synaesthesia
Audio files: 85
Posted: Tue Apr 12, 2016 2:11 pm Post subject:
Two more patches from the Moduletta. The first is using an 8-bit shift register with XOR feedback and a filter. The second uses two counters at different speeds for the melody and a shift register to generate the second voice.
 Download (listen) |
| Filename: |
Moduletta Chimes Bass.mp3 |
1.08 MB |
| Downloaded: |
1243 Time(s) |
 Download (listen) |
| Filename: |
Moduletta Swing Melody.mp3 |
588.69 KB |
| Downloaded: |
1141 Time(s) |
masterofstuff124
Joined: Sep 21, 2015 Posts: 23 Location: Miami, Florida
Posted: Fri Apr 15, 2016 6:30 pm Post subject:
wow this looks amazing. Id love to get a PCB. Im currently building a benjolin and power supply with 12v out so I can connect it with breadboard circuits and patch them to the benjolin. Going for a poor mans sound machines ns1 http://www.sound-machines.it/product/ns1nanosynth/ this "moduletta" seems like it would fit great into that plan. I hope you make the pCB's available!
a fellow sound enthusiast! |
synaesthesia
Audio files: 85
Posted: Sun Apr 17, 2016 11:55 am Post subject:
And two more patches. The first is made from a shift register and a counter to generate random beats with small variations. The second is the famous Rungler made from an 8-bit shift register and two VCOs with PWM.
 Download (listen) |
| Filename: |
Moduletta Beatbox.mp3 |
472.35 KB |
| Downloaded: |
1116 Time(s) |
 Download (listen) |
| Filename: |
Moduletta Rungler.mp3 |
500.92 KB |
| Downloaded: |
1112 Time(s) |
trav
Posted: Sun Apr 17, 2016 6:41 pm Post subject:
| These sound great! Favourites so far are the Swing Melody and Chimes Bass. |
piedwagtail
Posted: Mon Apr 18, 2016 10:40 pm Post subject:
I like the logistics of this: negotiating with a mustard factory for knob supply.
Even the conversation where someone says "this would make a good..."
There should be more synth/catering interaction.
With the bun* colour MDF and the mustard knobs, I feel the pcbs should be red!
Superb work, gentlemen.
R
*bread roll or the precise german word for such I don't know |
Kosmo Mishka
Posted: Tue Apr 19, 2016 9:36 am Post subject:
| Thats great! Sound and design so beautiful. If there will be a chance, I would like to buy couple pcbs or kits. |
synaesthesia
Audio files: 85
Posted: Fri Apr 22, 2016 11:53 am Post subject:
I can't stop. Two more sound samples from the Moduletta. The first is using a shift register for a randomized scale and another one for the arpeggios. The VCA gives it the percussive touch. The second patch uses a long counter for scale and rhythm and a long shift register as a variable divider. It is a bit heavy on the low frequencies, so sounds better using headphones.
The patches are documented and I will publish them together with the schematics and description for the workshop soon.
 Download (listen) |
| Filename: |
Moduletta Rock.mp3 |
1.23 MB |
| Downloaded: |
1038 Time(s) |
 Download (listen) |
| Filename: |
Moduletta March.mp3 |
1.13 MB |
| Downloaded: |
1011 Time(s) |
piedwagtail
Posted: Sat Apr 23, 2016 9:29 am Post subject:
(prompt)
Will you video the workshop?
R |
synaesthesia
Audio files: 85
Posted: Sat Apr 23, 2016 2:46 pm Post subject:
| Yes, now that you ask, I think it would be a good idea. Given that everybody agrees of course. |
elektrouwe
piedwagtail
Posted: Sun Apr 24, 2016 9:04 am Post subject:
Is that paint or recycled plastic?
R |
elektrouwe
Posted: Sun Apr 24, 2016 9:26 am Post subject:
| piedwagtail wrote: | Is that paint or recycled plastic?
R |
it's painted MDF |
Joined: Apr 03, 2004 Posts: 24506 Location: The Netherlands, Enschede
Posted: Sun Apr 24, 2016 12:21 pm Post subject:
Just listened to the sound examples, it does some nice stuff! _________________ Jan
1_over_f_noise
Posted: Sat Apr 30, 2016 2:10 pm Post subject:
Hi elektrouwe,
how you obtained the Moduletta PCB? Or did you make by yourself? |
synaesthesia
Audio files: 85
Posted: Sat Apr 30, 2016 11:52 pm Post subject:
| I designed the circuit and PCB and had it manufactured at vrint-pcb. Uwe helped with the PCB design and did the laser cutting. Of course, he got the first PCB for that. Looking forward to the workshop now. |
stringsthings
Posted: Fri May 13, 2016 2:03 am Post subject:
| Interested in a PCB when available |
synaesthesia
Audio files: 85
Posted: Tue Jun 07, 2016 12:06 pm Post subject:
| You can find a few photos from the ZUKUNFTSMUSIK workshop in Linz at http://dorninger.servus.at/node/1824. We built several Modulettas there and demonstrated them during an improvised performance on the last evening. |
synaesthesia
Audio files: 85
Kosmo Mishka
Posted: Thu Jan 12, 2017 10:20 am Post subject:
| Still want this |
soundworker
haebbmaster
Joined: Aug 27, 2016 Posts: 40 Location: Windenreute, Germany
Posted: Tue Nov 28, 2017 3:33 pm Post subject:
VCO is ready, thank you for this
149 KB |
| Viewed: |
339 Time(s) |
112.46 KB |
| Viewed: |
336 Time(s) |
_________________ Make modular synthesizers great again!
Modular Synthesizer DIY blog: http://modular.haebbmaster.de |
synaesthesia
Audio files: 85
haebbmaster
Posted: Sat Dec 02, 2017 2:11 pm Post subject:
Thank you for the documentation.
This is the dual filter. I added potentiometers for attenuting the CV
On the VCOs I added CV potentiometers too and normalized them to + so they work without a CV.
73.49 KB |
| Viewed: |
326 Time(s) |
124.96 KB |
| Viewed: |
358 Time(s) |
gasboss775
Posted: Tue Dec 05, 2017 12:49 pm Post subject:
A bit late to the party, I know. Are there any PCBs still available for this project?
BTW the VCO works using an NPN transistor instead of the 4066, though it gets quite non linear below about 75 millivolts input CV. |
