Dec 14, 2010 2:57 pm Post subject:
Quantizer:
today i think i managed what you suggested in regards to the config bits.
i switched to debug mode and built the project. then i run debug. as before all the code protection was switched off by MPLAB. i then EXPORTED the file via file/export menu to hex code, while i checked off the "config bits are set in code" option in the confog window.
i then was able to load the hex without any error message into the PICkit2 programmer software - and write, verify, and read the code without any error.
alas, the quantizer does not do anything
so for now i am not far from wanting to surrender. last option was to breadboard again... _________________
mattias
Posted: Tue Dec 28, 2010 1:48 pm Post subject:
Got a working version 2.3 for MIDI2CV |
Sorry to jump into this thread. I also had trouble with the HEX file from acoupel.com for the MIDI2CV version 2.3.
The issue with the source was in the __CONFIG -line. After some adjustments it worked for me.
The original bit-string for the __CONFIG line from acoupel.com seems to be broken:
I think the line
__CONFIG(1111111101011000);
should read
__CONFIG(0b1111111101011000);
or
__CONFIG(0b11111101011000);
(notice the leading "0b".)
Please note that the new source code uses symbols instead of single bits for the __CONFIG line.
| Description: |
| working image for MIDI2CV Version 2.3 |
 Download (listen) |
| Filename: |
ACS_MIDI V2.3.1a.hex |
| Filesize: |
7.76 KB |
| Downloaded: |
372 Time(s) |
| Description: |
| working sourcecode for MIDI2CV ver 2.3 |
 Download (listen) |
| Filename: |
ACS_MIDI V2.3.1.c |
| Filesize: |
9.99 KB |
| Downloaded: |
378 Time(s) |
_________________ Red is black and plus is minus. http://www.bild-schall.com |
ejr27233
Posted: Sat Jan 01, 2011 1:34 pm Post subject:
Many thanks for that.
I'll try it as soon as I get chance. |
mph
Posted: Mon Jan 03, 2011 4:26 am Post subject:
Hi
may I suggest you to post in the french Yusynth forum: Alain Coupel has a dedicated subforum ( called "ACXSynth" ). And I think it's not a problem if you post in english. So you could have help from the man himself.
http://forum.yusynth.net/
I haven't finished this module yet, but it seems the V2.3 is working for other people with no problem.
Good luck. |
Posted: Mon Jan 03, 2011 4:48 am Post subject:
thanks for the hint.
did anybody here built the quantizer? _________________
yusynth
Posted: Mon Jan 03, 2011 6:11 am Post subject:
| mph wrote: | Hi
I haven't finished this module yet, but it seems the V2.3 is working for other people with no problem.. |
Note that if you want to post on the yusynth forum you MUST select French as the default language otherwise you wont succeed in registering : this is a a quick and dirty trick to block SPAM robots which always select english. Once registered you may post in english this is not a problem
Yves _________________ Yves |
mph
Posted: Mon Jan 03, 2011 6:20 am Post subject:
Sorry Matthias, I don't even know if someone build the quantizer on the yusynth forum... never seen a build report for this module.
But you should ask Alain for this one too ( his nickname on yusynth/forum is "München"). |
PickNick
Posted: Tue Jan 04, 2011 2:29 am Post subject:
hi!
i tried the latest midiCV hex via PicKit2///hex from mattias.
looks ok!
there was no protection error:)
i will try the circuit soon!
thx! _________________ Allow theex.nl |
ACS
Posted: Tue Jan 04, 2011 5:29 am Post subject:
Hi everybody,
the problem you have seems to come from the __CONFIG macro.
You can find a new version of my firmware on my new website : www.acxsynth.com
(I changed my name, I'am not ACS anymore but ACX !)
This new site is still under construction, there are a lot of mistakes, but the firmware for MIDI2CV is OK.
Happy new year !
Alain |
MirlitronOne
Posted: Wed Aug 29, 2012 10:23 am Post subject:
| Quote: | thanks for the hint.
did anybody here built the quantizer? |
Matthias, did you ever get the ACX quantizer working? Because I'm in a similar situation with programming the PIC chip. _________________ Life is like an analogue sequencer. Twiddle the knobs to avoid boredom. |
Posted: Wed Aug 29, 2012 11:47 am Post subject:
no, it is still sitting on my workbench...
but now that you remind me i will give ti a 2nd try (without creating a project in the MPLAB). _________________
MirlitronOne
Posted: Wed Aug 29, 2012 3:11 pm Post subject:
Well, it's a long while since I did any PIC programming, but I recall that the configuration data had to be in one part of memory and the program somewhere else. I'm using a Phyton programmer which is a pretty good piece of kit, but it just seems to take the raw hex data and try to slap it straight into the chip. If I simply try to load it up, it fails. If I offset the loading to start at location 100, it loads and verifies perfectly - but the quantizer still doesn't work. Like you, I've thoroughly checked all the support circuitry.
Looks like I'll have to go back to the textbooks... But somebody out there must know how to get this to work. _________________ Life is like an analogue sequencer. Twiddle the knobs to avoid boredom. |
sneakthief
MirlitronOne
Posted: Tue Nov 03, 2015 5:44 pm Post subject:
I eventually solved the problem by purchasing a programmed chip from the author at a very reasonable price! _________________ Life is like an analogue sequencer. Twiddle the knobs to avoid boredom. |
braincell
Posted: Sun Nov 15, 2015 9:14 am Post subject:
tl866a |
Hi Everybody,
I have built up a board based on the hexinverter schematic , downloaded the firmware HEX file file.
but i cannot get the pic programmed with the TL855 programmer.
it says its programmed but doesnt work.
Can anyone here help ?
Thanks , Lee |
sneakthief
Posted: Sun Nov 15, 2015 5:08 pm Post subject:
braincell - make sure the configuration bits (aka fuses) match the ones in the image I posted above. _________________ Sneak-Thief - raw electrofunk |
braincell
Posted: Mon Nov 16, 2015 12:40 am Post subject:
Hi ,
Thanks for reply .
Does the image have to be binary or intel ?
Does ot load to code or data memory ?
Is there an offsett ??
Its a cheap tl866cs usb programmer from ebay.
Thanks lee |
sneakthief
Posted: Mon Nov 16, 2015 5:46 am Post subject:
Lee: pic chips are almost always programmed with HEX files.
In your programmer software, check the configuration bits page - it looks something like this picture I found on the net:
And make sure the bits are set to the ones I used and posted in my earlier post: http://electro-music.com/forum/post-414216.html#414216
(and not the ones in this picture in this post!!) _________________ Sneak-Thief - raw electrofunk |
braincell
Posted: Mon Nov 16, 2015 6:01 am Post subject:
pic program |
| Sneakthief , Thank you very much will try that over the next few days |
