thapoke
G2 patch files: 5
Posted: Fri Feb 19, 2016 8:30 am Post subject:
Korg mono/poly emulation |
Hello, I finally have a G2!
I have been trying to recreate my korg monopoly as I have to sell it.
The monophonic and arpeggiator modes are easy enough, but the paraphonic section is more difficult. The monopoly has 4 oscillators going through one filter and VCA with an adsr envelope each.
There are 2 problems
1.
In paraphonic mode the key assigner plays oscillator 1 for the first note and if that note is still held down it will play oscillator 2 , then 3 then 4...
If you let go of the first key held down it free's up oscillator 1 - so that will be used for the next key struck.
So the assigner will always play the lowest free oscillator that is not already held down.
I have not been able to recreate this using the status module or the counter - it seems to always assign a new voice and step through the voices in a random order depending on what has been played previously... it should always start on osc 1 then go to the next available oscillator that isn't held down already
2.
The envelopes can be set to retrigger every time a new note is struck or to have a single trigger on the first note.
Single trigger mode is easy using the mono keyboard module but multiple triggering using the keyboard module makes the envelopes retrigger both when you strike a key and when you release it - it should only happen on a key on event..
this thread has the same problem but i don't know if it was resolved.. http://srv4.electro-music.com/forum/viewtopic.php?highlight=paraphonic&t=30835
Any help appreciated!
| Description: |
| this is the patch with the weird retriggering problem and assignment problems |
 Download (listen) |
| Filename: |
Monopoly multi.pch2 |
| Filesize: |
3.04 KB |
| Downloaded: |
4096 Time(s) |
| Description: |
| this has strange voice assignment but correct envelope single trigger mode |
 Download (listen) |
| Filename: |
Monopoly single.pch2 |
| Filesize: |
3.06 KB |
| Downloaded: |
4097 Time(s) |
| Description: |
| this one is why the monopoly is good! |
 Download (listen) |
| Filename: |
Monopoly arp.pch2 |
| Filesize: |
2.98 KB |
| Downloaded: |
4244 Time(s) |
thapoke
G2 patch files: 5
thapoke
G2 patch files: 5
Posted: Sun Feb 21, 2016 7:41 am Post subject:
apologies this is in the wrong section, can this be moved to experimental patches please?
also I have been trying to get my head around the diy pattern appegiator building block which has a keyboard scanning circuit here http://www.electro-music.com/forum/topic-39414.html
- could this be used to make a 4 voice keyboard scanning/ voice assigner? |
Joined: Apr 03, 2004 Posts: 24574 Location: The Netherlands, Enschede
Audio files: 308
Posted: Sun Feb 21, 2016 8:30 am Post subject:
| thapoke wrote: | | can this be moved to experimental patches please? |
Of course
Sorry to not be able to help out though. _________________ Jan
thapoke
G2 patch files: 5
Electromagnetic Wave
G2 patch files: 38
thapoke
G2 patch files: 5
Posted: Tue Mar 08, 2016 5:05 pm Post subject:
| Hey thanks for this, Ill have a proper look soon, had no time recently, cheers |
tomhall
Posted: Tue Jul 26, 2016 4:26 pm Post subject:
| killer patch |
G2 patch files: 38
